Question about Whirlpool LGR7646E Dryer
Gas dry turns on wont ignite
Dryer turns on but wont ignite. any suggestions?
  • Anonymous Feb 29, 2008
    Have gas pressure at the valve, doesn't ignite. Is the "glow coil" ignitor at fault?
  • 943 Answers
Hi thanks for the question. Most times a failure to ignite the igniter is caused by the thermal fuse located at the back, on the air duct . to repair, pull away from wall . remove back panel. clean all dirt , clean venting .the fuse is on the left, on the air vent, a small piece of plastic with 2 blue wires to it. replace thermal fuse. thanks the appliance doc
Posted on Oct 06, 2008
Tumbles but does not dry
When you put your wet cloths in the dryer close the door. You should then turn on the dry cycle you wish, not the fluff option as there will be only air and gas dryer will not heat the cloths. Wait 30 ~ seconds after the dryer is turned on and listen for the gas to ignite and begin warming and drying the cloths. If you hear no bump sound like the ignition of the gas, then you have an ignition issue. It will require replacing the ignitor. All the best and good luck. Hope this helped.
Oct 02, 2012 | Maytag Neptune MDG5500AW Gas Dryer
Dryer wont dry, blows cold air
Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty. I hope this helps. If it does, please let Fixya know by rating my solution. Good luck!
Nov 28, 2010 | Whirlpool LGR5636L Gas Dryer
My ge dryer wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
Jul 08, 2010 | GE DWSR483GB Gas Dryer
Gas dryer lites then does not dry cloths
You just need to replace the gas solenoids:
Jun 15, 2010 | GE Dryers
Maytag gas dryer wont turn off when done drying in auto dry regular fabrics. does turn off in air fluff and auto dry perm. press. model # d3382
auto dry relies on a moisture sensor to say when its done. so your clothes arent dry enough according to sensor. perm. press. doesnt dry the clothes as much
Aug 01, 2009 | Dryers
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool gas dryer motor wont turn over
If the drum is not turning, then the belt may have broken and could be (because of the noise I think your describing, partially wrapped around the motor pulley.
Modern gas dryers do not have standing pilot lights. They are electronic ignition.
Chances are, you solve the belt problem, you'll solve the (I guess your having) heat problem.
Please respond with more detail of the problems you are having, and advise if the belt is broken.
Jan 18, 2009 | Whirlpool GGQ8831L Gas Dryer
Whrilpool gas dryer
Apr 22, 2008 | Dryers
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Dryers Logo
71 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
