Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
How to install front wheel assembly on Hoover Bagless windtunnel vaccuum
We cannot figure out where the spring fits back into the vaccuum and cannot find it in the manual.
Thanks
Diane Hedrick
    President:
  • 1,673 Answers
There is a spot that sticks up on the holder for the wheels, the hole in the spring goes there, then it fits between the holder and the base asm.How to install front wheel assembly on Hoover Bagl - 04f5295.jpg
Posted on Feb 29, 2008
How to remove the hoover windtunnel handle release lever
Tilt the handle back and pry it out with a flat blade screwdriver.
Jan 23, 2013 | Hoover U6630-900 WindTunnel Bagless...
I have a Hoover Windtunnel bagless self-propelled model #U6616-90. The vaccuum works fine, but the suction hose will hardly ****. There are no obstructions in the hose line. What could be wrong?
The only possible place where it could be clogged is where the hose goes into the motor if the hose is clear. Take the bottom off completely and use a flashlight and investigate. Hope this helped.
Jan 05, 2011 | Hoover U6630-900 WindTunnel Bagless...
Suction not working on vaccuum.
Check for a blockage in the hose, or a tear / hole in the hose between the "pleats"
Jun 13, 2010 | Hoover U5753-900 WindTunnel Bagless...
Need instructions to replace hoover U5757-900 belt
install the belt on the motor shaft first by sliding it sideways between the shaft and housing. then install on the brushroll and stretch in place
Mar 06, 2010 | Hoover U5750-900 WindTunnel Bagless...
How to install spring
on this machine the spring goes to the front wheel assembly under the machine. if this has came off then the wheel assembly is broken. i believe the part # is 36432027. hope this helps
Jul 27, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover Wind Tunnel bagless- issue with turning on
Have you tried to plug the vaccuum in another outlet that is on another breaker? It could be the vaccuum tripped the breaker. Turn the breaker back on. The manual mentions the thermal protector could have been activated. If this happened it resets and your vac should run after 30 minutes. I have a Widepath Tempo and it has tripped the surge protector. If this is the problem try turning some things off that are also on that breaker/outlet, or unplug them when you use the vac.
Jan 04, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover Windtunnel Bagless bolt fell off
With this self propell series, the entire bottom needs to come apart to re-install the nut. if it is one month old I would highly recommend taking it in for warranty service. What plastic is melted?
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Nov 02, 2008 | Hoover U6630-900 WindTunnel Bagless...
2 belts on hoover u6634-900
I realized that the fatter flat belt needed to b attached to the wheel shaft, to make it so the button to make the unit useable as a machine could be depressed. When that flatter belt was then attached it raised the small wheel i was trying to figure out how it was used was then raised and made the thinner belt fit properly.
Oct 02, 2008 | Hoover U6630-900 WindTunnel Bagless...
Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Oct 15, 2006 | Hoover U6630-900 WindTunnel Bagless...
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
1,200 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
