Question about Whirlpool RBS275PD Electric Single Oven
Problem with our oven
The oven, after we start cooking it says F3 and locks the door what should we do to fix it and whats going on?
  • Anonymous Nov 23, 2008
    My Whirlpool oven is set to bake at 350. After a while it beeps, shows a code of E2 F3 and then locks. I can turn the oven off and when it cools down it will unlock. Same thing happens when I turn it on again at 350.
How to fit a heating eliment to a whirlpool akz451/1x/01 oven please
Posted on Apr 10, 2008
My oven door will not unlock after I cleaned it. What should I do
Posted on Jan 14, 2009
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
I'm in the middle of cooking dinner and I got a f3 e2 error and the oven locked...how do I get my dinner out? My husband is an elevator mechanic so he's handy...we turned off the breaker to quit...
That code refers to the oven temperature sensor sensing a too hot oven. I suspect what you did to quite the cleaning cycle should help once the temperature cools down the door should open. I am a little confused, did you set the oven to clean while your cooking, or did it do this on its own, or was it preset and yopu forgot it was set to clean? Your temp sensor may be going bad if it just detected a too hot oven while your cooking. If it started cleaning then it may have gotten too hot and this is the safety device to prevent it from overheating. it sounds like it is trying to self clean, its essential that you find the error code sheet, stuck in the stove or oven cabinet somewhere, also check your range settings so that it is not set to auto clean.
Jun 28, 2011 | Ovens
Failure/error display E2 -F3- What is going on? When using the oven
F3 - E2 Oven temperature is too high (Cook mode)
Replace Oven temperature sensor (RTD)
Note: Applies to all F3-E... codes.
Oct 24, 2010 | Whirlpool GBS277PD Electric Single Oven
Model GBS307PDQ5: Oven preheated to 425 degrees.
F3 usually means, that the oven temp. sensor is bad and one need to replace it.
The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
Whirlpool oven repair orange county, ca
Feb 06, 2010 | Ovens
While cooking the oven started beeping and F3 flashed
Hi there
I found this for you to read and hope this is helpful.Let me know how this goes.
F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuseThank you for writing to fix ya.
Best Regards Richard
Dec 30, 2009 | Ovens
Kenmore double oven flashing "door locked"
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool accubake self clean oven. Error code(s) E2 - F3?
You can get all the codes here.
F3 E2 9 Bake range over temperature At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control.
http://www.repairclinic.com/0078.asp#Westinghouse
Good Luck and Please Rate FixYa!
Jan 07, 2009 | Whirlpool RBS305PDS Electric Single Oven
F3 error code
Try pressing and holding the cancel button for 5 secs. Wait a few mins and it should unlock.
Dec 23, 2007 | Maytag CWG3100A Gas Single Oven
Whirlpool RBS275PD Electric Single Oven Logo
397 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
