Question about Minolta magicolor 2200 DeskLaser Printer
Paper is coming out folded - accordion-like
Starting about 3" down the page, for about 3".
(minolta qms magicolor 2200 desklaser)
  • S. Metcalfe Apr 10, 2009
    Mine has just started doing this. Any further information on the most likely cause? The paper is not damp.
  • Minolta Master
  • 691 Answers
Sounds like the fuser is worn out/damaged or maybe your paper is damp.
Posted on Feb 24, 2008
Its a solenoid problem
Posted on Apr 17, 2008
Firmware magicolor 2200 DL
Sir/mam requires access to secure konicaminolta web site. If they still have it. That legacy Minolta/QMS now konicaminolta
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 18, 2014 | Minolta magicolor 2200 DeskLaser Printer
My magicolor 2200 keeps asking me to put paper in the mpt (multi purpose tray) when I'm printing form the bottom tray. The resulting print comes out slightly smeared and starts part way down the page. ...
ok seems like 1 of 2 things,,, firstly check your print settings and ensure your selecting the correct try to print from..
turn off machine
might be a stuck sensor, turn off machine look at where u load the paper, close to where the printer pulls it up, there is a small leaf swith there that tell the printer if it has or dont have paper, play ith the switch a bit.. Then turn back on and try again.
Apr 02, 2011 | Minolta magicolor 2200 DeskLaser Printer
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
Minolta magicolor 2200 registration is shifting
Yes,
There is a solinoid on the right side that will cause this to happen. I placed a spacer in mind a resolved the issue. Not an ease fix as you need to put the machine way down but it's a cheap do it your self job.
Sep 30, 2009 | Minolta magicolor 2200 DeskLaser Printer
Paper Jams (xylophone effect)
This problem is caused by a poor glue compound used on a solonoid assembly (SL3) in the back of the printer. Although difficult to get to, it is easy to fix.
Remove the back panel. Now remove the power board (PWB-A) - that's the lower-left board with the over-abundance of connections. At the top of the newly exposed area will be a solonoid assembly (SL3) - a small, black, round device connected by two wires and mounted to a brass-colored bracket. This assembly is mounted by one screw. Remove the screw and the solonoid assembly. Now that you have the solenoid assembly out, the repair should be a snap.
Notice on the assembly will be a brass lever held in place by a spring. At the tip of the lever that rests against the brass bracket, you should be able to see a tiny black pad when you push down on the other end of the lever. The glue that holds the black pad in place is the problem. The pad is likely part-way to most of the way out of position. Lining the pad back up with the tips of both brass pieces and supergluing it will do the trick. Just make sure to not superglue the brass pieces together and to let the superglue cure before putting it back together.
As to exactly why this repair procedure works, I'm unsure. I can only speculate that the lever must rest too far from the solonoid and be failing to stop the gear that feeds the paper. Or in my case, with only one or two folds in the paper, it must have been functioning too slowly.
Apr 17, 2009 | Minolta magicolor 2200 DeskLaser Printer
FUSE FOR TRANFERBELT
Are you sure you have to replace the fuse and not the fuser unit? What symptoms does your printer show and is there an error code? Most of the fuses are on the HV1, HV2 or PU1 and will be either 5, 10 or 15 amp.
Mar 08, 2008 | Minolta magicolor 2200 DeskLaser Printer
Minolta magicolor 2200 DeskLaser Printer Logo
311 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
