Question about Acer Aspire 5630 Notebook
Acer launch manager
Install process for acer launch manager stopped loading, stuck at process 2 of 7 please wait . been like this for 3 days, after reboot.
  • 1 more comment
  • NDND4E Mar 03, 2008
    i inadvertinly deleted my launch manager . how do i get it back? or do i?
  • Anonymous Apr 04, 2009
    deleted launch manager and now how do i get it back?
  • Anonymous Mar 26, 2014
    launch manager windows 7
How big is the hardrive 2.5 inch or 3.5 inch mine is messed up and i need a new one
Posted on Feb 25, 2008
Just look for this:
LaunchManager_Dritek_v3.0.04_W7x86x64
It's the Acer Extensa 5630 launch manager (I think), you can get it on the Acer support page.
I just installed it and all side buttons and Launch Manager buttons are working 100% with Win 7 Ultimate
Posted on Jan 24, 2010
ACER REINSTALL STUCK ON INSTALLING CLEANUP 28/29
Sounds like the recovery disk when BURNT contains errors, you need the factory discs for your system
Jan 26, 2013 | Acer Upper Case Palmrest for Aspire 5336,...
Hi my acer aspire 5315 e button at the top dose not work so do you now who to fix this
Hello reeceman1,
The Acer Launch Manager needs to be running for the 'e' key to work. To run the Acer Launch manager, do these 3 steps:
* Click the windows start button (bottom left-hand corner) * Click All Programs * Click 'Launch Manager'
When the Launch manager window displays on the screen, click OK. Now Press the 'e' button and it will launch the Acer Empowering Technology
If this solution is helpful please click a thumbs-up rating.
Have a great day, martyshaw152
Apr 09, 2011 | Acer Aspire 5315 Notebook
Hello my Acer aspire one kav10 is stuck on windows xp loading screen. I have already tried to system restore to an earlier point by using safe mode but when the laptop starts up again it gets stuck on the...
One of the drivers or programs that is set to launch during boot is corrupted. You will have to find out which and uninstall / upgrade it.
Boot in Safe Mode, click Start, Click Run and type msconfig and hit enter - the startup management window will launch. Click on the Startup tab and untick all the programs in there. Now reboot. If you get the same error then the problem is with a driver - uninstall them all then download the latest versions from the Acer Support site and install them one by one. If the problem is fixed then one of the programs is corrupted - open msconfig / Startup again and tick one program at a time with reboot until the problem returns: uninstal that program.
Feb 26, 2011 | Computers & Internet
I have an acer aspire one, model: KAV60, that crashed a few days ago and I don't think anything is wrong w/ the hardrive but I cannot get it past the Win. XP "loading" screen..i know I may need...
Launching Acer eRecovery Management
1 You may also launch Acer eRecovery Management by running the program
from the Acer program group in the Start menu, or by double-clicking the
icon if you have created a desktop shortcut.
2 You can choose to restore the system from a factory default image or
reinstall applications and drivers.
3 Follow the instructions on screen to complete the process.
Note: External optical disc drive required. Please see your retailer
for more details.
Enable disk-to-disk recovery
To enable disk-to-disk recovery (hard disk recovery), activate the BIOS utility,
then select Main from the categories listed at the top of the screen. Find D2D
Recovery at the bottom of the screen and use the and keys to set this
value to Enabled.
Jan 19, 2011 | Acer Aspire One PC Notebook
CineDashMediaConsole.volume not working.
Cinedash FIX for Windows 7
This works to fix the CineDash Media Console!
I had the same problem with my Aspire 8920G
Now it works fine.
Getting the CineDash Media Console and Launch Buttons working
If you have problems with either the CineDash Media Console or Launch buttons then you will be happy to hear that the solution for fixing these is easy!
The first thing that you will need to do is install the “Launch Manager” which can be downloaded off the Acer website. Go to http://www.acer.com and click the service support, then driver download. Go to your model. Download the Launch Manager on the acer site. The filename should be “Kilimanjaro_v2.0.00_Vistax32×64_XPx32×64.zip” the version of Launch Manager under the Windows Vista operating system .This will get the Email, Web and Empowering Technology buttons working with their default settings. If you need to change what the buttons do, you can launch the application named “Launch Manager” in the start menu.
Uninstall any previous version of Launch Manager
The solution to my problem was to get the Launch Manager to run in compatibility mode for Windows Vista Service Pack 2.
Unzip. Explore the new folder and right-click Setup.exe.
To do this go to the Launch Manager Install directory (C:\Program Files\Launch Manager ), right-click on “setup.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install. But don’t reboot yet!
Now locate and explore the freshly installed folder in your program files directory – (probably C:\Program Files (x86)\Launch Manager or C:\Program Files\Launch Manager depending on if you are running 64-bit or 32-bit)
right-click on “LManager.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install.
Reboot and enjoy properly synced volume, and fully functioning buttons.
Feb 16, 2010 | Acer Aspire 6920 Notebook PC
PSP X2 stopped launching
When it gets to the 2 second point just leave it at that and eventualy, Takes SEVERAL MINUTES, the finish screen appears. patience is rewarded,
Jul 06, 2009 | Corel Paint Shop Pro Photo X2 Full Version...
My CineDash Media Console will not work anymore. The volume, stop, play, etc. does not work. Not with itunes anymore.
This is the way to get it to work!
The first thing that you will need to do is install the “Launch Manager” which can be downloaded off the Acer website. Go to www.acer.com and click the service support, then driver download. Go to your model. Download the Launch Manager here (hosted here) or go to the acer site and find it there. The filename should be “Kilimanjaro_v2.0.00_Vistax32×64_XPx32×64.zip” the version of Launch Manager under the Windows Vista operating system .This will get the Email, Web and Empowering Technology buttons working with their default settings. If you need to change what the buttons do, you can launch the application named “Launch Manager” in the start menu.
Nov 06, 2008 | Computers & Internet
My new acer works fine but there is something loading in the middle of the screen and i cant get rid of it .... how ?
these are system set up routines, when you first boot up Acer laptops they configure themselves, then reboot about 4 times, to load all the drivers and pre installed software, but if its taking too long (hours) then you need to speak to Acer technical, see below for tel no.s
http://support.acer-euro.com/phone.html
Aug 29, 2008 | Computers & Internet
My cineDash media console has stopped working
Confirm that this solution work very well. Thank you.
Jul 07, 2008 | Audio Players & Recorders
How to restore my acer aspire 3680
You might try this. If it doesn't work, you may have to purchase a recovery CD. It is supposed to come with one.
This is from the Acer website:
Re-install bundled software without CD
Acer e-recovery Management stores pre-loaded software internally for easy
driver and application re-installation.
1 Boot to Windows XP.
2 Press <Alt> + <F10> to open the Acer e-recovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer e-recovery Management window, select Recovery actions and
click Next.
5 In the Recovery settings window, select Reinstall applications/drivers and
click Next.
6 Select the desired driver/application and follow the instructions on screen
to re-install.
At first launch, Acer e-recovery Management prepares all the needed software
and may take few seconds to bring up the software content window.
Below is a link for Acer. You can see if it helps.
http://support.acer-euro.com/drivers/notebook/as_3680.html
Jun 20, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5630 Notebook Logo
1,790 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
