Question about Maytag Neptune MAH5500B Front Load Washer
Getting error code#06 Lr Locked Rotor
I just found the troubleshooting guide for my washer.My washer would start, begin to wash ok then after spin cycle I received error message Lr
Locked Rotor.If I hit start it would start up again then set Lr code.
The washer just began to leak water from underneath also after about 10 Minutes of use, slight puddle.
It says to check the MOTOR DRIVE SYSTEM. It could be either the motor or the motor control board. I did not preform the entire test yet.
I`am thinking it may be the motor control board, Can anyone possibly help me out?
  • 5 more comments
  • matt1966 Feb 25, 2008
    my washer wont spin ,drum wont turn at all and code says Lr what do i do . mitchell4366@yahoo.com
  • pryby Feb 27, 2008
    The Model # is MAH5500BWW and the washer is about 5 years old.
    I `am trying to find out about motor warranty too.
    Thanks- pryby
  • Anonymous Feb 29, 2008
    My washer did not spin all the water out of the clothing and I get a code Lr. What do I do?
  • gce002 Jun 29, 2008
    Having the same problem as of yesterday--Lr on display after washer trys to cycle load of wash--sounds like drum is not spinning. Washer is 6 yrs old in May
    Sent in class action info at the time but never heard from them-
  • NeedCleaning Aug 30, 2008
    I have the Lr code as well. I found the service guide under the top display panel and followed the steps in its troubleshooting guide. I check the 10 amp fuse and the motor windings. Everything looked fine. Does this mean it is the motor control board itself? Is there a test for it?
  • craig carter May 11, 2010
    yes your right i have found that but also depends on model you have
  • Anonymous Mar 15, 2014
    Won't start. Flashing green light. Will not display error after diagnostic test - only the time of spin cycle. Door lock module or Motor Control Board?
I too had the Lr problem on my Maytag MAH5500B. We had it fixed once when it was still under warranty but when it appeared again this summer, I was told that it would cost at least $500 to repair -- in other words, get a new one.
With nothing to lose, I simply unplugged the unit, opened the front and reset (as in pull out and re-insert) the jumpers to the control unit on the bottom right. It's been working fine since and I run it at least twice a week. I noticed that the Lr error would appear when I interrupt the wash cycle once it begins. When the error message appears, I simply unplug it, wait a few minutes and start it up again.
It is after all, a computer...and all computer could use a reset once in a while.
Posted on Aug 07, 2008
    President:
  • Maytag Master
  • 2,651 Answers
I would check you warr in you user man, sometimes they warr the motor on that unit for 10 yrs(certain models) and if its that old a neptune repair kit is in order which includes both motor controller and motor assy
Posted on Feb 25, 2008
It said Lr on screen and stops
LR = Locked Rotor on the motor. Many things can cause this. Please contact me, with more details willing to help all I can.
Apr 12, 2014 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune Washer Model #MAH5500BWW. I am getting an Lr error code. I ran a diagnostic wash and it stopped with the Lr cade and I pushed ^ t continue the diagnostic test. What should my...
Hi
Lr means locked rotor, this issue occurs due to locked rotors, you'll need to check the rotor wiring and motor windings. If the wiring is good and windings are not burnt then you'll need to replace your motor and motor control board. These are sold as one unit, it is a 3 phase motor and one of the phases is bad as a little power surge can damage the boards. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune tl what is code Lr
LR is the error code for Locked Rotor.
This could be an issue with the Motor Controller or Control Board.
I have not seen Drive Motor cause this issue to date.
If you want to investigate further I would suggest getting the FAV6800A/FAV9800A Service Manual.
Google this ""Neptune TL Washer FAV6800AWW""
This is a sticky for the FAV6800A/FAV9800A washer DIY support. Go to the 5th post down in the Sticky and you will find a link for the Service Manual.
If you want to go further in troubleshooting and possibly a DIY fix just open a new thread in that DIY forum with Model number and Serial number. That info is found tag behind the console right back side as you face the machine console.
Feb 24, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Error LR what does that mean
LR = Locked Rotor
Could be a Control Board Issue. Will the machine let you do a Spin Only cycle?
This could be a difficult problem to troubleshoot with out a known Control Board or Motor Control board........D*ick
Aug 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Lr code went into service mode but wont respond to commands model #fav6800aww
Tom,
The LR error code can be a tough one to troubleshoot but I'll see what if any help I can be.
The LR code stands for Locked Rotor.
If you Power Cycle the 120VAC to the machine will the error code clear?
What cycle was the machine in when you took the error code wash, spin?
If you remove the front panel and with the 120VAC power cord removed from the service outlet can you rotate the Clutch Pulley CCW (Spin direction) or CW (wash/agitate) direction.
Sounds like you have the FAV6800A/FAV9800A Service Manual.
Let’s see if the drive system is free and not locked up…………Rich
Jul 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Gives an error code lr
The “Lr” = Locked Rotor: The machine has repeatedly tried to turn the motor.
I have seen this issue caused by a failed motor. I have seen a bad Control Board cause this issue and a bad Motor Controller cause this issue.
If the Lr error code happened in the Spin Cycle of the wash cycle it could be caused by seized Outer Tub bearings.
Without a known good Control Board and Motor Control board this could be difficult to troubleshoot.
Here is a link for the FAV6800A/FAV9800A Service Manual
May 31, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune Washer
lr is a code for a locked rotor assy, on the motor itself, depending on age of machine you might have warr on the motor(part anyway) check your user guide and warr info. probably gonna need to install a "neptune repair kit" which includes new motor and new motor controller
Nov 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Fills with water but wont wash or spin
The code LR stands for locked rotor you will need a new motor and motor control kit pretty expensive and only covered under you warrenty for a year!
Aug 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
You may have an outer tub seal leak and the bearing may be trying to seize up, hence the lr code. Removing the back panel will divulge a brown colored "spray" mark around the cabinet perimeter. This is not a DIY job and is usually around $650.00.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. You should be able to find a manual there. If not then try; www.maytag.com
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action?psid=31378668&sid=MMHSx20070515x00001a
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Error code Lr
i am a appliance repair man and this is a normal problem and you need to replace your motor and motor control board sold as one unit these are 3 phases motors and one of the phases is bad. dont forget to put a surge protector on these machines because a little power surge can damage the boards maytag just figured this out because they are sending one with the new machines
Oct 11, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
1,172 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
