Amana ALW480DA Top Load Washer Logo
Posted on Feb 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer wont drain or spin just hums and then blows fuse
Amana top load washer wont drain or spin and blows fuse after I hear a hum
  • 1 more comment
  • murphnh2002 Aug 11, 2008
    Yes, for the SECOND TIME in 4 1/2 years of use. Did it again this weekend and I am really angry. Last time, under warantry, was over $100.00 in labor!!! And the guy said it was a design flaw that Amana was aware of! We are a family of 2 adults who both work, so it isn't getting heavy use either....
  • Anonymous May 11, 2010
    My amana LWD 70AW top loader, doesn't blow a fuse but hums and stinks like electric overload, I changed the capacitor several months ago and it ran for a while, but now I've got the problem back.
    I would like to avoid replacing the motor if that's not the problem. It runs fine once the initial load is taken off the motor.
  • Anonymous Mar 18, 2014
    wont drain
Anonymous
Level 2:
  • Expert 156 Answers
  • Posted on Feb 25, 2008
Anonymous
Expert
Level 2:
Answers
156
Questions
0
Helped
85643
Points
266
How can I spin and drain my normal size load. I have an LG front loading washer m/n WM2455H and it will not spin and drain. I hear the hum of the pump, so it isn't that. Went through all troub
It is most likely the drain motor even though you hear it humming. The LG drain motor impellers usually wear out on the motor shaft, and the impellers then just end up wobbling. The result; a drain motor that no longer drains water.
1helpful
2answers
Wont spin or drain
Does the machine agitate if so this eliminates the motor coupling could be a bad timer place unit in spin if motor hums then power going to motor eliminates this check the drain pump it is white and attaches to the motor with 2 spring clips if there is something stuck in it or a bad bearing won't drain if a washer cannot drain it will not spin hope this helps.
1helpful
Replaced the clutch and motor coupler a month ago. Ran great. Washed tennis shoes. Came in to remove clothes, didn't spin. Wont agitate or spin, i could hear the motor running. Just replaced the motor...
Check for a failed capacitor under the control panel It is a start/run capacitor that the motor needs to start running. The motor will hum and if left will eventually burn out.
Amana washing machine dosent spin
Maybe door switch? Hear any humming? Belt might be broke.
Service Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Kenmore washing machine catalyst stops during rinse cycle
The hum you here is the probably the motor trying to turn, but it is about burned out. If it moves a little with a full load and more with no load, it is probably bad. If you hear a hum and the drum never moves at all you probably have a broken belt.
1helpful
Washer filled w water but wont agitate,spin or drain. I hear a humming,buzzing and something smells like it is burning. After several attempts to start in various different cyles it may have tripped...
send the model number.if it's humming it sounds like the motor is bad.where.if it resets after a while and hums again it's the motor.there's an overload in the motor,when it gets to hot it pops and will reset after it cools.
Amana clothes washer alw880qaw
Hi, Check the belt first. Remove the lower front panel and see if the belt is ok. Please let me know if I can assist you further.
Thankx
Vic
Top Amana Washing Machines Experts
Virgil Watts
ZJ Limited
ZJ Limited
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
