Question about Car Audio & Video
Ghostly car stereo
Turn on ignition front fascia of cd player cotinually opens and shuts making it impossible to operate . problem started after flat battery
  • 199 Answers
Hi is thi9s a kenwood mask type unit?
if so it sounds like the flexi/ribbon cable is faulty.
check they may beable to help
Blue ICE
Posted on Feb 26, 2008
97 grand cherokee laredo wiring cd player install. can get power to it but have to have battery and ignition switch hooked together how to do it the other way? cause it erases my memory on the cd player...
Hi the ignition wire needs constant power thats how it saves your memory. You will need a test light to find the wire that is constant power. With the key off touch the light tester to the power wires from the radio harness the one that turns the light on with the key off is the ignition wire and is to be connected to the ignition wire from the radio.
Feb 05, 2010 | Cherokee (REF) AM/FM Stereo with CD Player...
My JVC car stereo will let me listen to the radio but when i put in a cd it wont play and 00:0000 AY flashes constantly. It started a week ago... have i pressed a wrong button?
I had the same problem, it occurred after my battery had run flat. To fix it you need to reset the unit. To do this, remove the clip-off fascia, and on the main body of the unit there small hole, just to the left of the connector. Push a narrow pointed object such as a pen nib into this hold until you feel the click. The unit is now reset and should be working properly. You'll have to retune your saved radio stations, but the cd player should now be working.
Can't tune my radio station to cd/mp3 car stereo, not sure of make doesn't state. only info to go on is acoustic solutions ics-30 rds compact disc digital audio
Try holding the reset switch for 5 seconds. It's located under the front unit/fascia of the stereo so you'll need to take that off.
Aug 15, 2009 | Pioneer DEH-3700MP CD Player
2002 malibu wiring diagram?!?!?!?!?!?!
ok, the red and yellow wires serve 2 different purposes.the yellow supplies constant power to your stereo, and the red is switched power. what youve done is combine the two, and connect them to a constant power source. like this, your stereo wont be switched with your ignition. so take off the red wire, but leave the yellow wire connected to the wire its already on. make sure your stereo fuse is good in the fusebox of the car. then, use a test light, with the ignition switch on, to find the second wire on your cars harness that has power. that will be your switched power. connect that one to your red wire, and that will solve your problem.
Aug 04, 2009 | Corvette Chevy Malibu 90-04 Car Radio...
Car will not start after installing CD player into a 1999 Saturn!
Check your Ignition 1 & ignition 3 fuses in the inside fuse block,also check the body fuse 10amp in the inside fuse block.Keyless entry should take back off once you found the blown fuse.hope this helps
May 26, 2009 | 1999 Saturn SL
How to take out the light assy on a 2004 Toytota sienna van.RH side. Do you have to take off the front cap (bumper)
Yes....herer is the steps to replacing it:
Headlight Assembly Removal & Installation Standard Headlights To Remove:
  1. Disconnect the battery ground cable.
  2. Remove the left and right front inner fenders. Fog light & headlight assembly (exploded view) toyota-06-00-5662.gif
  3. Remove the 8 screws and separate the front splash shield from the front bumper fascia.
  4. Remove the 5 push-pins from the top of the fascia grille.
  5. Release the retainers on the left and right sides of the front bumper fascia and pull the fascia toward the front of the vehicle.
  6. Disconnect the headlight assembly connectors.
  7. Remove the mounting bolt, 3 screws and headlight assembly.
  8. Turn all bulb sockets counterclockwise to remove.
To Install:
  1. Turn all bulb sockets clockwise to install.
  2. Align the retainers with the slots and install the front fascia.
  3. Install the 5 push-pins on top of the fascia grille.
  4. Install the front splash shield on the front bumper fascia with the 8 screws.
  5. Install the left and right front inner fenders.
  6. Connect the battery ground cable.
  7. Vehicles with power windows perform the following steps:
    • Turn the ignition switch on.
    • Open the power window halfway.
    • Close the window and continue to hold the switch up for at least 1 second after the window is closed.
    • Ensure that the auto up/down circuit is operating properly.
    • If the auto up/down circuit does not operate, disconnect the battery ground cable for 10 seconds.
    • Connect the battery ground cable.
    • If the auto up/down circuit does not operate, turn the ignition switch on.
    • Close the window and continue to hold the switch up for at least 12 second after the window is closed.
  8. Vehicles with sliding roof system perform the following steps:
    • Press and hold the TILT UP switch until the glass tilts to the full up position. The glass will automatically tilt slightly down after it reaches the up position.
    • Release the switch.
    • If the sliding roof does not operate properly, replace the sliding roof ECU.
May 07, 2009 | 2004 Toyota Sienna
Broken front release fascia button. How do I fix it?
only thing i can think of is contact alpine and get a replacement part of find the broken clip and try to glue it stereo parts are hard to fix because the componenent are plastic usaully .
Dec 30, 2008 | Alpine CDA-9851 CD Player
I need to install a kenwood cd player into my 2001 ford explorer step by step
goto the auto parts store and purchase a pair of stereo keys, fascia adaptor and wiring harness (you may need to get fascia and harness from a car audio store or circuit city.)
Then use the stereo keys to remove the factory stereo. Push them into the small holes on the front of the stereo push them slightly outwards and pull to release the stereo. Unplug all the connectors from back keeping track of where they fall.
Insert wiring harness into the stock wiring
attach fascia in regards to its packaged instructions.
Place cage from new stereo into the hole in the dash using the tabs on cage to secure it,
Attach stereo to other end of new harness along with aerial (may need adaptor for this also depending on the new head unit.)
Insert stereo into new cage and voila nice new stereo.
Nov 27, 2008 | Kenwood Car Audio & Video
Stereo will not operate correctly
did you try running a ground wire from the case of the deck to the battery,just for testing?
Feb 04, 2008 | Kenwood KDC-MP435U CD Player
Sub display screen
It's usually the flexible pcb that connects the fascia to the main board that needs replacing, because the fascia opens and closes each time the ignition is turned on and off the connector flexes and eventually some of it snaps, sometimes if you pop the trim off you can see the snapped pcb on the bottom right hand side of your radio
Dec 11, 2007 | Sony CDX-M800 CD Player
Car Audio & Video Logo
37 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
