Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Spontaneous program changes
Doesn't respond to remote. When I turn on manually, it scrolls among TV, Video 1, 2, 3, 4 and Initial Sony Setup Screen. I've unplugged cable box and TV and plugged back in. Changed batteries in remote.
  • 2 more comments
  • hosenphefer Feb 29, 2008
    Exact same problem. It switches channels automatically and cannot stay on the video extension without switching back to tv. Also the Remote just went out and is completely useless, unless I do certain combinations of pressing the actual TV controls and the remote control at the same time.
    Any help is surely appreciated. I read something about a bad Tack board caused by cleaning solution or moisture seeping onto it from the screen?
  • tvwoes516 Mar 01, 2008
    The 'Initial Sony Setup Screen' keeps showing up spontaneously on top of what I'm watching, and the remote doesn't work at all. Putting fresh batteries in the remote did not resolve this. I also tried pushing CH+ to let the tv go through it's initial setup routine, but that did not resolve anything.
    I tried turning the tv off manually for about 2 minutes and since I have turned it back on, I haven't seen the 'initial sony setup screen' for now (4 minutes), but the remote still does not work at all.
  • HENKEM56 Apr 25, 2008
    the initial set up flashes on and off every 15-30 seconds, following the Ch+ buttons doesn't help. I tried unplugging the cable from the wall and restarting the tv.
  • Lexusfreak Apr 30, 2008
    The remote on my Sony FD TRINITRON WEGA KV-27FS100 27" TV does also not work and all of the controls including the menu buttons in the panel do the same thing. Switch the video inputs like the tv/video button is supposed to do.
  • 71 Answers
Sony has trouble with the push switches that change channels, tv/video etc. change the tv/lvideo switchbehind the button on the front-the chassis will have to be removed
Posted on Apr 27, 2008
  • james cunnington Apr 27, 2008
    will also cause remote not to work.
  • 62 Answers
No doubt ...
try to check out the memory module and the T board......
thank's
[Vrya]
Posted on Mar 07, 2008
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
To perform Auto Program again
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Dec 18, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Initial setup screen pops up at random times. The
The ability to control volume is often lost do to dirt or wear internal to the remote control. If that's the case then I would try a new remote. I universal one will give you the capacity to control volume, on/off and channel change. Try one of those (you need to program it for your individual model) and if that controls the volume you should replace your remote.
Concerning the spontaneous activation of your on screen display is also possibly coming from the remote. Put the remote in cardboard box or anything non translucent and see if that stops the problem. If it does stop it's the remote. If not your set will have to be seen by a professional electronics technician that hopefully is familiar with TV circuitry.
Apr 16, 2010 | Sony Televison & Video
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
Menu Screen pops up, try to exit and goes to video 1
This could be a stuck button on the front control panel or a bad solder connection on one of the switches on the front control panel.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Initial setup
This is commonly caused by the CRT going too weak, and the AKG circuits are switching off the bias to the CRT. This is part of the high voltage regulation protection.
Other causes, but are rare to cause this, are failures in the bias circuits, high voltage regulation (flyback assembly), and in the scan amplifiers.
With proper experience, reference to the service manual, and the proper set-up, it is possible to determine the causes of the failure, and service it. The cost of the parts will be rather expensive if you can still have access to them.
Jerry G.
Apr 04, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony KV-27FS100 does not respond to remote
Good day.
Maybe there are loose connections along the IC that supports the operation of your remote. This could also hamper initial set up operation of your unit. Also, check on loose connections along the power supply.
Chris
Mar 02, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Won't respond to remote
Access servicer menu,run initial set-up. Have you already tried hard re-set? Leave it unplugged from AC overnight==== Also,please verify model #
Oct 05, 2007 | Sony KV-36FS100 36" TV
Help!
You have a button stuck either on the set itself or on the remote. Stargazer
Aug 16, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-27FS100L -
This is due to switches malfuction due to corrosion in switch and dust accumulated in the switch. Since you rarely used switch now after failure of remote of remote control you tried to operate the switch. Another thing you said did"t get picture, maybe memory problem is there. This can be sorted out by the technician only.
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
89 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
