Question about Car Audio & Video
JVC KD-PDR30 remote switch wire
The remote switch wire stays hot all the time.  Ignition on, ignition off, radio on, radio off.  This keeps my amp on all the time and runsdown the battery.
  • hugh24 Feb 25, 2008
    as I suspected.  thanks for the tip (i.e. ignition switch).
  • 199 Answers
Hi sounds like theunit is faulty, you will need to have the unit repaired, or have the amp switched via the ignition this would be the cheapest option.
Regards
Mark
www.blueice-electronics.co.uk
Posted on Feb 25, 2008
Resets when I turn ignition off
The yellow wire on your radio needs to be connected to an always hot fuse or wire. It is hooked to one now that is connected through the ignition, which is why it won't keep settings.
Feb 17, 2014 | JVC KD-G120 CD Player
Jvc kd-hdr1
Most wiring now is standard colors....red=ignition(goes to a switched power source...Yellow=battery...goes to a hot all the time(even with key off)...black=ground...white=left front speaker positive...white w/blk stripe=left front speaker negative...gray=right front spkr +...gray/ blk=right front spkr - ...green=rear left +....green/blk rear left - ...violet=right rear +...violet/blk= right rear - ...light blue or blue with a stripe is the remote turn on lead either for an amplifier or power antenna...some radios have an orange/ with white stripe that connects to your parking light dimmer circuit to dim the radio light with the dash lights....and then you should have the antenna plug and possibly rca outputs that go to an external amp
Feb 26, 2012 | JVC KD-HDR1 CD Player
My radio wont power on but it turns on to eject and take Cd's but it will not turn on so i can listen to the radio
that sounds like the power is hooked up but the ignition (yellow wire i think) isnt hooked up right. this is what shuts off the radio when you take your key out.
Feb 03, 2010 | JVC KD-PDR30 CD Player
JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Jun 10, 2009 | JVC KD-G200 CD Player
JVC KD-PDR30 overheating
think the sub woofer my be drawing to much power try disconnecting the sub for a few days and see how it goes
May 21, 2009 | JVC KD-PDR30 CD Player
Trying to hook up a AMP
What I did to manualy turn on and off my amp is I put a wire hooked to the fuse followed by a switch and then from the switch ran it straight to the amp. Make sure that the wire plugged into the fuse is the on the fuse for the radio and that it is live only while key is turned on. I have this set up for police reason. They do not like loud music where I live. I have never had a problem with this set up. RADIO FUSE-------SWITCH----------------AMP
Mar 03, 2009 | JVC KD-PDR30 Car CD/ MP3 Player
Jvc kd-pdr30 ipod problems
The Touch will not work with the KDPDR30. I spoke with JVC and their models that will operate the Touch are KDPDR40, KDAPD49, KDPDR45, KDPDR41 and KDG47 the last two have a cable required.
Sep 01, 2007 | JVC KD-PDR30 CD Player
Power will not stay on
Sounds like you're not getting voltage on the accessory power lead. This is the red wire at the back of the deck, and it supplies power whenever the key is switched on. It's possible that your vehicle's radio fuse is blown.
Aug 11, 2007 | JVC KD-PDR30 CD Player
Car Audio & Video Logo
190 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
