Question about Amcor PLM-14000E Portable Air Conditioner
Amcor plm15keh I had an Amcor 15000 btu Aircon/Heater worked fine for 9months then one day set it to come on in heat mode,it did but overheated,melted outer casing, burnt carpet and smoke damaged my flat.Have photos of remains clearly shows burns around mainboard, mains lead and plug intact, circuit breaker never tripped.Currently waiting for Amcor to inspect unit,so I can claim off their insurance.
  • 86 Answers
Change thermostate switch.its means yr thermostate switch donot working.the heater running cotinusly,this is the reason for over heat.
Posted on Mar 17, 2008
Duo therm heat pump blowing hot air only
relay module or communication cable from t-stat issue.
Apr 02, 2014 | Dometic 459186 Duo-Therm Brisk Air...
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
I have two Amcor AmcorAire UCHW-H12AF2 Split System Air Conditioner units -- 2 years old. One works fine, but the other does not blow heated air (Heat Mode). It is cold outside, but the good unit is...
your unit may be have possible leak on piping then refrigerant exit or had leakage of refigerant try to locate leak then braze it then recharge a correct amoun of refrigeran. if you use heater try to check heating element if ok by supplying voltage or used ommeter to test continuity.
Feb 03, 2011 | AmcorAire UCHW-H12AF2 Split System Air...
I have an AMCOR model AL-10000EH. The A/C side works fine but I cannot select the heat mode with controls on the panel or with the remote. I can select all modes except the heat mode. Hope You can help,...
Remove batteries from remote and reset it. Now keep in "Heat" mode. and setting temp +5 degree than your room temp. Wait for 3 minutes. Heat mode symbol will be like symbol of SUN. Helpful?
Dec 27, 2010 | Amcor Heating & Cooling
AMCOR 24,000 BTU split system. Worked fine two years, then today it had no power. Checked circuit breaker, it had popped. Reset CB and went to inside unit - would not turn on or off with remote or hard...
I had this same problem. I disconnected the thermostat wire out side at the condenser and reconnected it and it started working. A couple days later it blew the breaker again this time I found the bus where the L1, L2. GR wire connect at the condenser had melted. I wire nutted all 3 wires instead of the using the bus everything is working right again. Hope this helps.
Tim
Aug 09, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
Amcor aircon 15000btu
Have you tried pushing the reset button on the power plug? If the unit overheats the reset button will click on and the a/c will turn off. In order to turn it back on you will have to push the reset button.
Jul 09, 2010 | Amcor PLM-14000E Portable Air Conditioner
My LS-H186 VML 1Metal Art Cool 12000 BTU Air Con does not heat up
You should also check the outside unit to make sure the coil is not clogged with dirt or grass clippings and the fan is working. The reversing valve that switches it from cool to heat could also be a problem. If it isn't shifting it will not switch between heat and cool.
Apr 29, 2010 | LG Art Cool LA181CNW Split System Air...
Amcor PLM-14000E Portable Air Conditioner Logo
309 people viewed this question
Top Amcor Heating & Cooling Experts
Donni Steen
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
