Question about Yamaha DV-S5650 DVD Player
Yamaha dv-s5650 Try resetting picture size. Was fooling around with pal setting.Can no longer get any type of menu to come up on the T.V. no setup.How can I reset DVD player.Also disconnect the AC power over night.
  • Anonymous Mar 05, 2008
    Playing around with pal settings ... black screen
  • rexcarr2 Mar 21, 2009
    My DVD player only shows in black and white. I also was trying to change TV type or PAL/NTSC settings. Now the picture moves vertically so fast I can not reset it to the former position. That did not change black and white issue. I have tried numerous cables and plugs but still BLACK AND WHITE. As a first start I need to reset to factory settings. Any help out there?
I have a Yamaha DV-S5550 and recently did the same thing. Our players may have the same menu system. Give this a try. Turn the power to the dvd player on. Using the remote, follow this key sequence exactly. Press the onscreen button. Press the down directional key once. Press the right directional key once. Press the down directional key six times. Press the right directional key once. Press the down directional key once. Press the left directional key once. Press the onscreen button. Your player should now be set to NTSC output. Good luck!
Posted on Apr 22, 2009
Reset factory settings
Hi,you need to go into the setup menu,check for vidoe settings and change video output to pal,thanks
Nov 03, 2013 | Yamaha Televison & Video
I have a (cyberhome ch-dvd 300) dvd player and changed setup menu now lost video cant see to change back is there a reset code or something
I wish I could find the website that gave all the repair hints for this DVD player, but I downloaded the info, and can no longer find the site. Here is what it says with regard to your symptoms. I hope this helps. I have done all the mods the site suggested, but continue to have difficulty with the remote, tray opening, etc. I have 2 machines and used to love them, but frustration has taken it's toll. Recovering from a condition with no TV picture
Accidentally switching to PAL and getting a rolling black & white picture happens all the time to baffle users, especially on models with a System or P/N key on the remote. To get back your color and sound just switch to the proper system in the menu or put in a movie of the correct type and it can switch automatically or try the procedure below for resetting to the defaults.
Sometimes owners will accidentally switch to Progressive Scan in the menu then get no picture at all. You can fix the no picture condition on the CH-300 by resetting the defaults to interlaced as mentioned in the users manual:
"To reset the VIDEO OUTPUT, turn Off the player, turn back On, open the disc tray and press and hold the Stop button on the player for 10 seconds to reset the scan mode."
The Reset procedure doesn't seem to work on all versions but you can sometimes get a usable B&W picture allowing you to get to the menu and change the settings by connecting the composite video input of your display to the Red Pr/Cr or Green Y component output jacks on the rear of the cabinet.
You can also go into the Menu and set it blind with the following key presses on the Remote:
1. With the unit Stopped, press Setup.
2. Press Enter.
3. Press the Down Arrow 3 times.
4. Press the Right Arrow Once.
5. Press Enter.
On 300Z & 300ZS models if the video is set to Progressive Scan and you can't get a viewable picture on the Red or Green jacks try going into the Menu blind and changing it back with the following key presses on the Remote:
1. With the unit stopped, press Setup on the remote.
2. Press the Right Arrow Once.
3. Press Enter.
4. Press the Down Arrow 2 times.
5. Press Enter.
6. Press the Up Arrow 2 Times.
7. Press Enter. This should switch it back to Interlaced scan with S-Video and Composite output.
To change the Parental Control setting on the CH-300 use the factory password of 3351. For the CH-400 use 1379.
Nov 02, 2009 | Televison & Video
My yamaha dv-s5650 is only playing in black & white!
That's a problem with the video IC it might shorted. You need to send your TV now to the nearest electronic repair center and have it fix there.
Jun 29, 2009 | Televison & Video
Distorted picture, after changing "TV TYPE"
well here goes
its going to take a little finness but i think i can help
i got the owners manual infront of me
find dvd/cd press it. then setup button on remote go to the osd menu you probably wont see it cause its a little fuzzy
but were going to try and walk threw blind, video menu is the first one on menu so its going to be one down
that tv type
one over to right arrow keys
one down to ntsf setting then hit ok (enter)
this way is a blind walk threw but will get it done if have patiences
the other way you mentioned is that your missing preferneces
will see and check
the other is [preferences page]- [default]- [reset] Press enter (ok) to reset the paremeters to initial factory settings
this can be found on page 38 en of the manual i will also post the link so you know what i am looking at hope these too things work i know you cant see your screen but a blind walk threw is better than not having the preferences not being there for you
http://www.generalmanual.com/pdf/yamaha/DVX-C310_manual.pdf
May 06, 2008 | Yamaha DVX-C310SL System
Need a manual for 1998 runco 42''
If it is running in B&W, then you have got it set for NTSC and playing a PAL picture or the other way around.
Just go into the setup menu and the option will be there to set the video output format.
Apr 21, 2008 | Runco PlasmaWall PL-42 42 in. Television
No video in my philips dvd622
The black and white picture is caused by only 2 things.
  1. You are trying to play back an NTSC disc in a PAL dvd player (or the other way around)
  2. Your DVD player is set to NTSC when it should be set to PAL (or the other way around)
You will find options for setting PAL or NTSC in the setup menu under Video.
Apr 03, 2008 | Computers & Internet
How to switch back to NTSC from PAL without being able to see player menu
Solution to resetting TV type for RJ Tech
  1. hook up unit to computer monitor (not a TV)
  2. power up, remove any media from the tray
  3. select setup menue
  4. for TV type - select NTSC
  5. for TV output make sure CVBS S-Video is selected
  6. exit setup
Oct 28, 2007 | RJ Tech RJ-200S DVD Player
Mustek dv3000
Try change the video out setting to "pal",press the menu button and scroll 3rd down which will show "ntsc" or "pal" press "set" to get "pal".
Oct 15, 2007 | Mustek DV-3000 Digital Camera
DVD picture cuts in and out first 15 minutes
This is like the problem I had for some months. After a lot of exchanging cables and troubleshooting on forums like this, I decided to call in the Sony service engineers.
The problem turned out to be nothing more than a menu selection. You need to check the setup menu under video and select the colour system you are using (NTSC, PAL). The factory setting on the TVs is 'auto' apparently and sometimes a weaker signal will cause the auto colour setting to drop in and out. In our case we set it to PAL and the problem has not recurred.
Sep 03, 2007 | Pioneer DV-545 DVD Player
No sound
Go into the TV Menu and access the sound settings, for the UK it would normally be set to I. This MAY need to be changed to a different setting. Try the options that are listed. Might fix it!!
Jul 28, 2006 | Sanyo C40N
Yamaha DV-S5650 DVD Player Logo
269 people viewed this question
Top Yamaha Televison & Video Experts
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
