Question about Holmes Products Cool Mist HM3500 Humidifier
Iron/rust in water
Our water has a very high level of iron & rust and it dirties/packs the filter very quickly. How can we avoid this? At the moment, we have to change the filter every week and it is very expensive.
  • 123 Answers
You can use distilled water to fill your humidifier that would save your filters.
Or you can try soaking your filter in a 50-50 water and white vinegar solution to try and clean them to use again.
Good Luck.
Posted on Apr 18, 2008
I have a 2 yr old dehumidifier and it runs, it just won't pull out the moisture out of the air.
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit
(No LED screen), set the humidity extraction knob on Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helped you and thanks for choosing FixYa
Sep 13, 2011 | Kenmore 938060 Humidifier
DEHUMIDIFIER IS RUNNING BUT NOT COLLECTING WATER
level
problem.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Jul 28, 2011 | Whirlpool AD25BBR 25 Pint Per Day...
Our Kenmore 50pt dehumidifer is less than 2 years old, only used for 1 summer, tried to use it last week, it starts/runs but does not withdraw any water, please help. Thanks kindly
There are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you unit is manual control,
turn the control knob to Maximum.
the unit without the filter. Filter should be cleaned once every 2 weeks.
level
problem.
I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 29, 2011 | Humidifiers
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Mar 25, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Filter lasting only about one week--"needle" almost on Red model SCM3502 cool most humidifier
If your water is well water, more than likely that's the problem. To many minerals and iron. Try cleaning the humidifier with a 50/50 solution of white vinegar and either bottled spring water or distilled water. Fill the tank about half way and run the humidifier until the tank is almost empty. You may want to do this outside in garage if possible, because of the vinegar odor. Then run a full tank of bottled Spring Water or Distilled water through it, to flush out any vinegar residue.
I would highly recommend, that if in fact you're using well water, stop using the well water and switch to bottled spring water or distilled water.
Hope this solves your problem. Please let me know.
Rich
Feb 07, 2011 | Sunbeam Humidifiers
Why does it discharge a white powder in the mist?
  • Sorry to read about your problem, I hope this helps you out.
  • you could say you have dirty water. Unplug the humidifier from the wall.
  • 2 Remove the existing water from the humidifier. Water contains several types of minerals, including iron and sodium, which cause the white powder when released into the air.
  • 3 Clean the humidifier according to the manufacturer's instructions. This may involve disassembling the unit and replacing the humidifier's filter.
  • 4 Pour demineralized or distilled water into the humidifier's tank. These liquids have a lower mineral content than tap water.
  • 5 Consider switching to a humidifier that comes equipped with a demineralizing filter, which removes the minerals found in tap water before they are dispersed into the air.
  • I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
    4 Thumbs - Very Helpful
    3 Thumbs - Helpful
    Dec 31, 2010 | Air-O-Swiss U7142 Humidifier
    I have old 78 series cast iron wet base . seral #780104 model#78--175. Iam looking for a wet pack.Not if that is right, but it's to line the fire box ?? MEGAMAN@ZOOMINTERNET.NET
    I just bought a wet pack for my 78 series from a local supplier.
    It is a Westwood No S70-45, wet sheet chamber liner. You cut it to fit then fire up the boiler and it sets up. The sheet measures 16'x48'. You can also get it online. Good luck
    Mar 20, 2009 | Slant Fin GF-210W 2 Gallon Humidifier
    Only light moisture even at high setting
    Link to Manual:
    http://www.crane-usa.com/manuals/HumidifierManual2008.pdf
    Filters can get dirty pretty quick with the use of tap water. I attached the manual for you so that you can clean it.
    Personally, i replace my humidifier filter at least once every 2 months.
    Good Luck.
    Mar 15, 2008 | Crane Frog EE-3191 1 Gallon Humidifier
    Produces a ton of white dust... Why???
    Your V5100N ultrasonic humidifier generates a fine mist by vibrating the water at an exremely high speed. The water doesn't actually evaporate until after the water mist is in the air. As the tiny water droplets evaporate in the air, the calcium and other minerals settle on your floors and furniture.
    Humidifiers that evaporate the water in a filter wick, or with heat, do not generate dust because the water evaporates inside the unit and the calcium is trapped inside.
    You can avoid the dust problem with your humidifier by using distilled water. Distilled water is available in most stores that sell bottled water in gallons...but be sure to choose "distilled" water, not "purified" water. Try the distilled water in your steam iron also...if you have one. It will last longer.
    Feb 29, 2008 | Vicks V5100N Humidifier
    Holmes Products Cool Mist HM3500 Humidifier Logo
    164 people viewed this question
    Top Holmes Products Humidifiers Experts
    cwradio73
    ray gallant
    Ben Eng
    Level 1 Expert
    Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
