HP Pavilion 1310n
Removing cover? looks easy, but is not
    Sergeant:
    Champion:
  • 326 Answers
Just pay attention to what screws come from where and the cover should slide off.
Posted on Feb 24, 2008
After dropping my laptop it will no longer power on
looks like power supply board or even a possible connector had separated internal inspection would be considered due to the fact that the board may have a fuse at most times rear cover can be removed with several screws,it might just be an easy fix.
Aug 11, 2013 | HEWLETT-PACKARD Hewlett Packard 518432-001...
How do I remove/replace the keyboard from a HP Pavillion dv7-2277cl
1. Remove 6 screws from the bottom of the case (as shown). These screws hold the accessory cover.
2. Remove one screw securing the CD/DVD drive. Slide the CD/DVD drive to the left to disconnect it from the motherboard. Remove the CD/DVD drive.
3. Remove all marked screws from the bottom of the notebook.
The yellow circled screws secure the keyboard cover, and the green one secures the HP Pavilion DV7 keyboard.
4. Turn the computer display-side up and open it as far as possible. Insert a guitar pick or small flat screwdriver between the keyboard cover and case and slowly move along the side.
5. Lift the keyboard cover. Be careful, it's still connected to the motherboard. Release the zero insertion force (ZIF) connector and disconnect the cable from the LED board. Remove the keyboard cover.
6. Remove the four screws that secure the HP Pavilion DV7 keyboard.
7. Lift the rear edge of the HP Pavilion DV7 keyboard until it rests at an angle. Slide the keyboard back to disengage the tabs on the front edge of the keyboard from the top cover and rest it on the display.
8. Release the ZIF connector to which the keyboard cable is attached and disconnect the keyboard cable. Remove the HP Pavilion DV7 keyboard.
You can refer to the complete article via the link below:
http://laptoppartstore.weebly.com/replace--remove-hp-pavilion-dv7-keyboard.html
Apr 08, 2012 | HP Pavilion dv7 Keyboard (483275-001)
Removing back cover of hp dv 6915nr
Back Cover?
1) Display Cover: The plastic cover that is on the opposite side of the LCD screen. Sometimes referred to as Top Cover.
Display Assembly is removed from laptop first, then LCD screen assembly is removed from the Display Cover.
2) Base Enclosure: The plastic bottom part of the notebook.
A laptop is disassembled from the Top down to the Bottom.
The bottom 'cover' (Base Enclosure) is not removed first. It is last.
3) There is no back cover per se. Half of the cover for the back (Bottom half) is part of the Base Enclosure. The top half is part of the Palm Rest.
(The back has the Vent in it)
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
[Use the dv6700 service manual. Go down to the subheading HP Pavilion dm1 (dm1 is in blue)
Scroll to the right, click on dv6700. Note that it is a PDF file, and may take up to 30 seconds, before you see the first page come up ]
What is it you are trying to do? What hardware component are you trying to access?
Post back in a Comment.
Regards,
joecoolvette
Display assembly is removed. Palm Rest Cover is removed, and so on.
Jan 14, 2012 | HP Pavilion dv6915nr Notebook
Have a hp pavilion tx2000 laptop. outer screen is cracked but display is fine. can i replace just the cracked part and still have touch screen?
hi.
yes, of course.
you can visit a service center of HP Company and ask for "Shield or Cover Screen". (they ask you the exact model of your laptop)
and they will give you a cover screen which should be installed by yourself.
it's easy and cheap.
need more? only ask!
Jan 29, 2011 | HP Pavilion TX1000Z 12.1" Touch Screen...
Need to remove front cover to replace cd rom drive on hp 735n computer. How is it done?
In some models you need to take screws. But most of them are easy just play around with the frond cover, that is just set with rubber pins onto the cahsis, so unplug them and also the side panel of the case.You wil find screws taht hold the CD_ROM.
Oct 06, 2010 | HP Pavilion 735n PC Desktop
How to take the back of hp laptop.I need to soilder the ac plug back in the laptop.this is hp the serial number istw23910891
Hi there please follow the video below & get knowledge how to remove the back side.
Thanks & waiting for your feedback.
Feb 19, 2010 | HP Pavilion dv6000z Notebook
Not abe to boot up
YOUR WINDOWS FILE IS CORRUPT AND YOUR RECOVERY CD AND BACKUP WHICH IN HIDDEN IN THE SYSTEM IS ALSO CORRUPT . YOU HAVE TO INSTALL WINDOWS AGAIN IF YOU KNOW OTHER WISE CONTACT SERVICE CENTER FOR YOU PC.
Sep 29, 2009 | Computers & Internet
On/off switch failing. difficult to turn on
To repair this, you need some experience. Remove 3 white and 2 black screws under battery. Remove memory cover. There is another black screw under memory cover. Then you can remove upper cover and keyboard. You will see two special white wires connected from cover to motherboard. One of them is damaged. Need to clean these wires or replace with new one
Apr 14, 2009 | HP Pavilion dv6000z Notebook
Cant open the case to my HP pavilion 700
First, turn off the PC, remove the power cord from the back of the PC to remove the 115 volts then push the power button for a second or two so the capacitors will discharge. This is important because the residual charge can cause Motherboard damage especially when changing the RAM. You should follow this process ANYTIME you enter the PC case to make changes, etc.
To remove the side panel on a Pavilion 700x series:
Only one side panel allows access to the inside of the Pavilion case, the left side if looking from the front of the PC. The left side panel has knurled thumbscrews, not machine screws. Loosen the thumbscrews, they are designed to stay attached to the side panel, place your hand on the middle of the side panel and with inward force push the panel towards the back. The panel will slide and inch or two and you can pull it free. This proccess is easier if the PC is unplugged (push the power button on the front of the PC after pulling the power cord to dischard the capacitors) and the right side of the PC laying on the floor. This allows easy access to the left panel and allows light to enter the case from above to change/add the RAM you want to install.
Apex44
Mar 03, 2009 | HP Pavilion (PN153AAR) PC Desktop
Computers & Internet Logo
322 people viewed this question
David Payne
David Payne
