Question about Texas Instruments TI-89 Calculator
TI-89 Backup Battery
Hey, I am just wondering what happens when one removes the backup battery from a TI-89 Titanium calculator? A program froze the whole thing so I want to pull the backup battery to see if that will clear the problem. Will I be able to reinstall everything from the Connect-thing? Thanks for your help.
  • 1 more comment
  • Kevin Brookes
    Kevin Brookes Feb 26, 2008
    I'll let you know if it does. Thanks.
  • Anonymous Feb 27, 2008
    (x^3+6x^2-37x-210)/(-x^3-12x^2-39x-28) graph
  • Anonymous Jul 23, 2008
    Error: Protected Memory Violation
  • 76 Answers
Usually you will be able to re-install everything. And I would try uninstalling the program first then if that doen't work just pull the batteries out and put them back in or just press the reset button. Hope this helps. =)
Posted on Feb 25, 2008
Take of the backup battery and it will be fine
Posted on Apr 14, 2009
I have 2 TI 89 TITANIUMS N THEY JUST SHUT OFF N DONT TURN ON ANYMORE WTH!! I NEED HELP PLEASE
Posted on Aug 01, 2008
My calculator keeps showing the number 1 and is completely frozen. I can't clear it or turn it off. I've tried replacing the batteries and it's not working. Help!!!
There should be a backup battery in the calculator that you can remove also. This battery keeps power to the calculator when the main batteries are removed so that information doesn't get lost while you change them. Try taking this battery out for a second along with the main batteries and that might fix your issue.
Jun 12, 2015 | Texas Instruments Texas Instuments TI-89...
TI-89 Titanium completely frozen (Tried all reset methods)
Press left and right arrow and 2nd keys simultaneosly, hold it and then press ON. Release all keys at the same time and you will reset TI 89 Titanium.
Or, type diamond key simultaneosly with + or -
(plus or minus) key to resolve dark screen.
Jun 01, 2017 | Texas Instruments TI-89 Calculator
My TI-89 Titanium's screen froze. Well actually, the cursor kept blinking but none of the buttons worked. I got it to restart using the (-) and ) button trick, but rather than going back to normal it went...
Hi kelsers,
You need to re-install your calculator's OS. After this process your Ti 89 Titanium will operate properly. If you do the process below make sure you use new batteries.
Warning!!! If you do this procedure make sure that your computer and, calculator are connect. Use Ti Connect software and, make sure you can install the OS on the calculator without any interruption. At any time even at the very beginning of this process, if your computer or, calculator gets interrupted or you have a power failure during the installation of the OS, your calculator will be destroyed. So not attempt this procedure during a thunder storm.
You can use the Ti OS Downloader but, you will have no idea what OS is stored by the Ti OS Downloader. So, I suggest following my instructions and, installing the newest Ti 89 Titanium OS 3.10v.
Procedure to installing the newest Ti 89 Titanium OS 3.10v.
You can also get the latest copy of Ti 89 Titanium OS 3.10v by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 89 Titanium OS 3.10v." Once your at the Ti site click the Download Item, Ti 89 Titanium OS 3.10v. Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti 89 Titanium OS 3.10v. will download to you. Click, "SAVE". And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, "Save as" to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 89 Titanium guidebook too, if needed.
Link your computer and calculator with the USB cable or, Direct Black Link cable that came with the calculator.
Remove one of the AAA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. On the older TI-89 you should see "Press I to install code...", and you should press the [9] key to continue. But, on your Ti 89 titanium it should say, "Waiting to receive..." or, "Waiting to received OS...". Now you need to follow the instructions in the paragraph below to restore the calculator's operating system.
Next, drag the Ti 89 Titanium OS 3.10v. that you copied earlier to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Next the OS Downloader Warning will pop-up. Click, "OK" to continue and, the new OS will begin to install. The Ti Device window should pop up and, click on to the port where your Ti 89 Titanium is located, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 89 Titanium OS 3.01v. will be installed.
Jan 10, 2011 | Texas Instruments TI-89 Calculator
When I turn the switch on, ti-89 titanium does not turn on.
If you connect calculator to computer using Ti connect device explorer you might be able to see what files are on the calculator. I don't know if you downloaded from the web but, 3rd party programs and shells tent to miss up the calculator. This would able you to delete out possible problems which could be re installed later.
Sep 22, 2009 | Texas Instruments TI-89 Calculator
TI-89. Don't turn on.
I've did the same thing but, with Ti Connect Device Explorer software, I was able to reinstall the OS software. If it is that unresponsive take out all batteries including the backup battery for about 4 hours. I had to do that one time just to get unlocked from the graphing APP. Ti one time told me to miss with the arrow and ESC keys, and it works sometimes. Good Luck, and I hope this helps your posted problem.
Jan 13, 2009 | Texas Instruments TI-89 Calculator
Ti 89 Titanium Battery use
I have a regular TI-89 (HW2)...have had it for 6 or 7 years. Suddenly it's doing the same thing. I have to put new batteries in it every week or so. I even replaced the backup Li-Ion battery. I'm getting really tired of buying new batteries but don't want to go shell out 100+ for a new one.
Anyone have anything on this? I'm having trouble finding much on this...
Oct 01, 2008 | Texas Instruments TI-89 Calculator
HELP!!
Well, in most calculators, the action of taking out the backup battery practically clears the whole thing. Memory, everything. I myself have a Ti-89 and have not yet experienced this problem, but I have on an older Ti-82 and removed the backup battery and the whole thing is dead now, or at least nothing happens when I turn it on, even after replacing the batteries again. If you still have the manual, I would check out the troubleshooting. If you don't have it, try to find it online. And if you have done both of these things, try getting hold of technical support through Texas Instruments.
Jan 30, 2008 | Texas Instruments TI-89 Calculator
TI-89 Titanium (hardcore reset)?
Hey guys,
Do this it will reset your calc and get you out of your busy state
2nd - left arrow - right arrow - on
It will reset your calc no matter how frozen it is.
Nov 16, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
2,390 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
