Question about Jenn-Air JCB2280HES Side by Side Refrigerator
Fridge wont get cold and freezer gets cold then gets warm
Noticed freezer wasn't keeping ice cream solid. Checked temp and discovered both freezer and fridge were warm. Milk spoiled overnight. Freezer had alot of frost so unloaded the unit and let it thaw out. Restarted and temps seemed fine then it did the same thing all over. Repeated again and the same thing.
Checked the seals doubled checked level. This refigerator is 2 months old. WTF?
I see no defrost water catch in the manual. The frost in the freezer is indicative of a bad seal or the door not closing all the way.
What you think?
  • MAUREENN Apr 11, 2008
    yes freezer actually had snow it it, now fridge will not get cold warm. Jenn air not the best product for what you pay.
I Had The Same Problem , Went To partselect.com  You Will Find A Solution And Reasonable Priced Repair Parts There
Posted on Apr 18, 2008
Sounds like to me you have a defrost issue. If your fridge is only 2 months old don't sweat it and call out a Whirlpool warrenty certified tech. to fix the problem. And sorry to say age does not matter with fridges any more. The good ole days of fridges lasting 20 years is over now it's 12 years if your lucky.
Posted on Feb 25, 2008
We first noticed the freezer in our 4 yr old Frigidaire Refrigerator with top freezer (Model FRT18HP7DB7) was failing when ice cream was not freezing. We cleaned the dust off the condenser, checked the...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 22, 2011 | Frigidaire FRS23KF7AB Side by Side...
Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Apr 18, 2010 | Maytag MFD2560HES Bottom Freezer French...
Freezer is no longer keeping ice cream solid/frozen
Ice cream is usually kept at -10 degrees to stay firm. Need to check temperature. Look at condenser coil for cleaning. This is usually the most simple and common issue. If not making the desired temp, and the temperature control is set for that temp, and compressor run constant, it is a refrigeration issue. If compressor does not run constant, then a control issue.
Jan 24, 2018 | True GDM-49FC Refrigerator Commercial
Freezer too cold--refrigerator too warm
If the cold control is not adjusting the temp when you move it, that can be part of the problem.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Kenmore side by side purchased in 1/2002. The freezer section keeps melting and then refreezing again. The ice creams melts then hardens up again. Please assist with what the problem may be. We...
It may be the defrost thermostat...
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
Sep 21, 2009 | Refrigerators
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Freezer not freezing ice cream and milk
Icecream is a tough call. Some brands have to many artaficial ingredients and that doesnt get solid. What temps are you getting in the freezer? Is everything else frozen solid?
Jul 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
What temp should the fridge and freezer each be?
According to FDA safetey specs bacteria can grow at 40 to 140 F degrees .Refrigeration must be below this number but above 32F to keep from freezing. I maintain commercial refrigeration and they run at 34 to 38 F degrees. I have deep freeze set at -10F which keeps ice cream very solid but can go up to +2 F which renders softer ice cream...
Jun 25, 2009 | Kenmore 64802 Top Freezer Refrigerator
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Jenn-Air JCB2280HES Side by Side Refrigerator Logo
531 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
