Question about MTX Ford Explorer/Mercury Mountaineer/Mazda Navajo 1991-2001 Thunderform Loaded with 10 Inch Woofer and ... Car Speaker
1997 mazda 626
I cannot find the transmission fluid stick for the life of me....i just bought the car and i am double checking the fluids...please help...i cannot find an online manual to access asap
  • dplenzick Feb 25, 2008
    thankyou pierre!!! I saw that knob but i wasn't sure what it was so i afraid to mess with it:-) Thankyou...i found it with no problem!!' Take care!!
  • 2,039 Answers
Black rubber nob big hose from air filter to motor its behind that big hose on the driver side let me know pierre if you have any more question
Posted on Feb 24, 2008
I HAVE A MAZDA 626 1994 MODEL AND ITS A AUTO TRANSMISSION.ITS HAVING A PROBLEM LIKE WHEN I START ITS OK AND WHEN I DRIVE SOME TIMES THE TRANSMISSION MISSES AND WHEN I REVERSE IS ALSO MISSES AND ITS D
Ok you might have low transmission fluid which would cause to slip.
Now check fluid level with engine running. Also if you look at colour of fluid on the dip stick if its a brown colour than you need to change fluid and filter. A good fluid should be red not brown or smelling burnt.
Sep 14, 2014 | Transmission & Drivetrain for Ford Transit...
I have a 1992 mazda 626 5 speed manual and the clutch is stuck down what do i check
You will need to check the transmission fluid. There is a dip stick for the trans just under your breather box on the driver side of the car. Start your car and let it warm up before checking the trans fluid. It should show on the stick. It should be the upper mark on the stick. If it is touching it then the fluid is ok and if not you will need to add some fluid.
Nov 25, 2012 | 1993 Mazda 626
My Mazda 1997 626 is smoking when driven. Just had exhaust and transmisson work. Mechanics say it's fine
its time to look under the car yourself for a oil leak or even a plastic bag burning on the exhaust you have been checking the engine oil have you checked the transmission fluid level? the trans is on the drivers side i believe
Jul 11, 2012 | 1997 Mazda 626
1997 mazda 626 won't start.
Are the plugs wet with fuel?
Check for spark. No spark? it may be the ignition module.
Plugs dry and spark present? No fuel?Spray a little starting fluid and see if it will run on that.
Then check pump fuses and for fuel pump noise.
Jun 01, 2017 | 1997 Mazda 626
Changing transmission filter on 1997 mazda 626
If it has those transmission without a transmission pan then all you can do is drain the fluid and refill it back up with fresh one. The ones I have seen are like Hondas, their filters are built inside the transmissions, so in order to replace the filter is to rebuilt the transmission. Those Mazda transmission should use Mercon III transmission fluid but check in your manual book to make sure. The Honda transmissions uses special transmission fluid from the Honda Dealer only.
hope help.
Jun 22, 2011 | 1997 Mazda 626
Madza 626 2.0 1997. Transmission does not work in reverse. Forward is fine. any possible solutions? Fluid is not burnt
Loss of reverse is a dead givaway that the transmission has failed. The reverse clutch band has failed.
Apr 14, 2011 | 1997 Mazda 626
How do I check the transmission fluid on a manual 1995 Mazda 626 dx
On the transmission you have 2 plugs. The lower one is to drain the fluid the top one is to fill/check fluid level. Take the top one out and stick your finger in. If you get fluid its full.
Mar 26, 2011 | Mazda 626 Cars & Trucks
Wheres the transmission filter located at on 1997 mazda 626
the filter is located inside the trans. you have to take the pan off the trans to drain it. be sure to have a catch pan big ehough to catch the fluid. get a filter and gasket before you start.
Mar 29, 2010 | 1997 Mazda 626
Car Audio & Video Logo
61 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Marvin
Marvin
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
