Question about Magellan eXplorist 500 GPS Receiver
Magellan Explorist 500 LE Power
While trying install new battery and charger, unit won't power up anymore. Tried USB cable, AAA battery pack and Li ion battery, still nothing. Does anyone know where diagrams can be found.
  • 1 more comment
  • lexmac3 Mar 02, 2008
    My explorist 500 is just a wk old it won't power up i downloaded maps turned of magellan when i tried turning it on later nothing Batteries are fine used lighter adaptor still dead?
  • peerkons May 03, 2008
    My eXplorist was 2 weeks old. Bught it in e-Bay as factory refurbisehed. Seems I am having the same problem, but I do not want to believe that GPSr died... this is not fair! There has to be a solution! :S Tried almost everything, but anyway it does not turn on..
  • Anonymous Mar 23, 2009
    I keep getting low power shutting down even when I have put new batteries in.
EXplorist units have also some hidden and service functions. Like, if unit is off, you can to press:
- IN + PWR - to full selftest of unit (screen test, keypad test, NMEA test)
- OUT + PWR - to serial port test
- ESC + PWR - to burn-in process
- LIGHT + ENTER + RWR - tp uploading of new firmware
- NAV + PWR - to call Service Function window (see below)
- NAV + MENU + PWR - to force power off, equal remove batteries.
- GOTO + OUT + POWER - clear memory and set all settings as default.
IN + PWR helped to power up my unit.
Posted on Nov 15, 2008
Try pressing both the power and backlight keys at the same time. I have no idea why but this worked for me.
Posted on May 22, 2010
  • frankswd Oct 10, 2010
    My unit wouldn't turn on while on batteries but would on USB cable. I thought it was broken for sure. This trick got my UNIT TO TURUN ON AGAIN!
Make sure you are using the power button on the right side of the unit and not the backlight setting on the left. I know this sounds silly, but I just spent 20 minutes trying to figure out how to turn it on. Dah!!
Posted on Mar 18, 2008
My explorist Gc unit...on start up is looking for an active tracking file which is missing. I have a copy on my desktop. How can I get it back into the unit?
You can download the US basemap for the 500 at
http://www.megaupload.com/it/?d=EJTNQH03
Rename it BASEMAP.MGI
Then copy it in the directory "background maps" in the SD card of your 500, by using a SD card reader/writer.
Insert the SD card in your 500 and connect it to your PC; then turn it on;it will turn on regularly, because the basemap in the card will be detected; turn it to USB file transfer mode, and copy the basemap from the SD card to the directory "background maps" of the 500.
If you already have the file ..just rename it like I said ..and copy it ..using the sd card in the reader...Than if it is not functional ..just reset it ..and reload the file the proper way by reloading maps..
Aug 28, 2011 | Magellan eXplorist 500 GPS Receiver
Cant not get watereays on explorist 500 in canada
You can try to update your GPS firmware.
Before you update your Magellan eXplorist 500 firmware or install a custom basemap, Magellan recommends that you backup all of your GPS data.
Click here to download the firmware update (Version 2.57)
Connect your Magellan GPS unit via the USB drive.
Double-click on the update file to begin the installation process.
Follow the on-screen instructions .
Jun 17, 2011 | Magellan GPS
We have a Magellan Explorist GC that we have had for only a couple of months. It freezes when turning on. The Magellan name comes up and the spinning compass thing, but then the spinning thing just...
I had the same problem. Was able to fix it as follows:
1. Turn unit off (pull battery if on/off won't respond) 2. Plug unit into PC with USB cable 3. Hold the menu key and the joystick in the "up" position and power unit on. Make sure you H O L D all three buttons as described until unit is fully powered on. 4. This should allow the unit to go into maintenance/disk access mode. Go to the Magellan website and download the newer version of the system (ver 1.4 as of this post). 5. Follow the install directions.
After doing this, my unit came back on just fine. From what I've read, ver 1.0 of the system has some issues.
Aug 10, 2010 | Magellan eXplorist GC Handheld Geocaching...
Magellan explorist 500 wont recognize sd card. Is there any type of card recomended i have tried 3 diferent cards in 2 diferent units but when i try to turn sd memory on it wont let me.
  • Try to check the Sd card if its already formatted. because if the sd card is still not formatted it will not work to your GPS.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Feb 14, 2010 | Magellan eXplorist 500 GPS Receiver
Device driver for Explorist 500 for windows vista
J'ai vista et je ne suis pas capable d'entrer le périférique.Le cd qui vient avec est conçu pour wimdows 2000 et xp et moi jài windows vista.
Sep 21, 2008 | Magellan eXplorist 500 GPS Receiver
NMEA communication does not work ( but file transfer is OK)
Try rebooting windows, with gps off connect the cable to gps.
Go out side get a good gps signals on nav menu.
Set the gps communications menu to , nmea, 2.1
Plug the device into a good usb port.
If you look under modems, in control panel you should see a new modem called explorist xxx
If you look at the properties for that you can see its com port number.
I just tried this program http://www.visualgps.net/VisualGPS/
and it views nmea from the explorist, just set the com port to the one in the explorist modem .
Jun 06, 2008 | Magellan eXplorist 500 GPS Receiver
Explorist 500
i had the same problem you have to contact magellan and they will tell you it needs to be sent in for repairs and they will send you an email or give you a phone # for the closest repair center to you
check this link for the magellan technical support closest to you https://www.magellangps.com/about/contacts.asp
Oct 19, 2007 | Magellan eXplorist 500 GPS Receiver
Magellan eXplorist 500 GPS Receiver Logo
1,402 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
