Phones
Problem for Phones
Generic problem for all Phones
Home telephone wiring
By krik on Feb 24, 2008
Hey, anybody know anything about telephone wiring inside the house?
All of my phones are dead. The signal is good to the house. I put a test phone at the box outside and all checked good. It seems everything at the box is OK. Got 48V and good connectivity from the phone CO plug to my terminal.
Bought a tone tester, good tone in the crawl space and the jack nearest the phone box outside, after that nothing.
Best Solution
posted on Feb 25, 2008
Helpful)
PHONE LADY
Rank: Wiz
Rating: 79%, 67 votes
If you have a dial tone at the closest jack and it doesnot go on through the house check to see if the red or green wire has been pulled loose or is broken at that jack or the next one. What happens when some one calls you? if they get a busy then there is a short where the red and green are touching each other. This sometimes happens only when a phone is plugged into the jack, in that case you can replace the jack. If the phone sounds like it is ringing to the caller and you do not hear the ring signal then you have a wire loose or broken( usually in a jack.) check each one and sometimes you need to pull on the wires the outer coating might hide the broken wire, Sometimes it might be just a loose screw in the jack.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Most home wiring is run in series. This means that the green or red wire is ran from the SNI (subscriber network interface) to the first (closest jack for a phone), then right back up the wall to the next (second) closest jack for a phone. Then, back up the wall and to the next and to the next and so on. This is called series wiring.
There are many variations of this.
The other home wiring is called home run. This is where most every jack wiring cable goes from the jack all the way back to the closest point to the SNI.
Hope this helps
Solution #3
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hope this helps
Solution #4
Somewhat Helpful)
Priority1
Rank: Wiz
Rating: 84%, 312 votes
Your wiring could be a mess of splicing, jumpers, additions over the years. It's impossible to know (or to really be able to help you) without being there in person.
Typically, you just have to worry about the red and green wires. The black and yellow are for a second line. This is of course only if you have standard 2 pair wiring.
If any work has been done recently I would concentrate on that area. If just one jack is removed or a wire cut by mistake that could easily take out your entire house. Also, if the red and green wires are touching anywhere that would also cause a problem.
Was this helpful?
Yes
No
Popular Solutions for Phones
Questions and Unsolved Problems for Phones
Answer
Need a unlimited phone book memory phone in CDMA
Answer
ferguson frg-116d dab radio power on ,screen light on ,but will not tune to any dab or fm channels?
Answer
The "new message" icon on our panasonic phone will not go off even though all messages... (More)
Answer
seceritycodeproblem
Answer
how do you transfer a call from an sli extension
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Phones Experts
Top Telephone Repair
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
