Question about Panasonic PT-51HX41 51" Rear Projection Television
I cannot change aspect ratio
When I try to change aspect ratio it is not highlighted and I cannot change it. I have a HD Tivo hooked up to HD Cable without a box....just Tivo. Any ideas?
Thank you.
  • 42 Answers
If you are trying to change the aspect ratio on the television make sure you are sending an HD signal Via Component cables. I am not aware of a way to get HD cable without a PC cable card or box, it could be that your television is not receiving the proper signal (analog, or composite) to switch the aspect ratio on your particular television.
Posted on Mar 07, 2008
Tv does not show full picture. top and bottom of picture are not viewable.
You cannot change aspect ratio when recieving HD signal. Try changing the cable box or satellite box format or aspect ratio.
Jun 11, 2011 | Olevia LT42HVi 42 in. LCD Television
Aspect Ratio problems with Insignia 26
Keep your Auto Zoom Off set Full screen than only you will get proper picture
Jan 21, 2010 | Insignia 26 in. LCD Flat-Panel HDTV
Picture size doesn't fit the screen I tried to adjust the aspect ratio but the option is locked on the menu. What to do? (Olevia TV model lt42hvi
Dec 30, 2009 | Televison & Video
Cannot change aspect ratio of picture when ratio button is pressed on remote. Batteries in remote are good. Everything else on remote works. Sony KP-57HW40
If you are connected to a HD cable or satellite box, the aspect ratio is set by that box. If it is set for 1080i 16:9 wide screen mode then your TV is locked at that ratio. This is good considering you have a Hi-Scan 1080i television in the Sony KP57HW40. Please take a moment to rate my answer. Thanks...
Nov 24, 2009 | Sony KP-57HW40 57" Rear Projection...
Onkyo TX-SR606 aspect ratio issue
you may want to try changing the aspect ratio on the HD box and the DVD as opposed to the receiver. This should do the thing
Mar 04, 2009 | Onkyo TX-SR606 Receiver
My tivo HD is not broadcasting or recording in HD
As far as I know, you need the cable cards to get HD through the Tivo, because they're what does the HD decoding and output.
Jan 18, 2009 | Tivo HD
Picture not to edge of screen
That is because you are watching the picture in the 4:3 aspect ratio. This is normal when you are watching a channel that is being broadcast in 480 or digital. But once you tune to a station that has 1080 or at least 720p which is true high def then the picture should expand to 16:9 aspect ratio. It will switch between the two automatically as it determines what type of signal it sees. You can force the resolution to change by pushing the format or aspect ratio button on the remote but you will lose picture quality.
Jan 11, 2009 | Panasonic PT-50LC13 50" Rear Projection...
32LG30 LCD TV screen aspect 4:3
I went into options or menu on LG remote and checked 480i and it worked.
Jan 10, 2009 | LG 32LG30 32 in. LCD HDTV
Philips LCD TV wont change aspect ratio
In your philips menu there is an option to turn of your auto aspec ratio to OFF then using your sky remote go to services, 4 then picture and ensure that this is set to 16:9
Job done
Cheers
Little Dish Fitter
Dec 24, 2008 | Philips 32PF7321 32 in. HDTV-Ready LCD...
Connecting my Humax Series 2 Tivo to a Motorola HD DCH3416 Cable Box
Yes, the Tivo will just record in standard definition, instead of high def.
You can still hook the two up together, though.
What I would suggest (and have done in the past) is this:
Split the cable coming out of the cable box.
Hook one up to your HD cable box, and the other up to the Tivo.
Hook the output of your HD cable box to one HD input on your TV
Hook the output of your Tivo up to a different (non-HD) input on your TV.
This will allow you to watch HD while recording standard definition, and vise versa.
Running the HD through the Tivo will work, but will limit you to not be able to watch HD through it.
Aug 10, 2008 | Humax DRT800 TiVo Video Recorder
Panasonic PT-51HX41 51" Rear Projection Television Logo
631 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
