SanDisk Sansa Clip MP3 Player Logo
Posted on Feb 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I plugged my sansa into my computer to charge it and left it for the afternoon charging. Now the screen glows white and it won't shut off or show anything on the screen. What gives?
Anonymous
Level 3:
  • Master 2,418 Answers
  • Posted on Feb 13, 2010
Anonymous
Master
Level 3:
Answers
2418
Questions
0
Helped
812502
Points
6999
My laptop wont charge.when its running low at 10% i plug in my battery adapter it says its plugged in but not charging. I can only use it when my adapter is plugged in and i've left my computer sit shut...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
1helpful
I shut down the computer while charging my mp3
Try plugging in the USB connection again. If that doesn't work, unplug it and then press and hold the on button for ten seconds.
3helpful
Can I use my Sandisk Sansa C240 while it is charging?
This is normal when the Sansa is connected to a computer. You can use it while charging if you connect it to something else. For example, you might have a cell phone with a USB charger that plugs into a wall outlet. You could connect the Sansa to it, and it would let you listen while charging.
I have a Sansa E250R MP3 player. I had the unit
some where on the device it should hve a reset button that you have to press with a pin or somthing try that
Won t charge
Download Motorola Phone tools and get a new battery for your phone.
The batteries go bad about once a year, sometimes longer.
if this helps you please leave a vote on fixya
2answers
Low battery
In this case wat u can do is on the Mp3 player itself u will see a slide switch which will say Hold/Unhold or Lock/Unlock............ Just make sure it is not Locked or On Hold and then try to charge it............. Will Work Fine.......... Goo Luck
Sansa crashed have white screen
I have a e250 also and it white screened. I could'nt shut it off. I just left it on overnight and 1/2 of the next day until the battery went dead. Then pluged it in. It Worked!!!!
Older e200 models...
Substitute REC for volume +
Sansa cant be detected by computer
i had the same problem with mine and my computer didn't detected it so try plugging it in and out a few time it might work.but if that doesn't work go on settings and change the usb setting
My Sansa E260's screen is white and it won't turn off
After leaving it on all night and running the battery down I plugged it back in, it charged and everything is working fine. The morale of this story is, don't unplug it from the computer while it is in use.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
