Question about SanDisk Sansa e200 MP3 Player
Sansa e 200
Ring turns on but screan is blue & red dots
  • david h Feb 24, 2008
    i need help my ring turns on but the screan is blue&red dots fuzzy
Hello i have that same ecxat one maybe i can help u with it..wht is rong?
Posted on Feb 24, 2008
My sansa fuze at times freezes. I do not know why,
When the blue ring is illuminated, first try the RESET for the Sansa Fuze.
The player should NOT be connected to any other device:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
When a RESET won't work or the player freezes again, UPDATE the firmware on the player in 2 steps.
> step1: Enable MSC mode
1. Turn device OFF: when the player is frozen first perform step 1 and 2
of the RESET procedure:
seconds.
2. Slide the Hold switch down to Lock (orange colored dot showing).
3. Press and hold the left button ( |<< ) while connecting the device to the PC.
> step 2 : UPDATE the firmware
Use next page for updating the firmware on the player.
http://kb.sandisk.com/app/answers/detail/a_id/278
There are 2 methods for updating, for Windows operating system the
updater ( method 1 ) should work:
Method 1; Use the Sansa Firmware Updater
Method 2: Use the update board / Sansa forum
Look in the Update page for the steps to follow.
Jul 20, 2010 | SanDisk Sansa Fuze MP3 Player
How to set up a redhead red dot pursuit deluxe
You must have the correct rings for your base. If the scope has rimfire dovetail rings already attached, it should be easy. Remove the 4 setscrews on the top of the receiver, install the dovetail mount (use blue locktite and DO NOT TIGHTEN THE SCREWS MORE THAN 10 IN/LBS! Otherwise you may strip the threads in the receiver!).Loosen the clamps, place the scope on the dovetail mount and tighten snugly.
If it has weaver mounts, you will need to install a weaver rail to your receiver. Remove the 4 setscrews on the top of the receiver, install the weaver mount (use blue locktite and DO NOT TIGHTEN THE SCREWS MORE THAN 10 IN/LBS! Otherwise you may strip the threads in the receiver!). Install the rings in the weaver slots, tighten snugly.
Go Here:
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
for info on how to zero your red-dot after you have it mounted.
Apr 17, 2010 | Cabela's Optics
My sansa wont turn on, I took out battery to reset and blue ring
Try resetting your firmware via Sandisk's support site. If it still doesn't work, your sansa's mainboard might be busted. The cost of replacing it will be more than a refurbished one (under $40 online).
Jun 13, 2009 | SanDisk Sansa e200 MP3 Player
Nothing but the blue ring lights up
ok..idk if this will work but it might...first turn off the sansa...then turn the hold switch on (it should turn red). hold down the record button on the side of the player..then while still holding that hold the power button down...but keep holding them untill a screen shows up saying something about recovory mode..itll say to plug in the usb..u could do that..idk it that will work..it it doesnt instead of plugging in tthe usb in the computer..wait about 15 seconds after the recovory mode screen shows up and then hold down the power button for about 15-20 sec...then itll go all black (including the blue light) press the power button again like u would to turn it on...and everything should be back to normal..hope this helps...:)
May 04, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e 200
my sansa e200 is having some problems the ring is lite up but the screen is black i tryed alot of things nothing is really working can you please HELPPPPPP me pleaseeee
Feb 21, 2008 | SanDisk Sansa e200 MP3 Player
Not turning on
Mine is almost the same except I don't get the dots. The screen only works when it's plugged up to the computer.
Jan 28, 2008 | SanDisk Sansa e200 MP3 Player
No screen
Sounds like the blue ring issue. TRY THIS FIRST!! If it works then great, ONLY DO THE LAST SOLUTION (a link) IF RECOVERY STEPS BELOW DO NOTHING. You WILL brick your sansa if you don't abide. In case our recovery procedures differ: ALL DATA WILL BE LOST WITH THIS PROCEDURE!! You can try a ROM recovery. - TURN OFF UNIT - Place hold switch so orange shows - Hold down the REC button with the red dot on the side of the player. - Whilst holding the REC button, press the power button as if to turn on the unit - Let go of the REC button You should see the recovery console. YOU WILL LOSE ALL DATA!! However you will also have a working player. LAST RESORT ONLY IF YOU CANNOT ENTER RECOVERY MODE!! http://www.anythingbutipod.com/forum/showthread.php?t=8953
Aug 18, 2007 | SanDisk Sansa e260 MP3 Player
Wire kit for a Audiovox BA200 200 Watt base tube
There are 5 wires to connect to the BA-200 for proper operation. 1. Red Wire with Fuse: Connect this wire to a source of + 12 volts which does not turn off with the ignition key. It may also be connected directly to the po~itive (+) terminal of the battery. 2. Black Wire: Secure this wire using a screw or bolt on a grounded metal surface of the vehicle. Clean-away any rust, dirt, or paint from the surface to make sure a good connection is made. 3. Blue Wire: This wire activates the BA-200 when the stereo system is turned on. Connect it to the "Power .Antenna" lead from your car stereo. If your car stereo does not have or you cannot locate the Power Antenna lead, the blue wire can be connected to a source of + 12 volts which is turned on and off with the ignition switch. In this case, the BA-200 will be activated whenever the ignition switch is turned on, whether the car stereo is on or off. 4. Green Wire: Splice this wire to the wire going to the positive (+) terminal (sometimes indicated bya red dot) of the left speaker of your stereo system. 5. G ray Wire: Splice this wire to the wire going to the positive ( + ) terminal (sometimes indicated bya red dot) of the right speaker of your stereo system. You Need to order this piece trough the manufacturer, with out this piece the sub is useless, i am guessing around $20-$30 for it
Jun 06, 2007 | Audiovox BA200 Car Subwoofer
SanDisk Sansa e200 MP3 Player Logo
22 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
