Question about Pioneer SD-P50A5-K 50" Rear Projection Television
50" Projection TV
I have a 50" Projection TV and it would keep shuting off after abot 1 hr. now when i turn it on a red light come on then simply shut back off. Now it wont even turn on ... i was told that it my be a regulator switch? I need help..and is it something that i can replace myself?
Thanks!
james
jlajla12@bellsouth.net
  • 7 more comments
  • el seven Mar 03, 2008
    Yes i would love a link to help in the repair of this problem. I have similar issues, it goes into protection mode near instantly. I can see a red LED lit up on the power supply board, i do not know if that details the need for resoldering, flyback replacement, etc... any help would be appreciated, it's the Pio SD-P50A5-K set as well. Built in 1997.
  • bjrose Mar 21, 2008
    I have the same problem. The green light goes on for a second and then turns to red. No picture
  • Anonymous Apr 06, 2008
    I have the same problem and I could use the link for the shutdomn circuitry troublshooting. Thanks Rick
  • phlaxx65 Apr 06, 2008
    tv wont turn on makes a chirping noise.
  • el seven Apr 24, 2008
    I found a 4amp fuse on the power supply board to be the culprit and my set is now working. Look for a mini AGC fuse grouping and check for any bad fuses!
  • thomas perusi Apr 24, 2008
    man pioneer must have seen us coming! my tv would try to come on and I would hit it at first and it would work. After a while it would not work anymore so I read on here about the cold solder joints and I took out the complete powersupply board and resoldered all the bad area. Now I get the green light to come on everytime but now the red portection led on the power supply board comes on. can I unplug some boards to see if one of them is loading it down. I have called pioneer, sams photofax, every manual place around and can not find a print. never buy pioneer !
  • elliottbd Jul 07, 2008
    I have a sd-p5071 pioneer tv and it stays on for about 1 or 2 hours then it shuts off, I unplug it plug it back in and it shuts off in 3-5 seconds. is something getting to hot like the power supply or is there some easy fix.
    blake
    elliottbd@yahoo.com
  • maffitt2008 Jul 29, 2008
    Tv wont power on its like stuck on stand buy we dont have a remote for it....so what to do thank you
  • ljljljlj Sep 12, 2008
    shuts down after 10 min. lokking for the power supply part number
Pioneer SD-P50A5-K 50 in. Rear Projection...
When the is switched on it turns itself off after 1 minute
Posted on Jul 23, 2008
    Problem Solver:
  • 6 Answers
I found a 4amp fuse on board the power supply board to be the culprit. Look for a grouping of mini AGC fuses and check them all.
Posted on Apr 24, 2008
Where is the link, for
Posted on Apr 23, 2008
  • rajirh mk May 04, 2008
    check (or resolder)IC- 2503,2504and Q 3014,3015,
    or some dry soldering related to vertical section
  • Pioneer Master
  • 8,617 Answers
Your set was going into protective shutdown. Probaly a leaky diode that was raising voltage that triggered the shutdown circuitry.Toshiba has good service info available to trubleshoot the power supply and shutdown circuitry. let me know if you would like me to post a link on where you can get this troubleshooter manual .
Posted on Feb 24, 2008
Screan shuts off after 30 seconds and 3 lights flash on botton near power button.
Contact Samsung tech support, Tell them this info, they should be able to tell you the type of problem you have
Feb 12, 2014 | Samsung HLP5085W 50" Rear Projection...
Hi iam josh i have a sony tv model no. KF-50WE610 serial no. 9137805 my tv is in good condition the only thing it keeps shuting off by it self and the red light on the power butten starts blinking i have...
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator.But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.The lamp you need is XL2100 you can find it here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click=48173.Have a blessed one!
Apr 30, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
TV KEEPS SHUTING DOWN TILL IT GETS WARM THEN ITS
No i just thought it sounded like a odd problem i've seen before . In your case I'd expect the lamp p/n 6912b22007 or possibly if not the lamp then a bad ballast p/n 6316000009b
Oct 06, 2009 | LG 62SX4D 62" Television
Zenith 52'' dlp tv won't turn on
after an hour tv shuts off and you have to wait to turn it back on
Jun 12, 2009 | Zenith Televison & Video
TV turns off and power light blinks unpluged andd still does it.
Likely to be the STK convergence chips causing a protection circuit to switch the TV off. Have you got any onscreen convergence problems (i.e, colour fringes)?
May 27, 2009 | Toshiba 42H81 42" Rear Projection...
Tv is now in faded black and white
Your HT Tansfer is giving low votage to the picture tube. Replace the HT Transformer(don't touch or go near it, it carries 11000 Volts!)....sodeep
Mar 22, 2009 | Samsung HLN5065W 50" Rear Projection...
Olevia 50" rear projection problem
http://www.tvlampsforless.com/Olevia_LCT50HV_bulb_p/lct50hv.htm
Apr 08, 2008 | Syntax Olevia 50" Rear Projection...
Tv shutting off
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sep 11, 2007 | Toshiba 50H81 50" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
176 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
