Question about HP Photosmart 4180 All-in-One Printer
Can not get printer to print
If i want to print something I go to print and my printer will not print , everything is installed. I don't know what to do
  • 1 more comment
  • Anonymous Apr 04, 2008
    printer
    printer 4180 is conecter and wont print
    Genius:
  • 1,019 Answers
have you got the cable connected between Printer And Computer ?
or any on-screen error messages.
Check printers In My Computer/Control Panel to check the printing has not been Paused.
mike @ compurepair.
Posted on Feb 24, 2008
Will not print
try to restart your computer. before u print something, make sure u select the right printer (maybe there's copy 1, copy 2, and so on), check the usb cable, and don't turn on your printer before the laptop/pc ready because your computer will not able to detect the printer if you turn the printer first.
Jun 13, 2012 | HP Photosmart 4180 All-in-One Printer
How do i get my hp1200 printer to print, is on a off line mode
Hi Joy,
Disconnect the printer completely from the PC.Unplug its power cable too.
Reboot your PC.
Connect everything again from scratch but use a different USB port to connect to the PC.Make sure everything is well connected.Try printing now.Cant print?
Under printers and faxes,check whether 'work offline' is checked by right clicking on the printers icon and 'Uncheck.Still cant print?
Uninstall the printer driver on your PC,reboot the PC and install software again.If you don't have the installation disks,install from this Hp Support site making sure you select the driver that corresponds with your Operating System[Windows 7,Vista,Windows XP etc]
Hope this helps.Thanks!
Please rate this answer.
Dec 02, 2011 | Office Equipment & Supplies
My Operation system is Windwos Vista 64. Therefore I downloaded the driver MF4100_PrtDriverV200WinVista_x64_EN. After the driver had been installed. I connected my USB print to my computer. I tested...
This does not sound like driver based issue, but rather a printer issue. Did you go to the website of the printer manufacturer and use their install program for your OS? Not all printers will work with newer OS....and Plug and play should be avoided when installing printers, some stuff will not work correctly.
Jul 16, 2011 | Computers & Internet
I have the zebra lp 2844 i'm trying to print from ebay everything is working ecept when i print the label only two line print. i did a test page and it comes out fine i have calibrated the printer and...
Check that your printer setup software is "setup" correctly (AKA printer properties in "control panel" or "devices & printers").
Look at the "label size" and orientation (portrait or landscape) in the printer setup, that may be wrong and cutting off the rest of the printout. If you indicate more printer buffer size that what there is, that to might cause problems.
Other things to check for: Do you have the correct print driver for your OS?
Make sure you have the correct printer selected in Ebay. I don't use Ebay to print labels out with my thermal printer, but I use paypal and I believe they are very similar if not the same. Also, in paypal anyways, you have to have the correct run-time version of JAVA installed in order for it to work properly. Don't know about ebay, but that might be something to look into.
Jun 15, 2011 | Zebra LP 2844 Thermal Printer
Im having a serious issue tring to get my kyocera fs-c5030n to print. I try to print, and it doesnt prompt for a password, but all that comes out if the printer is invalid account id everything I try to...
1. Click Start > Printers and Faxes
2. Right click the Kyocera printer and select properties
3. Select the "Device Settings" tab
4. Click "User"
5. Enter your User Name and Department Code
6. Click OK, OK
If you don't know the User Name and Department Code, these can be programmed by using the "KMNet Viewer" software utility, you can download it from here:
http://www.kyocerasupport.co.uk/index/download_center.false.driver.FSC5025N._.EN.html#
May 04, 2011 | Kyocera FS-5025N Laser Printer
Why my printer keeps jamming
Does it print then jam and then print a few pages and jam again? If that is the case, you might want to check your paper. It could just be that you have to "fan" the pages before inserting them into the tray. Also, try not to "rush" the printing process if you are doing envelopes...that will sometimes jam the printer and cause everything to go out of sync. Have you turned off the printer and restarted the computer. That resets things also.
Please take care to check for any remnants inside the roller area. If you have jammed the printer and then torn the sheet to get it out, a part of that could be inside. If that is the case, I would suggest that you UNPLUG the unit before trying to look inside and remove anything. Safety first, don't let yourself get frustrated and then do something silly and get hurt.
If those ideas don't help, try re-installing the printer. Just name the installation something else so that you will know which one to delete if you get it working properly.
Apr 08, 2011 | Office Equipment & Supplies
The type of print head is incorrect, please install the correct print head
patchiepoops,
make sure everything clicks. canon is known for their ''slide and click fittings''
don von gideonberg
May 28, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My wGPS606 wont print on my Windows Vista laptop!
I just found a way to enable the HP P1006 with a different print server (Liveprint on Orange Livebox router). Perhaps this might work with the WGPS606 wireless print server?
I set up the P1006 via the print server as instructed (I'm using Vista 32 Home Premium) but no test page would print.
BUT!! (with thanks to another another forum):
I selected printers, then right-clicked on the wireless printer I'd just installed and selected 'properties'.
Under the 'Ports' tab I deselected 'Enable bidirectional support'.
Problem solved.
Hope this helps.
let me inform you that this printer is not compatible with any wireless print server. The drawback is that it is not possible to network such printers. A printer needs a steady flow of data, which is easily accomplished when it is connected directly to a PC, but cannot be guaranteed when the printer is connected via a LAN. Also, these technologies require intensive handshaking between the driver and the printer.
The host-based software uses the computer's resources to process print commands and rasterizing data, taking advantage of the computer's memory and processing power."
Sorry I can't be more upbeat - but its probably useful to know that someone at HP thinks the job's imposible - unless someone out there has a fix?
May 11, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
HELP!
those are blown drivers..
you'll need to uninstall them
go to www.hp.com for new ones for your model and operating system
re install
try it again
Aug 09, 2008 | HP DeskJet 940c InkJet Printer
Lexmark 1200 series
Does it power on? How is it connected to your computer? Did you install the drivers for it?
Sep 07, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
HP Photosmart 4180 All-in-One Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
