Question about Mackie SWA1801 Subwoofer
Mackie SWA1801 NO POWER, NOT TURNING ON
I have the schematic from Mackie and it shows that i am supposed to have 18V at the rectifier D40. I noticed that at the transformer (Coil) I am only getting 5V from the secondary. It is a dual winding coil and the other winding has an output of 22V which feeds another rectifier D1. I also noticed that at the start-up board where the coil plugs into, there is a relay involved that does not energize. According to the diagram, 18V is required at the coil of the relay to energize. Does the relay energize when 18V is received from rectifier D40 or does the relay have to be energized before anything happens...can anyone help???
  • 1 more comment
  • dj georgie Oct 11, 2009
    hello can you please send me schematics circuit., G_man001@hotmail.com
  • mianibma268
    mianibma268 Apr 05, 2012
    hello i can help you can send copy of schamatics circuit i my email. is mianibma22@live.com tanks .
  • ixbt
    ixbt Apr 21, 2012
    Please help! i have blown capacitor, on this sub, please send me schematic to kurkul@gmail.com thanks!
Help please looking for a schematic for my sub ,as it's blown both fuses ,suspect further damage mackie 1801
email to justthinkofaname@hotmail.com (thanks). regards Rich.
Posted on Apr 11, 2011
    Problem Solver:
  • 5 Answers
  1. I have blown capacitor in my mackie swa1801, Can you send me schematic g_man001@hotmail.com thanks Georgie.
Posted on Aug 16, 2009
My transistor tip 122 is crossed and my fuse 1 is blown out. i need a diagram of mackie swa1801.
Posted on Mar 05, 2012
Hi, I have no power on my Mackie swa1801 Can you zend me that schematic please? De_Wijns@hotmail.com THX Thomas
Posted on Oct 30, 2011
I have one with a different problem, Get me a me a circuit diagram and I will tell you in 5 min what your problem is.
Posted on Nov 18, 2010
Please help, can you send me schematic djglutto@wp.pl
thanks
Posted on May 13, 2010
Check The 20 watt 22 ohm risistor on the ac input board
Posted on Jul 11, 2009
Hey,
Can I get a copy of that schematic?? I am also troubleshooting the same problem. I have found in two other occasions that the large power resistor has blown along with the poweramp. They are supposed to blow OPEN but in the case of the two i have worked on they burn to a high resistance. I only had 5 VAC going to primary of the large toroidal input coil. Maybe your problem maybe not. I have also needed to replace transistors TIP122, MJE15033 and MJE15033 and 2sc5200's(both) on the outputs.
-Brian C. Miller
metallifornia@hotmail.com
Posted on Oct 29, 2008
  • metal81 Nov 20, 2008
    Add these resistors to the fix for the Mackie swa1801
    r6 100 ohm
    r8 1 ohm
    r56 1 ohm
    r57 100 ohm
    The 1 ohm resistors (brown, black, gold, gold) damage was hidden to the eye but using a DMM you will see that they are burned open. I removed them from the PCB and found that they were burned on the underside.
    -Brian C. Miller
I think you will find that the relay is energised by the primary AC, which then passes the secondary outputs to the amplifier section. This is to protect the circuits in the event of the input supply falling below required level, which would otherwise result in wrong current loading and component failure.
Posted on Jun 10, 2008
Hi. I have problems with my SWA1801. When I try to start the amp, the Thermal light goes on. Even if the amp is cold ! What can it be? I have turned down the gain on the back and have good cables to the...
Power it ON, without anything connected to the input.
If it powers On without the thermal light, then rejoice,
If it powers On with the thermal light it means something...
Oct 23, 2012 | Mackie SWA1801 Subwoofer
No power
There are about 6 fuses on the inside. check them but the amp is probably blown
May 26, 2011 | Mackie SWA1801 Subwoofer
The thermal light comes on on my swa1801 and lose all audio what could be causing this to happen?
make sure its plugged into a large circuit over 30AMP! Turn down the gain on the back. They can't take too much punishment so turn the bass down on the eq. Get a stronger sub
Jul 01, 2010 | Mackie SWA1801 Subwoofer
How do you get to the ac fuse on the SWA1801 ?
There are 4 allen-head screws that hold the amplifier assembly in - two on top and two on bottom. Remove these and the entire thing slides out the back. There is one fuse near the power switch and two on the power supply board inside. Be sure to use the correct value.
May 13, 2010 | Mackie SWA1801 Subwoofer
Ould some one send me a copy of that schematic. I
Sorry, not really a solution yet. Just contacted the Belgium Service center. They say they're not allowed to give the schematics. Maybe Mackie is ashamed to show what's in it? Any way, this is all but a good publicity for the service of Mackie
Gerdy
Gerdy's Music Shop
Belgium
gerdy@gerdysmusicshop.be
Nov 07, 2009 | Mackie SWA1801 Subwoofer
Mackie swa 1801 power amp R7 100 ohm resistor smokes when powered up..
You likely have other parts blown as well, but Q3 (MJE15033) AND/OR r8 (1 OHM/0.5 Watt) are blown. I suspect that Q3 has a base-collector short and you will find several of the output transistors are fried as well Q4, Q5, Q15, Q16. I suspect that the Zeners D14, D25 may be blown.
When restarting this, put a 100 Watt lampin series with teh 120 volt power to limit current and avoid destroying freshly repaired parts due to a few bad ones not found.
Aug 17, 2009 | Mackie SWA1801 Subwoofer
Swa 1801 mackie blown capacitor
Took alot of finding but you can get them from Digi-key
Sep 16, 2008 | Mackie SWA1801 Subwoofer
How to open SWA1801Z
Please follow the guide given in the link.. there is a chapter on woofer replacement..
http://www.mackie.com/pdf/repair/SWA1801z%20repair%20guide.pdf
--please give your comments..
have a good day
sree
Jul 01, 2008 | Mackie SWA1801 Subwoofer
MACKIE SWA1801--Sound quality is not same
I suggest, go out and buy a heavier duty 18 and replace it.
Aug 24, 2007 | Mackie SWA1801 Subwoofer
Mackie SWA1801 Subwoofer Logo
2,244 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
