Question about Sony BRAVIA KDL-40V3000 Television
Tv speakers i have sony bravia lcd tv which has additional speakers with a dvd ....the problem is that the speakers work only with the dvd ....there is no sound from them while tv channels are running.....plz help also specify the wire fittings ........ plzzzzzzzzzzzzzzzzzzzz Same problem as rattan1880....have tried choosing Audio system in Speaker menu, have tried also Audio control, no luck
  • 84 Answers
Sounds like you have a home theatre system, and you need to run rca cables from audio out of the tv to audio in on the amp, and turn the speakers off in the tv menu and set audio out to fixed or turn tv volume up all the way to get enough audio siginal.
Posted on Mar 23, 2008
Sony Bravia KDL-46Z4100 46 in. LCD HDTV TV does
Probably its not a problem. On the menu You should have a Headphone audio level control (when needed you can mute the set speakers and still have headphone audio).
Oct 10, 2013 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sound isn't working on tv but works from dvd
hi,
Press the menu button on remote control then Audio Video set up then select Audio then TV Speaker.
Nov 08, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
BRAVIA KLV-37U300A 37 in. LCD TV: I have a HDMI cable attached to my Sony Bravia and...
t con is not working is t con is repairbale or can i get ic becouse here in pakistan is not available.
May 17, 2010 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
How do i connect a sony bravia tv to a sony dvd
you can connect two diffent ways with your bravia lcd tv one is videu out connection from dvd &put the cable in to video in to tv other way is rgb connection there is three color sockets in your dvd player & same as your lcd tv so connect with color wise & switch tv to component
Feb 06, 2010 | Sony DVP-NS575P DVD Player
Sony bravia kdl- 4052510 picture but no sound from my dvd player
1 Press volume +/- or Mute 2 If it does not work then check if the 'speaker' is set to 'TV speaker' from the "AV set up" menu in "Settings" 3 Press Menu and select Settings. Go up/down and select Set Up icon.Press enter 4 In AV Set up go to speaker and turn on the TV Speaker. This should solve your problem
Nov 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Aug 25, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
My Sony BRAVIA KDL-V32XBR2 32 has lost its sound. I have checked that the speaker setting is on, the mute is off. Is there anything elsei I can check?
please try differect sources e.g. dvd, cable TV box, aerial. Also check that your connectors are properly plugged in. If none of those work, bring your tv to the nearest service center.
cheers!
Jul 11, 2009 | Sony BRAVIA KDL-V32XBR2 32 in. HDTV LCD
Sound for DVDs
Turn Off or change surround sound mode in DVD system to get vocal sound (dialogues) in speakers.
Jun 03, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Can't get picture after connecting to receiver nad speakers
Sounds like something got confused in the re-wiring...if the TV signal from cable doesn't involve a box, then the co-ax should go straight to the "cable in" or "RF in" on the TV, and the sound equipment gets connected to output ports on the TV. Otherwise, try bypassing the video connections on receiver or whatever and go directly to TV...My surround sound has video in and out, but I've never used them, it doesn't matter.
Feb 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40V3000 Television Logo
243 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
