I had a problem with my washer leaking only part of the time - not from the door, but from the base. There was also a stinky smell after I washed several loads. I couldn't find out where they smell was coming from in my wash room. It wasn't until I started getting the code F 02 that I researched a little further. It ended up that my Drain Pump was clogged - very clogged. When I opened it, it was a horrible smell. So - I solved 3 problems in one: my small leak, bad wash room smell, and F 02 code.
To reach the drain pump, unscrew the lower front panel on your washer. It was a white casing in the middle. Just unscrew & look. I believe in the newer models, they have this available to unscrew directly from the front of the washer. Must've been a common problem.
