Back to:
Tags:
Panasonic CT-36HL43 36
Aspect is wacky. (by 2 users)
posted by kane52 on Feb 24, 2008
Its been getting worse and worse. The aspect on the tv is cutting off the right side of the picture (like whole people). Try to press aspect on the remote to change in between them but there is no response from the tv. How do i proceed?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by jomoto, posted on Jun 16, 2008
I'm having the same problem. The picture is cutting off on the right side and the picture is larger with a faint white line on the right side. What's wrong? How do I fix it?
Best Solution
posted on Sep 29, 2008
Thanks for Trying (70)
jingjao
Rank:Wiz Wiz
Rating: 79%, 33 votes
the capasitor of the vertical section had change value, most common value is 100 micro farad 50 volts
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Aspect is wacky.:
I don't want to Accept this solution
Can you Help with these Standard Televisions problems?
Panasonic CT-36HL43 36" TV
Tv was working fine. Would not turn on this morning
TV suddenly will not turn on.
My TV does not produce sound or picture. This happened...
Greetings: I have a Panasonic CT-32HC43. The TV works fine...
Won't turn on. There is an orange wire that is loose that...
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
