Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow d4c My rainbow d4c just quit running. Sounds like the motor. What is an easy way to troubleshoot at home?
    President:
  • 1,673 Answers
If it just quit running, it could be the cord. If you have a meter, you can check it to make sure it isn't broke. Take out the 4 I think, screw from the bottom, the top half should come off, then you get to the switch and the end of the cord. Check the motor brushes also, if they are worn down, they may not be conducting and the motor won't run. It gets involved, so don't know if you want to do this at home.
Posted on Mar 03, 2008
Mine quit because a resister overheated and fell out
Posted on Mar 15, 2008
Will D4c se plug into D4c
The Rainbow D4, D4C and SE all are the same vacuum base, only changes were made to the nozzle. As long as the nozzle cord on your D4 has 2 prongs, not 3 prongs you can use the D4 nozzle that looks like This or the SE PE (SE Performance) Nozzle that looks This
Sep 01, 2014 | Rainbow Vacuums
Why is my rainbow d4c kicking out so much dust?
Do you have the water level set right? Is there an elbow missing inside the tank?
Jul 27, 2014 | Rainbow Generic D4c And D4ce Fan Assembly....
I smelled something burning one day , but i kept using my d4c, now the motor part does not run but the top plug in will run
I work on Rainbows. D4C-E2 etc. Not sure what you mean by the top plug in. There are two motors in the rainbow, one in the main unit, one in the power head. Where was the odor coming from? email me back with more info, I can help you with this. Jerry
Nov 06, 2010 | Rainbow E series Canister Wet/Dry Vacuum
There was a foam piece above the motor of my rainbow d4c power nozzle. When I took the plate off it desintigrated and fell off. Was that supposed to be there? If so how do I find a replacement?
Hi, the only way to replace that, is go to home depot, or where ever, and buy some window seal foam, or door seal foam or what ever type, that matches your foam best, and put it on your self. You could also send it to me, and I will do it for you. I am a Rainbow seller and a Rainbow expert.
I use foam that is the soft kind, that is like the original Rainbow foam on them, and is about 1 inch wide, and about 3/8 to 1/2 inch thick.
It is self adhesive on the back side of it, that you peel off the paper cover off of it to stick it on.
If you have any more questions, let me know.
Thank you,
Ralph
May 21, 2010 | Rainbow 75th Anniversary Canister Vacuum
What's the difference between the rainbow D4C SE and the D4C?
the se has a newer updated version of the power nozzle. the power nozzle is smaller.the d4c is older
than the se. the attachments are pretty much the same and the se is a darker color than the
d4c
Jul 01, 2009 | Rainbow 75th Anniversary Canister Vacuum
Vacuum was used to clean up after plaster sanding.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=645474
Generic problem for all Vacuums
Posted by veronica1113 on Jun 04, 2008
Could the debris from plaster sanding cause my rainbow series D4C vacuum not to work? If so how is the best way to clean it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Rainbow D4C will still work but not @ the highest efficiency rating – the suction will be reduced because the sheetrock dust gets into the motor and the fan blade(s) Quan 3 and would need a professional cleaning 1st or 2nd. Replacement of the motor; if it is too serious and or too expensive. It’s a good vacuum back it is suggested that people use a good Shop Vac for the sheetrock dust removal. Feel free to contact your local vacuum cleaner dealer in your area or you can try to repair and change out the fans, clean out the carbon brush area and cleanup the armature. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 04, 2008 | Vacuums
Rainbow D4C power switch replacement
As far as I know, that switch with 6 terminals is still available. But if not, I would wire the 2 for the power head and the 2 motor wires together. Then you would have 4 leads to attach.
Jan 31, 2008 | Rainbow 75th Anniversary Canister Vacuum
Open Questions:
See all Rainbow E series Canister Wet/Dry Vacuum Questions
Rainbow E series Canister Wet/Dry Vacuum Logo
439 people viewed this question
Top Rainbow Vacuums Experts
Doris Wittkamm
Level 1 Expert
Jim Parker
Jim Parker
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
