Question about HP Pavilion dv4307CL Notebook
Keyboard and Mouse stopped working.
About 6 months back my laptop dv4307CL keyboard and touchpad stopped working. But I can connect external keyboard and mouse through USB and able to use the laptop.
When I sent for warranty, they figured there were ants inside and not covered and asked me to replace the motherboard. When I said ok, they changed and said still the keyboard and touch pad not working and asked more money which is equivalent to get a new laptop.
Now is there anyway I can replace the motherboard and make the keyboard and mouse work?
Any idea to replace with less cost would be appreciated.
TIA
  • humbletechy Feb 24, 2008
    Thanks for the prompt response. In that case, how can I make the keyboard and touchpad works. Atleast keyboard. Without it becomes desktop :-)
    Genius:
  • 1,019 Answers
Ants in the motherboard, Are they on Drugs ?
The keypad, connects to the motherboard via an additional ribbon cable usually, so it,s not always a motherboard issue.
i think they saw you coming, and just trying to make a fast buck.
If the externals working fine, carry on with them and save your money for another laptop.
When you buy a new 1, take it to whoever told you there were ants, in the motherboard, and bounce it straight off the back of his head.
Mike @ compurepair.
Posted on Feb 24, 2008
  • Mike Waldron Feb 24, 2008
    if you can get a replacement top-casing, which contains the touchpad and mouse.
    they can be swapped over, from the original one you have on there now.
    if that still does,nt solve the problem, it,s the motherboard or power connection board, that the mouse touchpad, connects to.
    this may be a seperate board to the motherboard, they refer to this as a PWB ( power Board ) Or daughterboard.
    Mike @ compurepair.
Keyboard, touchpad and external mouse stopped suddenly..for Toshiba satellite l3900
Press function key on keyboard F5 to see if this helps turn on mouse / touchpad
Jun 21, 2016 | Toshiba Computers & Internet
I can't click on anything on my home screen. Gateway N522 series. Won't tab or do anything. Helpppp!!!
Try ensuring that the touchpad hasn't been accidentally disabled (Hold down the '[fn]' key and press the F6 key on your keyboard to toggle the touchpad(mouse) to be enabled or disabled.
Have you tried using an external keyboard and mouse?
If the external keyboard and mouse work then we know it is something to do with the built in keyboard and touchpad on your laptop (likely - but not positively a hardware issue). If it does not work then we know that the issue is likely (but again not positively) software based.
Jan 20, 2015 | O4Jelectronicswarehousecom Wireless N...
Touchpad not working
Hi :
This problem is common with Acer Extensa seies . I've an Acer Extensa myself . and i always get this problem .
In future i advice you to not use the touchpad . Just use an external mouse to prevent this to happen .
good luck .
rate if useful please !
May 15, 2009 | Acer Wireless WIL-192 Keyboard
My acer 3100 keyboard and touchpad arent working. any help?
It's possible that something uninstalled the devices from Windows. You can try connecting an external keyboard and mouse, then check the Device Manager to see if it flags any hardware problems.
Another possibility is that the flat cables connecting the keyboard and touchpad to the main board have come loose. To check the cables you need to remove any screws securing the keyboard and pop off the top edge trim to lift the keyboard up.
Mar 31, 2009 | Acer Aspire 3100 Notebook
Toshiba satellite touchpad & keyboard stopped working
As I understand your keyboard is now working and your usb mouse. But the touchpad does not work.
Have you or someone opened up your laptop recently? If so it is possible the touchpad was not connected properly.
Can you please post the exact name of your laptop. I'll see what else I can figure out for you.
Oct 03, 2008 | Computers & Internet
Touchpad dead, keyboard erratic
Go to my computer, right click>properties>hardware tab>device manager, then look down the list for mice and pointing devices, click the '+' sign and right click on your touchpad and select uninstall, do the same on the keyboard line and then restart the pc.
Both touchpad and keyboard will be reinstalled and then ready to use again as it should be back to normal
Sep 10, 2008 | Acer TravelMate 4001WLCi PC Notebook
Acer Extesa 6601 Keypad & Touchpad Problem
you need the drivers for the touchpad and keyboard, click on the drivers and utilities section, then allow active x when the pop up appears
http://support.acer-euro.com/drivers/notebook/ex_6600.html
Aug 23, 2008 | Acer Aspire 5100-5022 Notebook
Keyboard,sound,touchpad all not working keyboard, touchpad and all usb ports stopped working
kINDLY CONNECT A USB KEYBOARD AND/OR MOUSE TO TROUBLESHOOT THE NOTE BOOK IF USB KEYBOARD/ MOUSE (EXTERNAL NORMAL USB DESKTOP KEYBOARD MOUSE). THEN WE WILL BE ABLE TO TROUBLE SHOOT
Feb 29, 2008 | Acer Aspire 5100 Notebook
Keyboard and touchpad
Have you attempted to use an external mouse? - USB - if so does that work?
if it does - Click on START - Control Pannel - Keyboard (& Mouse Respectively) - Click on the hardware Tab - Select the relevant Key Board, Click on Properties - this will give you a device status - if is is not working properly - click Trouble shoot & follow the onscreen instructions. - If is "Working Properly" click on Drivers - check your driver is updated, or roll back.
If you happend to be on a server and the keyboard and/or mouse have stopped responding - you will need to restart (The Server). Ensure that the Keyboard and mouse are on PS2 connections and not USB - the Severs do not like USB Connected Comms Devices. I have found if there are wireless mouse's &/or Keybourd's &/or any USB connected Mouse/Keyboard, they tend to somehow interfere with each other (i.e. the sever with one of the terminals) - only remedy I have ever managed to make work is restart.
Hope this helps
Feb 04, 2008 | Toshiba P25-S670 Notebook
Touchpad
sounds like software encoding error nothing you or  i can do cept take it in to a place like infotech i like them they help me alot
Oct 27, 2007 | Acer TravelMate 2300 Notebook
HP Pavilion dv4307CL Notebook Logo
206 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
