Question about Lexmark X5470 All-In-One InkJet Printer
LexMark 5400 Series All-In-One Printer
When the paper gets fed into the printer (I am only putting in one sheet), it gets jammed inside and does not move through. This is a new printer and it's only been used a few times.
    Scholar:
  • 110 Answers
Please make sure your paper isn't the wrong type, some printers are picky and if it's inkjet, using laser-type paper can cause jams easily.
Posted on Feb 24, 2008
    Genius:
  • 1,019 Answers
try putting several sheets in at a time, they,ll hold 30-50 or more.
Your printer sensors detect paperweight.
Also check to see if theres a paper thickness adjuster anywhere.
Refer to documentation.
mike @ compurepair.
    Genius:
  • 3,422 Answers
To clear a paper jam:
  • Pull Carefully
    If the sheet of paper is visible at the output slot of the printer (in other word, it stopped on its way out of the printer), try pulling carefully on it. If it pulls smoothly and easily, then carefully pull it the rest of the way out. If there is resistance, then stop and go on to the next step.
  • Open the Cover
    Open the printer cover and wait (in the case of an inkjet printer) for the carriage to stop moving. Carefully, slowly pull out any paper that is caught there.
  • Take Care
    Do NOT pull paper out from where it was feeding into the printer (where the blank paper enters the device). The rollers on your printer may only go in one direction, and if you force them the wrong way, you could damage the machine.
Be careful of the following:
  • Laser Printers
    If you have a laser printer, be very careful when pulling out the paper -- laser printers can get hot.
  • Paper Shreds
    If any paper tore, either during the jam or while you were removing them, remove any appliances that you can (paper trays, etc.) and look for the shreds of paper. Try to make sure nothing has been left behind.
If you have frequent paper jams:
  • Don't Overload
    Overloading your paper tray can cause paper jams. Your manual may say that your input tray can hold 250 sheets -- but if you keep getting jams, try loading 225 sheets instead.
  • Check the Paper
    Check the minimum/maximum paper weights that your printer can handle. Paper that is too thick, or too thin, can cause jams.
Goodluck..
  • Priya darshan Feb 24, 2008
    Click HERE for more step by step instructions with the diagrams to fix your problem..
Keeps saying paper jam,but no paper jam is inside
The jam indication is set because the sensor(s) detect one. This could be due to a buildup of paper dust, a small bit of a sheet that tore off and got lodged deep inside when removing a previous jam, or damage to the sensors if the jam was removed forcibly by pulling the sheets out from the wrong direction.
Dec 10, 2015 | Brother DCP-7020 All-In-One Laser Printer
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
How do i set it to print 11x17. It jams everytime and will not print to that size
Hello :-)
Please open the paper supply tray you wish to use. At the very front of the tray, to the right, you will see a blue dial. This dial is used to tell the copier what size paper it can expect to be fed. You can put many sizes of paper in the tray, but the blue dial MUST match the size that truly is in the tray. If ,for example, the blue dial is set at "LETTER" but the paper in the tray is 11x17, the copier will look at the dial setting and expect the paper to have passed its paper path sensors in a certain amount of time. So if the dial says 8.5x11 and the actual sheet of paper fed just keeps on moving by the sensors (11x17) the copier freaks and treats it as a paper jam assuming it has fed multiple sheets. Happy New Year to you and yours! :-)
Jan 19, 2011 | Canon ImageRunner 3025 Black and White...
Paper jammed
Hi Good day!!!
Here are some steps to remove paper jam
1. Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands on the metal tools inside the chassis.
2. Pin down the exact location of the jam. The three hot spots for a jam are before a sheet completely leaves the paper tray, between the feed tray and the print carriage or between the print carriage and the output tray.
3. Take off the front paper tray. If the sheet jammed around here, you should be able to see most of the paper.
4. Pull on the sheet with both hands and steady pressure. Don't tug too quickly. You might rip the paper, leaving a chunk of it deeper in the machine.
5. Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Use the carriage access door to get at a jam further inside. You may need to move the print carriage out of your way to get at the jam.
7. Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 05, 2010 | Epson WorkForce 600 All-In-One InkJet...
Paper is jammed
Firts remove the back panel by turning the large knowb in the center. Then if more than 2 pages are stuck inside "gently" pull on all the sheets except the top and bottom ones. They should pull out with moderate resistance. Once thos sheets are ou do the same thing with the remaining two sheets.
NOTE: when a printer is powered on with paper already in the paper path it will usually try to eject them by turning its rollers.
NOTE: some older HP DeskJets when you press the paper feed button (with paper already in printer) it will move the paper in one direction and when you press again it will move the paper in the opposite direction.
Apr 14, 2010 | HP DeskJet 845c Printer
HP PSC 1210xi does not accept paper from the paper tray.
Remove IE8. Use add / remove programs. It will put you back to IE7 and your printer problem will most likely be gone.
Aug 05, 2009 | HP Office Equipment & Supplies
Lexmark T640 won't print on label sheet a SECOND time...
try changing feed rollers. For a quick fix, remove the rubber rollers and flip them inside out. It should work
Jan 28, 2009 | Lexmark T640 Laser Printer
Cannot print
If this is a 2200dtn, have you checked the duplex turn around tray under the printer? You can access this by removing tray 2, inside on the front left you should see a small green tab which will release a drop down tray. Many times a sheet or even just a piece of paper can get lodged in the sensor causing a paper jam condition.
Nov 21, 2008 | HP LaserJet 2200dtn Printer
Paper Jam Errors
switch off power to printer and switch on again, worked for me
Jan 14, 2008 | Dell 3100cn Laser Printer
Automatic Paper feed
Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
Sep 06, 2007 | Samsung ML 1210 Laser Printer
Lexmark X5470 All-In-One InkJet Printer Logo
236 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
