Drivers bjc-210 I cannot get my printer to work. On a different computer I installed it automaticly as BJC-210sp,works just fine but on this computer,also runnung Windows XP I cannot find the proper drivers. Can you help me out please?
    Genius:
  • 1,019 Answers
windows XP should already have generic ( Basic Drivers ) for this.
I would however recommend going to Canons website, and downloading the drivers for this Model.
Alternatively, check to see if any other printers are already setup as the default printer. if so remove-delete-uninstall, then re-boot with your printer connected.
Mike @ Compurepair.
Posted on Feb 24, 2008
Windows 7 driver for > canon bjc-210 printer
A bit Late in the day but if you install the driver for a Canon BJC-2000 it works fine, at least in BW. I haven't tried it in colour
Dec 04, 2009 | Computers & Internet
Bjc2100 install disk won't work on my laptop. I use Windows Vista system.
The BJC2100 install disk came out when Windows 98 was in its heyday. It will not work in Windows Vista. The Windows Vista OS already has a driver imbedded that will work with your BJC-2100. It "should" recognize the printer and automatically install the driver. If it doesn't, try the "Add Printer" feature, select Canon as the manufacturer, and look for the BJC-2100 Series driver.
Dec 10, 2008 | Canon Office Equipment & Supplies
Re bjc-210 printer
http://www.nodevice.com/driver/BJC-210/get24597.html
Copy paste the above address into address bar download drivers hope this works its only .2 mb but it says for xp its the only one i can find rest are for 98 or me or nt
Jul 20, 2008 | Canon BJC 210 InkJet Printer
Printer problem
I found a small plastic "clip" of the type that covers the print-head of a cartridge in the mechanism where the printhead/inkcartridge is mounted. I have no idea where it came from nor how long it had been in there but the printer works OK after I removed it.
Jun 22, 2008 | Canon BJC 2100 InkJet Printer
Canon BJC 2000 question-1284 to usb
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 05, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
Canon bjc 85
Vista driver for this machine comes stnadard with vista but will not work when old xp drivers are present (or were when upgraded to vista) , remove old driver from system, connect printer,  vista should auto reconise and install.
Here is a canon link explaining Vista with BJC 85
http://www.usa.canon.com/consumer/controller?act=SuprtKnowledgeBaseAct&fcategoryid=230&modelid=6620
Oct 31, 2007 | Canon BJC 80 InkJet Printer
Canon BJC 250 printer driver
Canon Web Site for Printers.
Check the Vista internal list.
Go to Printers/Faxes
Click on Install Printer
When you get select from CD or list take 'List'
Go  to Canon
Select the Model
Click OK
Job Done
Oct 22, 2007 | Canon BJC 250 InkJet Printer
Time consuming
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Aug 23, 2007 | Canon BJC 80 InkJet Printer
78 people viewed this question
k24674
jasbo
jasbo
