Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA Scenium HD52W140
My RCA Scenium HD52W140 turns on but when i try to hook up anything from vcr to dvd nothing will work i get sound but no pic for like 2 secs and the it just says weak signal ive tried (air) cable (coaxel) Auidovideo cables nothing same thing happens what happens is the sound comes on with no pic 4 2 secs and goes back 2 weak signal plz if you have any solution let me know
ilovedaysha1@hotmail.com
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
I cannot think of anything easy that would cause the symtoms you are describing. Your power supply is working and the deflection bd is good because you have HV. The problem is signal related and all of this circuitry is on the SSB or small signal bd. The difficult thing is when replacing this bd. you must have RCA's chipper check to download all of the ssb eeprom settings so they can be uploaded to the new ssb. I'm affraid you will need a qualifier RCA service tech for this problem.
Posted on Feb 24, 2008
Try to hook up ps3, great pic no sound on tv or receiver tv is 7 yr old rca 50 inch scenium. i have tried to hook this up 20 different ways , no sound. is there something in the tv menu that needs to be...
Tries the PS3 with another tv?Make sure is not the PS3.Tries go into the tv menu to do tv audio resetting,so it can go back to factory setting,see if that make the PS3 it responses.
Jan 23, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
VIDEO 1 AND VIDEO 2 DON'T WORK WITH SATELLITE. VHF WORKS BUT NO SOUND
First of all check if theSatellite box or the RCA cable is working ok with other equipment/TV if they both r working fine then their is an internal problem with ur TV.Show it to a authorised service person.
Jun 01, 2009 | Televison & Video
DV1130 hooked up to TV, DVD works great. VHS has
If you are using RCA cables (Red Yellow White) the video (yellow) could be bad or not in the connector all the way. When the VCR mode is selected try pulling the yellow connector out then back in and see if anything changes on the tv.
If you are using another type cable let me know and I will help you diagnose.
Hope this helps
TankMurdock
Apr 25, 2009 | GoVideo DV1130 DVD Player/VCR
Have sound no pic. on 52 inch.
if you have some thin lines on the top of the picture probably you have a problem on the power supply for the convergence
Sep 29, 2008 | RCA Scenium D40W20 40" Rear Projection...
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
I need help with my tv and dvd/vcr combo
Hmmmm...I dont understand exactly what you are saying, but it sounds like your TV doesnt have RCA ports and you want to hook up a newer DVD player that uses RCA ports. If you have only a cable port (silver threads with a hole sticking out of back) on TV and RCA ports on DVD player, you have to buy a converter. You can get one at Wal-Mart for 20-30 dollars. Or you can just update your TV which it sounds like you badly need to do! :)
Dec 24, 2007 | Sanyo DVW-7200 DVD/VCR
Rca scenium 52 inch replacement screen
I`ll have to be the bearer of bad news, the image is not burned onto the screen it is burned into all 3 of your picture tubes, which basically means the set is junk because the cost is too high.
Nov 29, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
I have a rca hd52w140
Does the unit show a flashing led on front panel. make any sounds. reset this tv if it works invloves unpluging the set for 30 minites.
Oct 16, 2007 | RCA HD52W140 52" Rear Projection...
Weak Signal ..
Sounds like you have a bad tuner. The most likely cause on these RCA's is a loose RF antenna input connector. A bypass for now is if you have a VCR use it as the tuner and then connect it to the TV using the composite video inputs. If that faisl as well then you have a bad signal board.
Feb 12, 2007 | RCA HD52W140 52" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
153 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
