Question about Refrigerators
RERFIG TEMP PROBLEM
Refrig temp problem stuck at 82 deg freezer below ok..kitchen aid
model KBFA25ERSS00
JOESZ1313@GMAIL.COM
  • 3 more comments
  • joesz Feb 24, 2008
    thereis nothing wrong with the lighting that works the TEMPERATURE OF THE UNIT IS 82 DEGREES need to COOL or something...
    the lighting works well...NEED COOLING OF THE UNIT DOWN TO 32 DEGREES???
    refrig temp problem stuck at 82 deg freezer below ok..kitchen aid
    model KBFA25ERSS00 NEEDS TO COOOOOL
    JOESZ1313@GMAIL.COM
    THANKS MIKE THAT MAKES SENSE...where is the part located and what is the part no???
    vents cleaned and open no luck....
    Genius:
  • 1,019 Answers
thermostat Fault,
you,ll get lots of nonsense answers on here.
Some of these clowns, will say anything to earn $3-$5.
turn the thermostat up/down see if it clicks at any point.
Mike @ compurepair.
Posted on Feb 24, 2008
  • Mike Waldron Feb 24, 2008
    it,s usually the temprature dial, if it,s a chest freezer will be on the bottom. usually lit display and round dial.
    If it,s a fridge-freezer, will be inside the door, numbered dial 1 to 6 or 1 to 10.
    turn it either left or right, if you get a click, it,s working.
    if not it,s the thermostat not shutting down.
    good-luck buddy.
    Mike.
    Genius:
  • 3,422 Answers
Check the air vents. If you're having trouble achieving the right temperature, even after numerous adjustments, make sure the vents on the inside of the fridge aren't covered. This can prevent air flow, making it impossible to cool the refrigerator.
let me know if this worked.
Goodluck..
  • Priya darshan Feb 24, 2008
    Here are few points which will help you solve the problem:
    1. Make sure the cord is plugged in and that the breaker hasn't tripped.
    2.
    Check the settings on the temperature control if the fridge is too warm
    or too cold. This is the dial that's usually located at the top front
    or right rear of the refrigerator.
    3. Note the ambient temperature
    of the kitchen. If the fridge seems to be running for a long time, it
    may be that the room is just warm. If that's not the case, make sure
    the door isn't being left open and that the door gasket is sealing.
    4. Vacuum the coils under the fridge. Dust may be keeping them from cooling properly.
    5. Be sure that the appliance is at least 4 inches from the wall to ensure enough circulation to the coils on the back.
    6.
    Notice if the light comes on, but the motor doesn't run. The
    temperature control may be turned off. If the control is properly set,
    you may have a bad thermostat.
    7. Change the switch if the bulb is
    staying on when the door is shut. You can check this by pressing the
    button located along the hinged side of the door. The light should go
    off when you press it.
    8. Listen for unusual noises. Are the
    shelves rattling? You may need to tighten the supports on the back
    wall. Items on the shelves may also be the cause of the sound, such as
    glass bottles clattering together.
    9. Remove the base grill. Is the defrost pan the culprit? Make sure it's on its tracks and that the felt pads are in place.
    10.
    Check the condenser fan under the fridge. Sometimes paper stuck in it
    makes a racket. If there is something there, be sure to disconnect the
    power before you attempt to remove it.
    Let me know if this was helpful.
    Goodluck..
    Sergeant:
    Champion:
  • 281 Answers
The problem is with the lighitng, you should change that part that when you open the refregirator it turns on, after you change it the temrature will come back. Hope this helped you.
What temp should i run my cf80 to use it as a fridge and freezer
Refrig. temperatures are about 36 to 42 deg F.. Freezer temps from about -5 to + 8 deg F.
Apr 16, 2018 | Refrigerators
Ge freezer temp changes from -3 to 44degs and the ice melts and runs on the floor. I replaced the main board about 2 yrs ago, help?
Self defrost mechanism appears to be ok sinc eyou can get down to -3 degrees. The culprit in this refrigerator is the temperature regulator or electronic thermostat in this box. It should not allow the temp to swing that drastically from one extreme to another.
Mar 17, 2015 | Refrigerators
"Refrigerator/freezer runs continuosly but temp never goes below 42 deg in refrig or 18 deg in freeze"
well i hate to be the one to give you the bad news but most likely a bad thing... your compressor is 1. either weak, or 2 you are running low on freon....
Apr 27, 2009 | Refrigerators
Compressor runs, very little cooling, internal fan not running
You will need to unplug refrigerator and open plane inside freezer to see if fan is stuck or burned out. If freezer is frozen over with ice you will need to warm the ice for removal. Let me know, when you are ready, Sea Breeze
Mar 22, 2009 | KitchenAid KTRP22EK Top Freezer...
Kitchen Aid Refer: KSSC42FMS01: The freezer, doesn't go below 32
How long have you had this refrigerator and is this the first time this has happened? Your refrigerator has a control board and I believe the board is causing the refrigerator not to defrost every 8 hours. Let me know these questions and I will help you resolve this. Thanks, Sea Breeze
Mar 19, 2009 | KitchenAid Refrigerators
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Kenmore sidebyside
Hi! There,,,If you want help, one needs to explain the problem.. A refrig is quite simple in opertion, with time used experience. For a side by side the freezer is cooled with the same system as the refrigerator cooling system. One and only. Freezer works, do you mean it is provining design temperature of some -10 deg F??? Do you have a by-pass duct between the the two. yes, then open it up more, disconnect motor is auto, and prop vent open, set refrig temp to a low temp say 40 deg F. are we cooling??? Post your condition, if you want further info Regards,,,fmauka
Sep 05, 2007 | Kenmore 74822 / 74824 Top Freezer...
Freezer temp
Do you have a problem with the fridge other that. Have u tried adjusting you controls .. freezer and refrig. ? That should be ok unless you having problems with something else ... like say ice maker
Aug 18, 2007 | Frigidaire FRS23R4A Side by Side...
Freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Jun 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
