Question about Electrolux Lux 5500 Canister Vacuum
No Power coming thru hose handle
I have no power coming thru the 2 year old hose handle. I checked continuity also and nothing with the switch in the on position. The vacuum is 15 years old and I recently replaced the hose/handle part. Can I take apart the handle portion to see if anything's obvious there?
  • 75 Answers
It probably wouldn't help, it sounds like the switch. Have you tried pushing the reset button? (It's a little red button on the end of the power nozzle.)
Posted on Feb 26, 2008
All these answers deal with changing the belt. The belt on mine is fine. The light for the brush head doesn't come on - it's not getting power or the motor is burnt out. Next step?
What kind of vacuum is it? Model number? If its a canister machine and its not getting power to the nozzle its possibly: 1)One of the connections in the handle or the connection that sends power through the hose at the canister end is faulty. 2)If the hose handle has a switch to activate power on and off that may be bad. 3) The hose itself has a break in the internal wiring and would need replaced. However, this can be tested by powering the machine on and flexing the hose around to close a wiring break and see if it kicks on for a moment. 4) If the power nozzle has a circuit board brain in it that may have failed. 5) If there's a reset switch at the nozzle give that a try.
Sep 30, 2017 | Vacuums
No electrical continuity on one lead in hose. Cause is probably in the wiper assy. How do I disassemble hose ends to check electrical connections without breaking or cutting into plastic parts?
We have here the user manual. The page 8-9 you will see the instruction for replace the power nozzle which shows how to desmandle the vacuum and you will find the power cord connetion point. A big advice use your camera to take picture every step you make and especialy before remove the wires since in any case you will forget anything when you will try to assemble it back they will bevery helpfull.
Aug 06, 2011 | Hoover S3670 Bagged Canister Vacuum
We have an electrolux central vac. The power head won't turn on. It has a 3 way switch on the handle. When to the left it is just air for the floor. center is off and to the right is the power head. ...
I assume you did press the reset switch on the power nozzle. If so, there are a number of things that could cause this. To rule out the hose and power switch, connect the Sidekick (if you have one) to the handle. Turn vacuum on. If the sidekick runs, the problem will be in the wands or power nozzle. Try connecting the power nozzle directly to the hose. If it runs, the problem is the wiring connections in the wands, or from the lower wand to the power nozzle. Check all connections for discoloring and broken or cracked wand fittings.
The wiring in the elbow of the PN is a fairly common problem, especially with certain models. A piece inside breaks, resulting in the wire connection to not make contact. No contact means the PN motor won't run. And there's always the possibility that the PN motor is bad.
If the Sidekick doesn't run when connected directly to the hose, the switch could be bad, the wiring in the hose could have broken, which is another common problem in older hoses, or the ECV board in the vacuum could be bad.
If the problem hasn't been resolved at this point, it's best to take the entire machine to the Aerus Electrolux store near you for a free diagnosis.
http://www.aerushome.com/storelocator/
Jan 07, 2011 | Electrolux Central Vacuum
Kenmore Powermate power head not working
I've got the same problem. Try checking out the electrical connection where the hose attaches to the canister. The hot male terminal is corroded and the female socket is burned out. Its an unfortunate design flaw that every time you open the vacuum to replace the bag the electrical connection disconnects and reconnects. Not sure if I can find replacement parts for a 10 year old vacuum or if a home-made re-wiring job is in order. Will find out tomorrow.
May 30, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
The power will not come one remotely!!
The reset is not the problem. If you have suction at the vac itself , but no elsewhere., you have blockage in your main line, or your hose. Try dropping a coin thru the handle of the hose and shake it all the way thru the other end. If your hose is clear the obstruction is in your piping. If your hose is clogged you must back out the blockage by sucking it back thru the handle.
Go to each inlet with a coin and touch the contacts inside the throat of the inlet...., 2 little brass spring loaded pins. If you can feel suction move on one inlet at a time. If you have no suction at any inlet your blockage is in the main line. If you have suction at some inlets , your blockage is in a branch. Try to pinpoint the closest inlet to the vac where you have no suction. Then put another vac like a shop vac up to the inlet and **** the blockage back out if possible. ..What wedges in must back out the way it went in. Post back with more info if this doesn't work
Sep 09, 2009 | Broan-NuTone CV350 Performance Bagged...
I have a Hayden SuperVac 3600, almost 10 years old. The unit still runs, but now when I switch to the power nozzle, it doesn't have power to turn that. I think this happened once before and maybe they...
The hose has fuseable link inside, generally a 3-7 amp. It is at the wall end underneath the hose cuff. Easy to replace as it crimps in line. If you have a meter you can also test the detachable hose to wall cord for continuity, then check the hose to handle as well.
You can also detach the hose to wall cord from the hose, and plug your power head directly into that cord,, then into the wall thereby eliminating the hose itself.
Hayden makes a serviceable hose. If damaged or the fuse blown it can be serviced by a good tech. If the fuse is blown you need to clean and inspect the power head as this may be the cause
Jun 20, 2009 | Hayden Industries SuperVac 6000 Central...
Vacuum will not shut off
Sounds like you have wires crossed at the switch. The 2 wires coming in go to the center posts, 2 to the power head & 2 to the main motor.
Jan 31, 2009 | Kenmore 25512/ 25513 Progressive Canister...
I have a one year old Beam central vac. It has supervalves. The handle (connected to the hose stopped turning on the unit. The handle still powers the brush but no longer turns on the suction?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566201
Generic problem for all Vacuums
I have a one year
posted by jon89 on May 02, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Beam Central Vac may have more than a one year factory warranty and it sounds to me that you may have a bad relay switch the Central Vac, if you do it should be covered under the factory warranty. Otherwise, you may have a bad supervalves or a wire came loose, if the hose switch turns on the power nozzle then it may be a bad supervalve or a bad relay and to contact the installer or the manufacturer of Beam. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Electrical power down while vacuuming (not a reset)
Thank you JonahBegone!
My 4 years old Silver Moon has been power down off and on for a couple of months, but all of sudden it kept doing it. Then the power won't turn on when I plugged it in ( this turns out to be another problem, see my other posting). I took your advice on taking the hose and handle apart. I unscrewed the 5 screws, but can't pull the handle apart to look inside. I was able to see the 3 metal contact on the hose that you mentioned through a 1/4 inch gap when I forced the handle apart. I cleaned the black stuff off through the little gap by rotating the hose a few times. Then magically, my power down problem also went away. Thank you once again.
Mar 25, 2008 | Miele s558 Silver Moon Vacuum
No power to scrubber head
Hi Dennis_b,
to continue checking that problem, please see, with an electrical screwdriver, if the machine has energy where the scrubber connects. If yes, the problem is in the scruber; if no, the problem is in the machine, where a red and a black wire makes the connection since the electrical extension to the scrubber connetion, passing thru the swich. it makes me to think in various problems. Even a broken wire can make a malfunction.
Complements
Jan 19, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Electrolux Lux 5500 Canister Vacuum Logo
175 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
