Question about Roper REX4634KQ Electric Dryer
Roper dryer again
Is there a Need fuse location?
  • stephie77 Feb 24, 2008
    what I ment is were is the fuse location?
  • Anonymous Mar 25, 2014
    where is the fuse located?
    President:
  • Roper Master
  • 2,651 Answers
If its a thermal fuse located on rear bulkhead of dryer, youll find it by removing back cover of dryer, little white thermo,if bad there will be no continuity through it
Posted on Feb 25, 2008
My dryer will not turn on, there is current to electric plug.
The thermal fuse is located on the back side of the dryer. If you see lint built up that fuse can be melted. If it is melted then the motor won't run because that fuse is in the same circuit as the door switch. So if the fuse is good look for a bad door switch.
Roper dryer tuneup
Service manual and more
Sep 11, 2011 | Roper REX5635E Dryer
Roper Dryer # RED 4440, will not heat. Where are the fuses? What are other possible solutions.
The dryer will not heat then it is the thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset.
Hope this will help....
Dec 31, 2010 | Roper Dryers
Turns no heat continues to run? roper dryer model # red4340sq1
you need a Thermol fuse. This part is a non resetable fuse. you will need to replace it. it is located in the back of the dryer. you will need to take off the back panel. let me know if this helps
Oct 12, 2009 | Roper REX4634KQ Electric Dryer
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Roper dryer will not start it is electric
The thermal fuse is probably open again, This condition is caused by restricted air flow out the vent system. Replace thermal fuse again and clean the vent hose and vent hood outside
Jan 05, 2009 | Roper REX4634KQ Electric Dryer
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Not heating where is the model number located on roper dryers?
model #s are located on panel inside of door. check breakers, heater and thermal fuse always disconnct electrical power
Dec 13, 2008 | Roper REX4634KQ Electric Dryer
Roper dryer again
Hi here Is the thermal fuse located In the back Of the dryer On the air duct 00208689.jpg
Feb 24, 2008 | Roper REX3614KW Electric Dryer
Dryer won't start.
where is the thermal located
Nov 11, 2007 | Roper REX4634KQ Electric Dryer
Roper REX4634KQ Electric Dryer Logo
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
