Question about Casio Sea-Pathfinder SPF40-1V Wrist Watch
CASIO SPF40 battery replacement
I replaced the batteries with 4 fresh ones but there is a note in the cover that states"After battery replacement contact AC with battery(+) using tweezers.".
What is this ,where is it and how do i do it.
  • luison Mar 30, 2008
    hi there, could you tell me how to replace the battery of my sea pathfinder? please tell me if i have to remove the back or the top cover?
  • tonygenchev Sep 24, 2008
    How to remove the back cover and replace the battery of my Casio Sea Path Finder?
"AC" means All Clear. This terminal should be marked somehow. Use a magnifying glass to get a good look at what you are working on. My Casio had an arrow pointing to four copper leads. I used a paper clip to connect the AC terminal (I just picked one of the four) to the + side (usually the "up" side) for a couple seconds and my Casio Sea Pathfinder model 2273 powered right up. See the following link for more guidance.
Posted on Mar 26, 2008
This is how I replaced the battery on my Casio 1572 A168 watch.
1- Undo the 4 screws to remove the back cover. Note the correct orientation for reassembly by observing the writing.
2- Gently pry out the mechanism.
3- Undo the 6 clips round the circumference of the mechanism with a pin or watchmakers screwdriver. The top half should come loose. There is also a 7th clip which can be more easily unclipped from underneath. Replace the battery.
4- Note the correct position of the small spring. This spring is necessary to make the watch speaker work.
5- Note from the picture the correct position of the special contact which connects with the lower board. If this does not connect properly then the display will disappear.
6- With the battery in place, the watch display should work properly. If there is a problem try connecting the two all clear contacts with a screwdriver, paper clip or small piece of wire to reset the watch.
7- Reassemble the watch and make sure the rubber seal is in place. The seal on my watch was slightly deformed so I used a very small amount of silicone sealant on the tip of a screwdriver to tack it down properly.
8- Put on the back cover being careful not to overtighten the 4 screws and damage the threads. The cover needs to be positioned correctly and not 180 degrees in reverse so the spring will connect with the correct place. When you look at the front and back of the watch the writing should be the same way round.
Kind regards
*Looking at the picture it might also be possible to replace the battery by removing just the one clip that is closer to the spring. However I found that that clip is more easily undone from underneath, so I preferred to do a more complete dismantling. This also gives more freedom to reposition the battery.
Feb 26, 2013 | Casio A168W Wrist Watch
How do I reset my Casio PRG-40 following battery replacement?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please .
Apr 08, 2010 | Casio Protrek Triple Sensor Tough Solar...
I need to replace my battery and get my band fixed but i dont know how
Take it to a jeweler who sells Casion watches and ask them to replace the batter and the fix your band.
Jan 12, 2010 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
After battery replacement of casio sea-pathfinder
If it has "AC" written on the module you may need to short between the AC point and + battery. Also check voltage of battery. It may just be too flat.
Jul 25, 2009 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Body of SPF-40-1v
i have a spf40 casio, all is ok but interior display damaged
Aug 11, 2008 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
REPLACEMENT STRAPS FOR Casio Sea-Pathfinder SPF40-1V Wrist
Call Casio Parts dept and they should be able to send you a band. 800-223-2001 is their number. :)
Jul 19, 2007 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Casio Sea-Pathfinder SPF40-1V Wrist Watch Logo
7,633 people viewed this question
Top Casio Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
