Question about Equator EZ 3612 CEE Front Load Washer/Dryer
EZ3612 - spins for couple of times then stops with burning smell and mode light blinking 13 times
I have Equator EZ3612CEE. After it starts the washing cycle, it runs for a little while then stops. I smell something burning and the knob starts to turn. Mode light blinks for 13 times.
  • Anonymous Mar 29, 2008
    Mine fills and then empties, doesn't spin and then the washing dial starts going in circles.
    If I set it to dry it spins a couple of times and then stops. Then the washer cycle dial starts clicking around in circles.
    Help
  • 3 Answers
Per the service manual, if the mode light blinks 13 times, there's a bad dryer sensor or thermostat. I'm not sure if that related to your problem but it's a start.
Doug
Posted on Jul 06, 2008
Water not draining even after reset attempts
Did you check the most obvious item - the motor and belt that spin the drum and powers the pump assembly
Sep 12, 2017 | Equator EZ 3600 CEE Front Load Washer /...
When drying rubber burning smell from inside Equator EZ 3612 CEE
If you are still wanting to know the reason, it may be that the door gasket has warned off and may need to be replaced.
Apr 04, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Machine won't spin
Motor part number is 8529936 about $200.00 any appliance parts store can order it. You can replace it your self. Also replace the direct drive coupling when you change the motor.part number 285753. Be sure to inspect your wiring harness and check the motor wire continuity before you put $200.00 into it.
Mar 27, 2009 | KitchenAid KAWS850L Top Load Washer
Equator Wash dial just spins
just bought this ez 3600cee it says its ventless ,but yet came with
a venting duct work why?
Nov 29, 2008 | Equator EZ 3600 CEE Front Load Washer /...
I need a diagram of an Equator EZ3612CEE door
While you may have removed the door with the hinges from the cabinet the nuts may have fallen down on the unit.
You may want to open the back panel or the bottom panel and try searching for the same, in case you need assistance mounting the bracket back on the cabinet once you have the nuts do let me know.
Nov 24, 2008 | Equator EZ 3612 CEE Front Load...
Equator EZ 2512 CEE Front Load dryer not starting
The blinks are the fault code on the unit you will have to watch them an count match them to the chart in the service manual
Here is a link to the service manual
http://www.appliancedesk.com/appliancedesk/service/CWD/EZ3612CEE_EZ2512CEE_EZ1612V/Service_Manual.pdf
Feb 20, 2008 | Equator EZ 2512 CEE Front Load Washer /...
Strong ozone-like burning smell
Sounds to me like the motherboard inside the unit is on it's way to thermal overload. This is a common problem with this particular model. You'll smell electronics burning and one day it'll quit altogether with a burst of smoke. I had this happen to me and I traced the problem back to a faulty triac (transistor-like device) that overheated and caused the circuit board and wiring harness to burn up from excessive current draw. I repaired my motherboard with a new triac ($6) and rewired the harnesses. A cooling fan on the heatsink of the board would solve this problem.
Nov 12, 2007 | Equator EZ 3612 CEE Front Load...
Equator EZ3612 CEE
If you still need assistance on this let me know and I can provide you with the procedure for the same.
Sep 15, 2007 | Equator EZ 3612 CEE Front Load...
Equator EZ 3612 CEE Front Load Washer/Dryer Logo
193 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
