Question about HP OfficeJet 6110 All-In-One InkJet Printer
Remove and check cartridge
This message keeps coming up - I've changed cartridges and I still can't get the darn thing to print.  Any advice?
  • 3 more comments
  • boppy1234 Feb 24, 2008
    how do i run the calibration sequence?
    Don't know where the user manual is ... :-(  I can't get the menu to come up when this message is flashing nothing will happen.
    no IM - sorry - but i appreciate this help!  i turned off the machine and restarted it unplugged from the computer - but i still get the "remove and check cartridge" messge
    it is -- in fact i was printing from these cartridges (which still have ink in them) just yesterday...
    i have the cartridge installed and i am still getting the same message - for both the left and the right cartridge.  how do we do the shared screen sessions?
    Genius:
  • 3,587 Answers
Sure..run the calibration sequence from menu..print a test page..
Posted on Feb 24, 2008
  • 3 more comments
  • Patrick Michaels
    Patrick Michaels Feb 24, 2008
    from menu on front, or from computer print manager, depending on which you can access.do you have the user manual?
  • Patrick Michaels
    ahhh..got it....that's what I was seeking..turn off machine, and then restart it, unplugged from the computer, please?
    do you use IM, by chance?
  • Patrick Michaels
    ok..one thing..do you have the old cartridge? if so, compare the two of them, and make certain that the new on going in, is identical to the old one coming out, in every way.
  • Patrick Michaels
    good..would you please place the old cartridge back in machine, and relate if it's still the case..
    btw, we might be able to solve this with one of our Shared Screen Sessions, if you're open to that..
  • Patrick Michaels
    send me a note to my email address as listed on my profile, and I'll send you instructions
My hp officejet ignore printing after replacing of cayne colour cartridge.
I hope Magenta cartridge is not refilled one right? :#Remove all cartridges and print heads, disconnect power & USB cable, switch off wait for couple of minutes.. give power switch on the machine wait do as per the message appears on display.. once installed cartridges and printer heads wait for the ready mode:.. once ready mode appears attach USB cable then print and see..# check with old and new cartridge see the difference of message.. if both messages are same it might be problem with ISS(Ink supply station) faulty, try it get back to us..for further remedies.
Feb 03, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
HP2610 will not print. Getting "remove and check cartridge..."
I just had this same problem (cartridge on left). Something had broken that was holding the little metal wire in place--the one that sticks out along the bottom where your cartridge goes but apparently moves to the side when you install the cartridge. My guess is that this wire may make some sort of electrical connection that indicates when the cartridge is all the way it (if it doesn't move--or if it is broken--it doesn't make the connection and it thinks something is wrong with the way the cartridge is installed. So I used a strip of tape to hold the wire in place on the side of the cartridge compartment (it had been loose and flopping around), and it works fine now.
Oct 20, 2009 | HP Photosmart 2610 All-In-One InkJet...
Changed ink cartridge now it won't work
Try removing the black and see if the error is still there. If it goes away the black is bad, if it stays you got a defective new color cartridge.
Jul 01, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Remove and Check Cartridge
One of the cartidges you have purchased is faulty.
you can reinstall the empties one at a time as a process of elimination to determine which new cartridge is the problem
Jun 06, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp 1410 all in one keeps saying prin cartridge error
Follow the steps given below and check for the results
=== Cleaning the ink Cartridges ===
Even if the cartridge is new, follow the steps below to clean the print cartridge contacts. Print cartridges have a substance on the contacts to keep them from corroding during storage that may cause poor electrical contact between the print carriage and the print cartridge.
  1. Verify that the product is turned on. NOTE: If the HP product is not turned on, you will not be able to remove the print cartridges.
  2. Open the unit to access the print cartridges.
  3. After the print carriage (the part that holds the print cartridges) stops moving, unplug the power cord without turning off the unit using the power button. If you turn the unit off the print cartridges will be capped to prevent them from drying out and you will not be able to remove them. You must unplug the power cord to prevent the print carriage from moving.
  4. Remove both print cartridges.
  5. Verify that the part number on the cartridge is the correct part number for the unit.
  6. Using a cotton swab or lint free cloth (like a coffee filter) lightly moistened with distilled, filtered, or bottled water, clean the electrical contacts of the cartridge. Figure 1: Electrical contacts c00055424.jpg NOTE: When an all-in-one is used frequently for black and white printing but infrequently for color printing (for example, an all-in-one that is used primarily as a fax machine), the color cartridge will still eventually fail and need to be replaced. The pins in the print carriage can cause dents on the contact points of the color cartridge over time (usually between six and twelve months).
  7. Wipe the contacts with a dry, cotton cloth, as shown, to dry the contacts and finish cleaning. Figure 2: Wiping the contacts c00055425.jpg
  8. Reinsert the cartridges and lock them in place.
  9. Close the top cover or access door and plug in the power cord.
  10. If the error continues, repeat these steps. If further cleaning fails to clear the error, proceed to "Step two: Cleaning the print carriage contacts" below.
Step two: Cleaning the print carriage contacts Have the following materials available to clean the print carriage contacts:
  • Cotton swabs or any soft material that will not come apart or leave fibers.
  • Distilled, filtered, or bottled water (tap water may contain contaminants that can damage the print cartridges) CAUTION: Be careful not to get ink on hands or clothing.
Do the follow to clean the cartridge contacts inside the product:
  1. If the unit is off, turn it on.
  3. After the print carriage stops moving, unplug the power cord. Do not turn the unit off before unplugging the power cord.
  5. Using a cotton swab or cloth lightly moistened with distilled, filtered, or bottled water, clean the electrical contacts of the print carriage as shown below. Figure 3: Cleaning the carriage contacts (your model may look slightly different) c00130268.jpg
  6. On models equipped with locking latches, lower the latches. Figure 4: Latches in the lowered position (your model may look slightly different) c00055427.jpg
  7. Wait five minutes for the contacts to dry and then plug in the power cord. The unit will begin to reinitialize. Wait until the process is complete before proceeding.
  8. Reinsert the print cartridges when prompted and then close the top cover or access door.
  9. If the message recurs, replace the print cartridge indicated by the message. If you are using refilled or remanufactured cartridges or non-HP cartridges, replace them with new HP cartridges. HP cannot guarantee that refilled or non-HP cartridges will function correctly in HP products. If a new HP ink cartridge is defective, return it to the place of purchase with the receipt, or contact HP to obtain a replacement.
  10. If the problem still exists, replace both print cartridges. Since the cartridges are electronically connected through the printed circuit board, the cartridge not indicated in the message might be the causing the failure
If the issue still persists then try the following steps to identify the problem ink cartridge
1. Remove both the ink cartridges
2. Insert the Color ink cartridge first and close the ink access door
3. Check if you are getting any error message or the ink cartridge light is blinking
4. Now remove the color ink cartridge and then insert the black ink cartridge and close the ink access door
5. Check if you are getting any error message or the ink cartridge light is blinking
Replace the problem ink cartridge anc then check
May 17, 2009 | HP PSC 1410 All-In-One InkJet Printer
"REMOVE AND CHECK COLOUR CARTRIDGE" KEEPS COMING UP NO MATTER HOW
this would probably be a printer failure itself, the print head that reads the presence of the the cartridges is failing and you need to check if theres any sign of leakage or broken parts
Dec 22, 2008 | HP OfficeJet 6210 All-In-One InkJet...
If you already changed the cartridges for new ones, there should be a problem with the printer's carriage.
You need to take it to a repair store, but I advice you to buy a new one, because the price you will pay for the repair should be the same or more than what you pay for a new printer.
Nov 26, 2008 | HP PSC 2210 All-In-One InkJet Printer
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
ERROR MESSAGE
please check and clean the unit where ink cartridges are located
Sep 21, 2007 | HP 920 Plain Paper Fax
HP OfficeJet 6110 All-In-One InkJet Printer Logo
55 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
