Question about Microsoft Xbox 360 Console
Xbox cooling fan sounds louder than normal
The cooling fan sounds like a vacum running is this common.
  • 1 more comment
  • rgrafton Nov 03, 2008
    today i turned on my xbox and the fan sounded as if it were accelerating and it sounded as if it was not going to stop speeding up and getting louder.. but it did and it is staying steady. Louder than normal. Maybe the sensor is bad...?
  • Anonymous Feb 21, 2009
    my xbox 360 is louder then it normal is also if you listen carefuly you can hear a clicking noise and i realy need to get it fixed before i sell it.
  • rgrafton May 11, 2010
    today... i turned on my xbox and i had 2 red lights. idk...
  • 25 Answers
Yes, the cooling fans are commonly loud. Your xbox has a sensor on it when the CPU and GPU heat up, the rear fans suck more air out by turning up the rpms the fans run at.
Posted on Feb 24, 2008
Why does my Dish Network DVR-625 DTV receiver sound like it is running all the time
The Dish 625 as with the other Dish DVR systems has a fan built into the back of the unit. The fan runs nearly all the time to keep the internal drive cool. Sometimes the fan sounds louder that normal. what I do from time to time is take my shop vac and or the small vac u you use to clean your computer. and clean the vents around the fan. I do this on my desk top computer also.. Hope this helps.
Sep 03, 2014 | DISH Network DVR-625 DTV Receiver /...
Kenmore elite french door refrigerator and freezer not cooling
Check the compressor start device. The fans will be running and the compressor fan will be running but the compressor is problaly not running. If it is then it could be the compressor itself that is not oumping.
Mar 25, 2014 | Kenmore 73502 / 73504 / 73509 Bottom...
My xbox360 is really loud I don't know what to do
1. If your xbox 360 is in a confined space your not allowing the console to allow fresh air in and the heat out . The reason for your 360 being loud is the fans get louder and louder when the 360 system senses that the gpu heat sink is getting too hot. If you leave your xbox 360 on while you away for too long or if you play for too long the fans will get louder and louder . Solution : move the 360 to an open aired room if the problem persist shut off your xbox 360 and let it cool down a bit .
Jul 18, 2010 | Microsoft Xbox 360 Console
I have my dometic Rooftop ac unit. The heatstrip/fan run perfectly but when I turn on the ac...the fan runs good but when the compressor kicks on it just hums.
The compressor coming on does make a slight "humming" sound which is normal. Is the unit cooling properly? Do you think it is louder than before?
May 09, 2010 | Dometic Rooftop RV Air Conditioner
Xbox has two red rings and fan gets louder by second????????????
reflow the joints on the board it should fix the issue then let it sit for an hour and cool down
Aug 30, 2009 | Microsoft Xbox 360 Console
Gateway laptop - whirring, buzzing sound
if it's a continuous whirring sound it is most likely the cooling fan. this is normal. as the computer gets older this will get noticably louder as the fan has to run faster to prevent overheating.
Aug 14, 2009 | Gateway Computers & Internet
Engine sounds loud on cold start
It is normal for an engine to run at much higher RPM's when they are cold and that will make it sound louder.
Jan 07, 2009 | 2004 Ford Focus
Fan louder than normal
Sounds like whoever did the txv, changed the fan speed. Yes, the fan speed is adjustable. Some HVAC units can have up to 4 speeds on the motor. Low, Med Low, Med Hi, and Hi. this is so the same unit can be used for several different cooling coils and tonage. The faster the speed in the cooling mode, the less cool the air will be.
Sep 29, 2017 | Carrier 38CKC036 Air Conditioner
Xbox cooling fan sounds like a vacum running is this common
probably worn bearings. Or clogged with dust.
turn-off, unplug all leads, get vacuum cleaner on it and suck the blighter.
re-set back up.
nothing to lose eh ?
Mike @ Compurepair.
Feb 24, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
893 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
