Question about Roper REX4634KQ Electric Dryer
My roper dryer stopped working
I had a load in when the load was done. I went to add another load and went to turn the dryer on and it would not power on. I have checked the fuse box and made sure the door was shut. It will not turn on. Is my dryer dead?
  • 2 more comments
  • stephie77 Feb 24, 2008
    I have tried that and no luck.. Thanks for trying.
  • kitkat65 Mar 09, 2008
    My roper dryer will not start. The light stays on when the door is shut. Is it a fuse?
  • 67792 Apr 16, 2008
    My unit will not start. Just went out. Dryer is only 2 years old.
  • rickjodi Jul 06, 2008
    My dryer stopped working in the middle of a cycle. I've checked the plug into the wall and the breaker box. No luck. Help!
    President:
  • Roper Master
  • 2,651 Answers
Right above the door where it closes, there should be a door switch actuator, although your closing the door it might not be activating door switch.
Posted on Feb 24, 2008
My roper dryer works fine, it heats and the timer advances, it just wont shut off at the the end of a timed dry or auto dry. What do you think?
A timed drying cycle uses the timer alone to stop the drying cycle. Once it times out like an egg timer a set of contacts open up shutting off the dryer. Or a set of contacts closes to activate a relay which in turn shuts off the power.
Auto dry usually uses a moisture sensor which would do the same thing as the timer. Once it doesnt sense moisture in the load for a predetermined time it in turn triggers a relay which shuts the power off. Some auto dry cycles just use the timer alone and guess-timate the drying time by the selection.
If yours does not use a moisture sensor then most likely it is your timer/cycle switch. There may or may not be a relay involved.
Most dryers have a basic wiring diagram on the inside somewhere on one of the panels which will help.
Since yours is acting up on both cycles Im guessing you have a bad relay or connection to that relay somewhere IF it uses a moisture sensor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/john_32f4b76dad4781c4
Dec 17, 2014 | Roper Dryers
Roper dryer RAS7133RQ1 won't start
For starters, a user manual for your dryer can be found here.
Jun 02, 2008 | Dryers
Dryer is dead .does nothing
Try turning off the power at the main house breaker, then turn it back on. If nothing happens you probably blew a fuse in the control panel.
Jan 20, 2013 | Roper Dryers
My roper dryer will run for few minutes and throw a breaker.It gets hot and spins just throws breaker
check the vent i went on one that done that if vent is clear and no other signs replace breaker
Jun 08, 2010 | Roper RES7646KQ Electric Dryer
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Won't run
ensure your door switch is working then move into timer.
May 05, 2009 | Roper RES7646KQ Electric Dryer
I have a roper gas dryer. The Timer stopped
my roper just stopped working this morning the timmer nor the heater or the dryer itself will not at all.
Apr 04, 2009 | Roper RGX4634KQ Gas Dryer
Roper dryer
check thermal fuse
Jul 18, 2008 | Roper Dryers
Roper REX4634KQ Electric Dryer Logo
468 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
