I am currently having audio difficulties. The volume comes on initially only to cut-off anywhere from 1 minute to an hour later. Other times the audio does not come on at all. No problems with image/picture (Sharp/Aquos LC-32D6U).
  • DaveRawson Feb 26, 2008
    Thanks. I will try to locate and install a new board.
    Genius:
  • 1,175 Answers
Try locating a new sound driver circuit board online
These folks may have one
www.tritronicsinc.com
Posted on Feb 24, 2008
No sub woofer output or very little
Your sub amplifier is detecting an overdrive condition and reducing volume to prevent the output stage from burning up. When reduced volume doesn't work, output is cut completely for 10 minutes until things have cooled down.
Mar 27, 2017 | JVC KD-R740BT
It became only while the car was idling, now it's anytime, anywhere, and never on a consistent basis. The engine simply dies, turns itself off. When it happens, the check gauges light comes on. Nothing...
is your stereo the OEM (factory original) model? Does the car have a factory-installed anti-theft system? If the answer to both is Yes, you may have a logic conflict since many anti-theft systems go to and through the car's stereo. If you still have the original owner's manual, check the section on anti-theft or security systems. It may list a reset procedure that returns the system to factory defaults. If you have an aftermarket anti-theft system, you may have to disable it until troubleshooting and repair processes have been accomplished. Incidentally, by the car sitting without a battery for five years, all E-prom programming may have been degraded or lost. As for the volume increasing, some GM/Delco radios have a volume compensation feature that increases volume levels as speed increases.
Oct 10, 2013 | 1997 Pontiac Firebird
Trying to adjust the preset sunset time on a ET8215C so that I can range beyond the 120 minute limit set at the factory.
ET8215C is Astronomic time piece that can also be programmed for specific on-off time.
http://waterheatertimer.org/pdf/Intermatic-et8015c-.pdf
1) You can disable the astronomic function by inserting a jumper shown in manual, and then program individual on-off times.
2) You can extend either DST start-time or end-time by fudging on the current time setting. For example if you want timer to turn off 1 hour after normal sunrise, then set current time 1 hour ahead. Of course this means timer turns on 1 hour later in the evening.
3) You can extend astronomic on-off times slightly by changing astro zone
4) You can set exact astro times, but the default maximum is shown as 120 minutes.
Add a comment and say what you discover to solve the problem.
Jun 13, 2011 | Intermatic ET8215C- 7-Day Electronic...
How do you set the time on the jvc kd-s35
Press and hold SEL button. Press ^ button 3 times to display H (hour) turn volume knob to change hour setting, press down 1 time to select M (minute) turn volume knob to change minute setting. Press SEL to finish the proceedure. Reference page 14 in this link to your JVC KD-S35 instruction manual.
http://books.jvcservice.com/Download/106224402/GET0563-001A.pdf
Nov 04, 2009 | JVC AM FM CD DET FACE CAR STEREO
Don't know how to turn off the alarm. Bought this used (made in 1995) so there were no books with it. It comes on every day at 2. The system is on 'standby' all the time. I just don't seem to find the...
Setting the ON time (Example: AM 10:15).
1. Press the TIMER button on the Unit for more than
two seconds.
The Timer indicator lights up and the hour digit of the
current ON time blinks on the display.
• When the clock is not set, “CLOCK” and “ADJUST”
appear alternately on the display. Set the clock first.
Press the ¢ or 4 button on the Unit to set the
hour you want the Unit to come on.
Pressing the ¢ button moves the time forwards and
pressing the 4 button moves it backwards. Hold
down the button to move the time rapidly.
2. Press the TIMER button.
The minute digits of the ON time blink on the display.
Set the minute you want the Unit to come on, using
the ¢ or 4 button.
2 Setting the OFF time (Example: PM 1:30).
1. Press the TIMER button.
The hour digit of the OFF time blinks on the display.
(The same time as the ON time will be automatically
set.)
Set the hour you want the Unit to be turned off, using
the ¢ or 4 button.
The minute digits of the OFF time blink on the display
Set the minute you want the Unit to be turned off, using
the ¢ and 4 buttons.
3 Selecting the music source.
The “TUNER” or “CD” blinks on the display.
2. Press the ¢ or 4 button to select the music
source you want to listen to.
The display changes as shown below.
TUNERôCDô(back to the beginning)
4 Setting the volume level.
The current volume setting blinks on the display.
2. Press the ¢ or 4 button to select the volume level.
-- :The current volume level will be used.
0 to 50 :When the timer is turned on, the Volume
will be automatically set to the selected
level.
5 Press the TIMER button.
The timer setting is completed and the display returns to
the display before you set the Timer. The Timer indicator
remains lit.
6 Before turning off the System, prepare
the music source selected in step 3.
TUNER: Tune in to the desired station.
CD: Insert a CD. (Playback will start from the first
track at Timer on.)
7 Press the % button to turn off the System.
In standby mode, you can see the Timer indicator ( )
on the display.
• When the timer turns on, the Timer indicator starts
blinking and the prepared source in step 6 will be
played.
To cancel the timer, press the TIMER button. The
Timer indicator ( ) goes out on the display.
To re-activate the cancelled timer, press the TIMER
button to light the Timer indicator ( ).
At this time, you can see the current timer settings. Each
setting appears on the display for two seconds in the order
of ON time, OFF time, music source and volume.
To change the timer setting, repeat the setting procedure
from the beginning.
Oct 31, 2009 | JVC KD-G210 CD Player
Put the clock
1.
Press and hold SEL (select) for more
than 2 seconds.
“CLOCK H,” “CLOCK M,” “SCM LINK,” or
“LEVEL” appears on the display.
2.
Set the hour.
1 Using the << / >> button, select “CLOCK H” (hour) or "CLOCK M"
Use the + / - button to adjust the hour/minute
3.
Press SEL to finish.
4.
To check the current clock time or change the
display mode
Press DISP (display)
repeatedly
During tuner operation it will show the frequency or time.
During CD playback it will show elapsed time or time.
Follow this link to download the manual for your unit in .PDF form
Mar 30, 2009 | JVC AM FM CD DET FACE CAR STEREO
Audio cuts out
HDMI is not a universal standard. Some units will not talk back and forth correctly and can cause lock ups, loss of audio or loss of picture. Try switching to component inputs and see if it works better. Check your owners manual but I believe the component inputs will also accept 1080P as long as the Panasonic Blu Ray can output 1080P. Don't believe what the Salesman said if he told you that you have to use HDMI or you won't get HD.
Apr 19, 2008 | LG 42LB5D 42 in. LCD Television
Time setting
read the manual: HOLD SEL: using << or >>
Set the hour and minute.
1 Select “CLOCK H” (hour), then
adjust the hour.
2 Select “CLOCK M” (minute),
then adjust the minute.
then go fwd or back using VOLUME :)
push sel again
Dec 17, 2007 | JVC KD-G310 CD Player
GT400 CD DECK
Press and hold the volume knob to get into the setup menu. Press and release the knob repeatedly until you see "Clock Adj". Push the DISP button, then turn the volume knob to adjust the hours. Push DISP again then turn the knob to adjust minutes. When you're done, press the volume knob again. You can download an owner's manual here: http://esupport.sony.com/US/perl/model-documents.pl?mdl=CDXGT400®ion_id=1
May 26, 2007 | Sony CDX-GT400 CD Player
89 people viewed this question
 Grubhead
Grubhead
