Question about Microsoft Xbox 360 Console
The thermal paste?
Hey, I was wondering if i should use the ArctiClean THERMAL GREASE REMOVER & PURIFIER along with the Arctic Silver 5 Premium Silver Polysynthetic Thermal Compound 3.5 Gram Tube
or if you know of a cheaper place to get it let me know please
  • leeroi89 Feb 24, 2008
    okay thanks Mike.
    Genius:
  • 1,019 Answers
hey buddy you can do, but the grease removers an un-necessary item. this stuff will wipe off with a soft cloth.
or at worst, a very blunt plastic scraper.
you only need the tinyist amount of thermal paste.
I,d Suggest ( E-Bay )
mike.
Posted on Feb 24, 2008
  • Mike Waldron Feb 25, 2008
    Hi leeroi,
    i,m off here soon buddy.
    this rating system sucks.
    the more you try to help people, the more you get pesecuted, if they decide to not rank your advice too highly.
    My ratings getting lower and lower every day.
    i,ll only be on here from now on to help buddies out by request.
    Mike @ Compurepair.
Tip
To simplify what this guy is saying. I recommend getting new thermal compound...
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A135) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
on Oct 17, 2008 | Toshiba Satellite A135-S2276 Notebook
Computer problem
BYY A VERY EXPENSIVE COOLER and some very good thermal paste suck as arctic silver 5.
run the pc with the case side off
clear all the dust out of your PC
Make sure the interior of the case is uncluttered and airflow is unobstructed
Jan 12, 2014 | Intel Computers & Internet
My hp dv9008nr windows xp turns on hard drive moves along with the fan but it won't boot up. It shut down in the middle of me trying to recover the microsoft ware. I just replaced the screen and it worked...
EDIT:
the problem is the nVidia GPU. it often overheats. there was a recall for this computer a while back. the recall has ended, but just so you know, you need to find a way to better cool the GPU. a copper shim between the GPU and the
heat-sink will do wonders for you. apply Arctic Silver Thermal Epoxy to the shim and attach it to the heatsink. then, you need to use arctic silver 5 thermal paste on the GPU (about .2 grams should cover it) and reattach the heatsink to the board. while you are at it, replace the CPU thermal **** with the as5 thermal paste. my GPU is running now between 58 and 66 C. its really high still, yes, but the computer will not longer shut down because of overheat. get a laptop cooler for this thing too. it will not survive a hot summer day. i am absolutely positive.
Feb 22, 2011 | HP Pavilion dv9008nr Notebook
Hi, I have motherboard gigabyte GA-8I945GZME-RH, why the cpu temperature over heating? although I change my cooling fan. Thanks
the temperature show in windows is not right sometimes. enter cmos setup by press del(or f2) open system helth to see the right cpu temperature and voltage. still over heating? you need a better heatsink and don't feget use some heatsink compounds.
Oct 29, 2010 | Gigabyte GA-8I945GZME-RH Motherboard
What kind of thermal grease CPU I can use for replace old grease
Depends what you intend to do with your computer, if its lots of gaming, and pushing your pc to its limits, you will need a good quality thermal compound (arctic silver), if its just normal stuff a cheaper heat sink compound will do, i use Servisol, its cheap and works well
Jul 16, 2010 | Toshiba Satellite 2435-S255 Notebook
Thermal Paste
From the word itself it is a thermal paste that can hold the CPU and iot helps out to prevent the heat coming from the processor, when the cpu fan operate/spin it also that helps that processor to cool down.
You may try a toothpaste as a substitute for it you will need a "white base toothpaste" just put only a small amount into it.
Let me know for any clarification
Feb 06, 2010 | Spire STARS-420/2 White grease Thermal...
The same prob
hey there, first of all, just want to make sure you cleaned and reapplied thermal paste after removing heat sinks (arctic silver 5 the best). Next, do a deep CMOS clear (shorting out the pins on your mobo) followed by booting 4-5 times continuously while holding the INSERT key. This ought to get you back into your BIOS. Good luck, let me know if you need more help.
seth
Jun 19, 2009 | Abit AW9D-MAX Motherboard
Processor Overheating
It is important to use good quality thermal paste like Arctic Silver. You only need a very small amount on the heat sink. Too much is as bad as none at all. You care just trying to create a thin layer of thermal paste to fill in the tiny gaps between the processor and the heat sink. If this does not help an aftermarket heat sink with more fins and a better fan might be needed.
Mar 18, 2009 | Intel D865GVHZ Motherboard
CPU overheatsToshiba Satellite A105-S4134 need to replace system board and cpu
Open it u, blow it out really well with a can of compressed air.
Also I would reapply some thermal grease between the cpu and fan, like arctic silver 5. You should clean the old grease beforehand.
The Toshiba Satellite A100/A105 TECRA A7 Maintenance Manual is here.
Jan 12, 2009 | Computers & Internet
Microsoft Xbox 360 Console Logo
35 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
