Question about Dishwashers
Dishwasher not starting
My dishwasher will not start even though the door is closed and the lights come on. Can someone help me?
  • 2 more comments
  • Anonymous Feb 25, 2008
    all lights on. close door won't start?
  • tisselfied Feb 27, 2008
    Thanks for the advice, but it did not work. I had left it unplugged all night still nothing. I have a maytag quiet series 300. Some of the lights will come on but I cant change from light wash to normal wash. When I try to start it nothing happens. Hopefully you can give me something else to try.
  • tisselfied Feb 28, 2008
    Thanks for your advice. Ill try to contact a repairman.
  • domsmom45 Mar 16, 2008
    Put a new lock on and now it won't start. Press rinse only button, that comes on, but when we press start that light doesn't come on nor does dishwasher.
  • 21 Answers
Good day to you... my name is Dean
Are you able to program or change any functional features press other cycles...? If not, try un-plugging the dishwasher (usually location is under sink) if not find which breaker in the electrical panel will and open circut. Some dishwashers have a "lock" feature purposely to prevent children from toying with panel. You would need to provide more info for us on that one. Brand and model number would help. Sometimes, Electronic control panels can become statically charge, so by shutting down the electricity supplied to the unit for about 2 mins. and then restoring power, can be a simple solution. Let's hope so anyway, because it can get a lot more complicated, if not, and that's not supposed to be the way a Monday's supposed to start the week off, for anyone..
Posted on Feb 25, 2008
At this point about the only suggestion would be that either the latch switches in the door are defective or the electronic control board would need to be replaced. Sometimes the (what we would call the ribbon) the connection where the touch pad and control meet, that may not be making good contact (but that's rare) at this point, unless you have had some type of prior experience, it would probably be best to contact a repair person.. my apologies for not getting back sooner, I was in the field yesterday, was a long day.
Posted on Feb 27, 2008
My Prima LPR660 will not start even though all the lights are on
It is likely the door latch microswitch is faulty and preventing the controller from confirming if the door is shut or not. Or it is possible the door latch mechanism is preventing door from shutting. It looks like this.
Prima Door Interlock
Jan 08, 2014 | Dishwashers
Bosch Logixx won't start - Stuck on "Close the door" even though door is closed.
Open the door, look along the top stainless on the door and you should find the ENr number (model number) etched into the stainless, may need to give it a wipe and look at an angle to read it. Post the ENr and that should help with diagnosis.
Mar 15, 2013 | Bosch 24 in. SGS69L02 Logixx Built-in...
Kenmore dishwasher will not start
The most probable cause is the door latch (or switches in the latch) are not working right, and the controller thinks the door is open, even though it is closed.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 13, 2012 | Kenmore Dishwashers
I start the dishwasher and it does nothing and lights do not turn on either
When your dishwasher won't start, it could be a problem with your electrical panel or the door might not be closing properly.
Check your household electrical panel for a tripped breaker or blown fuse. Also check to make sure the door latches closed properly.
For additional troubleshooting steps you can take and things you can do, read Dishwasher won't start for more suggestions. I hope this helps!
Aug 02, 2012 | Kenmore Dishwashers
Our dishwasher is blinking CL - i think this means 'Close'... Even when the door is properly closed, it blinks CL and won't start!! Help!
Hi
Error CL appears when the dishwasher control detects door switch is open or door is open. You'll have to open the door and check the continuity of the door switch. If the door seems to be closed then it is the control has detected an issue with the door latch. Check the door latch & seals to make sure door is closing fine. Unplug the dishwasher from power outlet and wait for 10-15 minutes. Restart the dishwasher and check if the error is still there. If error still appears then you'll need to repalce the door switch/door latch. Hope this helps... Please post back for further assistance.
Daniel
Mar 24, 2011 | Frigidaire Professional Series 24 in....
Dishwasher wont run after pressing START ... green light blinks
NOT TOTALLY SURE ABOUT THIS MODEL, BUT IS THERE A "LOCK" BUTTON ON THE PANEL? ON SOME MODELS YOU NEED TO PRESS IT TWICE TO ENGAGE START. HOW OLD IS THE UNIT? HAVE SEEN THE INTERNAL TIMER RELAY MALFUNCTION ALSO AND IT WILL NOT ALLOW DISHWASHER TO START CYCLES. HOPE THIS HELPS
May 30, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Electicity going to dishwasher but when program dial turned it doesnt start program even though its switched on and door closed
small amount of water at bottom of dishwasher, electricity is going to the unit no breakers are blown, no light nothing responding on dishwasher
Sep 03, 2008 | Kenmore 16872 Built-in Dishwasher
Kitchenaid dishwasher KUDS02SRSS2 start light blinking won't start
I have this same kitchenaid model. It would not start after selecting the wash cycle and pressing start. The light would blink as if the door was open. I did the reset by pushing the sani-rinse, heat dry, sani-rinse, heat-dry and closing the door. You can hear something going on inside. After that stopped (about 3 minutes). I was able to select the wash cycle, press the start, close the door, and it started. Good luck!
Feb 22, 2008 | Dishwashers
Dishwashers Logo
208 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
