Question about HP DeskJet 694c InkJet Printer
Hp 694c injet
Printer powers up, then I can hear a buzzing noise. After that the yellow light blinks and nothing else happens. Help!!!!!
  • billweko Mar 14, 2008
    After clearing a paper jam, the amber light blinks when first switched "on" and is not printing. Now the computer is not detecting the printer at the usual LPT location. Anyone with similar problem?
  • alleric Jun 27, 2008
    Clean contacts on cartridges.
    Clean contactd on printer
    When printer switches on cartridges move as third of the way itshould, the the yellow light strt blinking. Does not pick up paper, therefore NO printing
    can be done. Plug from computer to printer has been checked. New
    cartridges hasd been installed and checked to fit correctly.
    Genius:
  • 1,019 Answers
Checklist:-
1) check for a paperjam.
2) check the ink cartridges are not empty.
3) try pressing and holding down the flashing light button ( if applicable )
4) check the power lead is connected correctly.
5) give it a good hard Smack.
6) if all else fails Bin It, And Buy A New One :)
Mike @ Compurepair.
Posted on Feb 24, 2008
The computer isn't coming on the power cable is plugged in the green light is blinking but nothing else is happening
Do you hear fan starting noise? If you dont hear any noise most probably you need new power supply.
you can buy cheap power supply from www.aria.co.uk
if you hear the fan noise!
Does you motherboard starting with POST (a beep noise).
if you dont hear. well you need a new motherboard which should be compatible with your other peripherals.
if you hear a beep noise! Most probably your operating system is corrupted. (Boot file corrupted)
in this case you may have to install new operating system.
Thank you
if you got any problem let me know
somindradilruk@gmail.com
Sep 03, 2010 | HP Pavilion a705w PC Desktop
Hp 2600n printer, flashing yellow light near printer cable
check the IP address on the printer,if u reset ur rooter it will assign a new IP so thats y cant print to it In a future use a host name of the printer so this wont happened again
Feb 23, 2010 | HP Color LaserJet 2600n Printer
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
The yellow light blinks and it won't print
I also started having problems with my HP 870Cse when I began using refilled cartridges and had ink leakage (cartridge contacts corrupted). Check for this problem. If so, remove cartridges and gently clean the spillage. Then try using HP brand cartridges and see if this doesn't remedy the problem.
Jan 21, 2009 | HP Deskjet 870cse Printer
Problem with Hp DeskJet Printer 5550
Here you will find steps for troubleshooting a carriage that wont move. Also, you can find information about the blinking lights here.
Hope this helps. Please remember to rate this information.
Thanks
Nov 16, 2008 | HP DeskJet 5550 InkJet Printer
Hp deskjet 694c
Light keeps flashing and will not print
May 08, 2008 | HP DeskJet 694c InkJet Printer
My HP 694c hangs while printing
Probably the service station motor is burn out ...
However try to lubricate the carriage shaft with some oil, supposing carriage blockage.
Jan 12, 2008 | HP DeskJet 694c InkJet Printer
Will not print at all
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
Oct 27, 2007 | HP DeskJet 960c InkJet Printer
HP DeskJet 694c InkJet Printer Logo
79 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
