Question about HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355
Need an updated software for the scanner. Scanner non functioal.
  • BENAM Feb 29, 2008
    I don't understand how to get the scanner update software . Where is it and How do I download it?
    Genius:
  • 3,587 Answers
Www.hp.com has some answers for that situation. go to support drivers
enter model number and operating system
voila..
check your computer warranty here FREE
Posted on Feb 24, 2008
  • Patrick Michaels
    Patrick Michaels Mar 01, 2008
    thanks for the Fixya and the confidence vote.
Scanner locked
Wrong software for system or else transit fixture is still in place.
Check for the current software on your operating system version. Plug in the scanner and do a software update. t should find the scanner and check for version updates. The scanning lamp will not move if the software is incorrect. There is no 'test lamp travel' mode either.
Nov 23, 2013 | Lexmark Interpret S405 - multifunction ...
Updated to Windows Vista and now the Dell 922 AIO scanner won't work
I assume the old computer was not Vista
This site has the vista 32bit driver
for Dell 922 AIO http://www.techspot.com/drivers/driver/file/information/8761/
Nov 21, 2007 | Dell 922 All-In-One InkJet Printer
Scan picture - Message: Sorry scanner could not be initialized. (Scanner Not Found)
There are several possibilities. Did you launch the scan from the computer or the scanner buttons? Stop at the point that works in these various trouble-shooting options.
1) Make sure that the HP Digital Imaging Monitor monitoring program was running if launching from the scanner. (Make sure the HP driver is installed not the generic OS driver.) The software is available from http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1146331& select your OS and then press Next. Click on Driver to download.
2) The scanner requires bidirectional communication with the computer. Try a new data cable and a direct connection (if you use a USB hub or print server). Try a different USB port and make sure that the ports aren't disabled for security or power-savings. (The first is in the Device Manager; the second is part of the advanced settings of the Screen Saver.)
3) Use the HP Director or Solution Center to check the scanner status (this is in the full-software form HP). If it is available for your OS, you should uninstall the generic OS driver and disconnect the data cable before installling the software. Even if you have this installed, check if you need to patch the software.
4) Download and run the HP Scan Diagnostic Tool to test the scanner. http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-926&h_lang=en&h_client=s-h-e016-1&h_keyword=dg-SDU&jumpid=ex_r4155/hho/ipg/ccdoc/scan_diag/ .
5) Can you acquire scans from the computer with non-HP software? Windows XP, Vista and 7 can acquire scans from Paint (File > Import from Scanner or Camera). Vista and Win7 also have Windows Fax and Scan (New Scan).
6) Disconnect the data cable from the computer. Then Start > Run > regedit . This launches the registry editor (Run as Administrator for Vista or Win7). Back up the entire registry first (File > Export, follow the steps you see and select all.) Locate the HP registry item: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\ {6BDD1FC6-810F-11D0-BEC7-08002BE2092F} and highlight the section in brackets. Right click on Lower Filters (string value) and delete it. Close regedit (Save changes) and restart the computer. Reconnect the data cable after the reboot.
7) Uninstall and reinstall the HP software driver (again remove the data cable after the uninstall and keep it unplugged until the software requests connecting the cable).
8) Check if you need to update the BIOS or USB drivers for your computer (see the manufacturer's site) and Windows Update.
9) Check if the scanner runs if connected (after software install) on another computer. If it doesn't work on another computer, you probably need to replace the unit.
I hope this helps.
Oct 08, 2010 | HP Photosmart C3180 All-In-One InkJet...
Lexmark X2650 scanner in Mac OSX 10.6.2 (Snow Leopard)
You need to update your driver by getting the latest software in the Lexmark website here. During software update what usually gets updated are the basic functionalities. In this case it looks like the scanner is not being updated as well. Hope this helps.
Mar 16, 2010 | Lexmark X2650 All-In-One InkJet Printer
Scanner
Questo spesso succede quando colleghi la stampante prima di aver installato il software, o quando non installi tutto il software.
Devi installare tutto il software presente sul disco, controlla anche il cavo usb, un cavo usb difettoso puo far funzionare la stampante e non lo scanner.
Se non funziona, fai un system restore (recupero del sistema? non mi ricordo come si chiama in Italiano.
Dicevo fai un system restore da Avvio>>programmi>>accessori>>utilita di sistema...
Questa procedura riportera' il computer come stava prima che Windows installasse automaticamente i driver per la stampante.
Dopo il system restore installa tutto il software sul disco della stampante SENZA collegare la stampante finche' esplicitamente richiesto dal programma di installazione.
Se non hai il disco devi scaricare i programmi dal sito Lexmark, che pero e' in inglese, o chiedere una copia del disco al rivenditore.
Qui c'e' il sito web della Lexmark : Official Lexmark Drivers and Software
In bocca al lupo.
Nov 20, 2008 | Lexmark X2500 All-In-One Printer
Won't scan pictures/documents, etc.
This is a strange one- and the following may not help;
- Open the Control Panel, then Scanners and Cameras - Delete the listing (if present) for the HP
Leave the scanner 'on' and reboot the PC.
If the weather is right, Windows may (should) find a 'new device' and reinstall the driver for the scanner. If that fails to cure the problem, either reinstall the HP scanner software or download updated software from the HP website (good luck with that - it's a nightmare getting what you need).
Oct 08, 2008 | HP Scanjet 4370
Update driver for the scaner with win xp
The driver on the link below is reported to work with this scanner on Windows XP. You will need to register (free) on the site to download: http://www.scanner-drivers.com/drivers/120/120718.htm Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 12, 2007 | AcerScan 320P Flatbed Scanner
Printer not printing items copied from canon scanner D1250U2F
Connecting a non HP scanner[Canon] to the printer may be a software mod on the printer so that it will only work with HP devices. The only way round that if this is the case is to work through a third party software[image editor]
May 21, 2007 | HP Photosmart 8250 InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
131 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
