My tView 10.4" headrest DVD player does not turn on. I have connected it to the battery as per the instructions. The package came with 2 headrest monitors, one that actually has the dvd player installed. Neither monitor will turn on. I checked the fuse and the connetions, all were good.
hi hallow then their is a problem in passing power supply or receiving power supply r some where the connection may lost which unknown to u so please refer it once again and see the battery connected perfectly are not. u explained u r problem very well but such problem can solve by cheaking the instrument practicaly so if still u r problem is not solved its better to consult the expert near to u directly
Make sure the 12v power source you are connected to is constantly hot. Then check to make sure your ground is in a good location. You can check this by putting the ground wire over various parts of metal until you get a spark. Then connect the ground in that location. If you have a good power supply, and the buttons on the unit still do not power it up, I would get them replaced or repaired. PS- also check the fuses the units came with. Those might be blown as well.
I have a 2wd, no sunroof SR5 sequoia and would like to install a dvd/video player on it.
Are there...
(More)
Are there units that fit into the last opening of the overhead console? Are the ones that are being installed aftermarket fitting in there or behind that overhead console? Any suggestions of ones that you have found to work would be greatly appreciated.
Our DVD player will no longer play most disks unless we eject the disk and re insert several times....
(More)
Our DVD player will no longer play most disks unless we eject the disk and re insert several times. It doesn't matter what type of disk; whether its one we burned or one bought straight from the store. The player will say that its loading and then after several minutes say that it is a bad disk. The player is just over a year old.
