Question about Minolta X-700 35mm SLR Camera
Film rewind button stuck
I have an old ricoh xr-10. I just removed my last role of film and went to put a new one in. The film rewind button on the bottem is still in the "pushed in" position. how do I get it to pop back out?
  • 1 more comment
  • photo000 Feb 24, 2008
    Please help!!!!
  • photo000 Feb 25, 2008
    My teacher fixed it for me! so, never mind
  • Anonymous Jun 09, 2008
    how did they fix it I have the same problem!!! PLease help...
  • 49 Answers
SOURCE: Unable to rewind film in camera
Well, I used to work at a camera store and actually encountered this a number of times with Minolta's. I can't remember if the motors wore out or if the film slipped or tore at the track. The solution: take the camera into a darkroom or pitch black environment and remove the film by hand. Bring a pair of scissors and a black film container just in case the film tears or the track is torn. Obviously be careful to ensure no light is available if you can't access a darkroom. Check the bottom of the camera for a small button that disengages the motor gear (some newer models may not have this)(you may have to hold it in). Open the film door and with clean hands, use your index fingers and thumbs carefully on the tracks only and pull evenly. You may feel some resistance from the motor and hear the motor but if it won't budge check again if the bottom of the camera has a film release. As you do this feel for torn areas in the track which may indicate a motor malfunction or improperly loaded film. Now just wind the film back into the canister unless the track is torn. You may want to leave the leader out, and you should probably have the film developed right away for a list of reasons. If the track is torn, cut it off at the canister and touching only the edges roll it up and put it inside the plastic film container. Mark it "open film", or Open only in darkroom etc. and mention it to your developer. Alternately you can just hand over your camera to your developer who will do all of this for you...
Posted on Sep 14, 2007
SOURCE: 35mm Film Camera Ricoh XR-2
You can replace it with the available lever.Most of the cameras lever can suit
Posted on Apr 02, 2008
  • 185 Answers
SOURCE: Ricoh XR-10 35mm SLR camera
stevdan,
take the screws off the bottom cover. there is a small lever pointing toward the front of camera with a black screw on it. gently move it to the left, this will release the lock lever. Now advance the lever and the shutter should fire. if not, it is not repairable. no parts
Posted on Dec 14, 2008
SOURCE: mirror is stuck in "up" position and film will not advance
Normally, stuck mirror is due to weak batteries with a elcetromagnetic shutter like the Ricoh. Try with brand new silver oxides and see if it helps!
Posted on May 28, 2009
  • 571 Answers
SOURCE: i push the rewind button and crank yet the film does not rewind. two seperate times the film came out of the canister. what am i doing wrong
Make sure to press the rewind button hard enough.
Posted on Aug 18, 2009
The film advance lever is stuck on my Minolta Hi-Matic C. I bought this at a thrift store today to see if it worked. The film advance lever worked fine for a while and then got stuck. Put a new battery...
Have you rewound the film? If you rewind the file completely and pull out the rewind know, it will pop the back open . . . and can remove the film cassette. While the back is still open, complete the cycle on the winding crank. The winding crank should return to "Normal" arter you complete the winding cycle. When you close the back, everything should go back to normal.
Jul 18, 2017 | Minolta Photography
My Ricoh kr-5sv's rewind button is still pressed in after i rewound andd took out the film. how do i get it to pop out again?
The rewind button will usually pop out once you turn your film advance lever. In order for you to be completely familiar with your camera, here's a link to a user's guide in pdf format:
http://www.butkus.org/chinon/ricoh/ricoh_kr-5sv/ricoh_kr-5sv.htm
Hope this helps.
Mar 25, 2011 | Ricoh KR-5SV 35mm SLR Camera
The film magazine stuck in the Canone EOS 10 camera, never happened that before, i could easily insert and remove the film. it's rewinded, luckily, but I need a new one to put there, + I'm afraid if I...
Nikon N75 or Canon EOS 10????????
How is the film stuck? Is the rear door stuck? Does the film door open?
As long as you do not damage the film canister, the film will be ok. If the door opens and the film is rewound, use something to pry out the top of the canister from the camera. Then you can remove the film.
Even a film roll of 36 should not get stuck. Check the cartridge are for anything sticky. Sometimes these older cameras get some sticky residue from decaying foam in the shutter area. This would be a good time to send it in for CLA - Clean, Lubricate, Adjust.
My own EOS 10 had that problem. If you can't get the film out, the repair shop will do that for you.
Jan 20, 2010 | Nikon N75 35mm SLR Camera
Blank film
Make sure when you load your film, that the cogs are actually winding the film. Many a roll has been "shot" with the film ever advancing. If you see what your taking, that is really about all that it could be.
Jun 28, 2009 | Ricoh XR-10M 35mm SLR Camera
Wind film?
Behind the LCD screen on the back of the camera, is a a gray button marked "R", and a gray slide switch to the immediate left of that.
Press and hold the R button, while sliding the switch to the left, this can be easily done with one thumb. the display will blink 0 and the motor will stop when rewinding is complete.
-John
Feb 21, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Mirror is stuck in "up" position and film will not advance
Feb 21, 2009 | Ricoh XR-10M 35mm SLR Camera
XR 7 locked up
Just read on another forum where the film rewind button can get stuck (little button on the bottom of the camera, used to initiate rewind), and removing the camera bottom allows access to unjam it.  I'll try... takes a small philips eyeglass screwdriver and young eyes (or my reading glasses...)
May 15, 2008 | Ricoh XR-7M II 35mm SLR Camera
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
Minolta X-700 35mm SLR Camera Logo
500 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
