Question about Kenmore Elite HE4 Electric Dryer
Coin stuck in the tub baffle
How do you remove a coin that is stuck inside the tub baffle?
  • hardnail Mar 03, 2008
    The appliance was a washer machine and not a dryer. The suggestion did not work. Is there away to fix it on a washer machine?
  • hardnail Mar 15, 2008
    This was very good feedback on how to resolve the problem.
    President:
  • Kenmore Master
  • 2,651 Answers
Its a little tricky but can be done. Can you remove the top panel of your washer?? 3 *****s along the back lip and the entire top will slide back and off. theres a little black hose leading from the soap dispensor to the top of the outer tub assy. its only pushed into the tub and is real flexible, pull it out .you see through the maybe 2inch hole and see he inner basket. as you rotate the basket from inside with your hand the inner baffle(s) will line up to the hole and depending on date of manufacture. they might have put a small stainless ***** in from behind to hold baffle in place,ifso remve the ***** and the baffle (although a little tricky should slide toward the rear of machine to remove, and pull toward the front to reinstall heres a replacement number for hte baffle 8182233, incase youbreak it youll need to replace
Posted on Mar 10, 2008
    Problem Solver:
  • 12 Answers
On top of the machine where the filter is there are 2 screws`remove.gently pry up on the top front of machine.it should pop up. rotate tub till your coin gets to the top .you should see the screws you need to remove .
Posted on Feb 28, 2008
Coin stuck in baffle of amana washer
You need to do whatever it takes to remove the coin, no easy answer here.
Aug 21, 2017 | Amana Washing Machines
My washer won't spin. There is a coin stuck inside
If the coin is in between the 2 drums but is free floating you amy be able to get it by removing th bottom drain hose from the drum but this can become a pain unless you are lucky as the coin will move with the machine tipped over. the other way is to remove the heating element while the machine is upright and use a stick or a grabber to get it out.
Dec 30, 2012 | Washing Machines
Speed Queen Front Load Coin operated # SWFT71.. The coin changer keeps getting stuck. Any ideas on how to resolve this?? How do I remove the coin changer from inside the machine??
I have not fixed any of these front loaders for a while, but the top cover should come off (usually with a key), which will give you access to the coin mechanism and timer. There you usually need a 5/16 wrench or a flat screwdriver to remove the screw at the top of the mechanism.
Dec 04, 2012 | Speed Queen SWFT71 27" Coin Operated...
Speed queen commercial dryer model sdg109wf, the coin compartment is stuck because of compartment was full, after emptying the coin slider doesn't come out so we cant use the dryer. what is the...
Oh your bringing me back to the early days of my appliance repair career when i only serviced coin operated washers and dryers. Not in the coin box but the cover on top where you would get access to the timer is a bolt that holds the coin slide to the coin box asm. remove that bolt(if i remeber from 25 years ago its a 5/16th inch hex head and brass colored) and the coin slide will come out and then gotta kinda genlty presuade it in with a hammer so the coin will drop through or pull on the handle ya would push, to free it up and remove stuck coin
Aug 20, 2011 | Dryers
How do I get change out of the washer? It went
I think you are talking about the three tub baffles that are attached to the inner tub. You can remove the baffles, usually one or two screws hold these into the tub. If it only has one screw then the opposite end is clipped into the tub. Most coins however get flushed down into the drain pump filter. We call this a coin catcher as that is what it is designed to do. Remove the front bottom panel, 3 to 4 screws on the bottom. Put a towel down under the pump to catch about a half gallon of water. There is a large round plastic screw that you unscrew from the pump assembly. The screw is three to 4 inches in diameter and almost dead center on the bottom front of the washer. Once you have unscrewed the unit, pull it out and clean out everything you see. Look inside and make sure there is nothing in the hose or the pump inlet hole. Reinstall and test for leaks before you put the panel back on. I recommend you clean this out every 6 months. Good Luck,
Appliance Specialists
Dec 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer- coin removal
Hi, The coin is probably inside the baffle that tosses the clothes around. I believe this nodel has a screw that holds the baffle in place. I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 28, 2009 | GE WSXH208A Front Load Washer
Coin stuck in front loader washer
GO TO www.repairclinic.com IN THE BRANDS WINDOW CLICK ELECTROLUX THEN IN APPLIANCE TYPE CLICK WASHING MACHINE AND LOOK FOR PART 1154917 CLICK ON THAT PHOTO AND LOOK AT ADDITIONAL PICS.YOU WILL SEE THAT IT SNAPS INTO PLACE. FROM HERE I THINK YOU CAN TAKE IT OUT AND RETIEVE YOUR COIN. GOOD LUCK
Apr 24, 2009 | Electrolux AWF1235 Front Load Washer
STUCK CD CHANGER
A coin has fallen down inside the unit. If you unbolt it from the arm rest and turn it upside down,the coin may fallout. I had to take my apart and physical remove the lodged coin.
Jan 10, 2009 | 2000 Lincoln Continental
SOMETHING stuck inside the dryer body - something like a coin... let me knwo
ok here is the best way to describe it you will need to get around the back there are two torks screws remove them and slide the top panel back to you ..OH I FORGOT unplug the machine first !!!....Ok now with the top off you will see the drum.. slowly hand rotate it until you see some screws that are lined up with the baffles inside the drum You will need to remove just a few screws on one side (the baffle that has the coins) dont take them all out or the baffle will fall inside the drum and it will be a pain to get back on9u will need 2 people) and that should do it you will need to rotate the drum around until the correct baffle ...ie ..the one with the coins in on top at the 12 o'clock position.. let me know if this works our for you
Feb 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
206 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
