Question about SanDisk Sansa e250 MP3 Player
My sansa works fine until I plug it into my computer
Then it just turns on and off, on and off, in an endless cycle.
My sansa turns on and has the bars show up, but then it freezes like that then i have to turn it off in a weird way.
Posted on Feb 25, 2008
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
How do I stop my Bosch logixx 8 from beeping endlessly at the end of a cycle?
hi, I found out last night after being wokenup by endless beeping.... start with program dial at " off position", then turn 1 notch to the right, and then press and hold eco-perfect button and turn prog.dial 1 notch to the right. a number will appear in the display. press"clock" button until number is 0. then turn prog.dial one notch more and do the same. all sounds are off now....
May 09, 2012 | Washing Machines
I have a sansa E100 seriers MP3 player. I was using it fine yesterday , and it just stopped working in the middle of a song. Today I changed to a new battery and it will not turn on. If I plug into the...
Run the recovery tool from the SanDisk website .
Download Sansa Disk Recovery tool
How to use Sansa Recovery tool(instructions)
Download Adobe reader
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Mar 20, 2011 | SanDisk Sansa e100 MP3 Player
My sansa E280 will not turn on
I have more advice on my Tips & Tricks for fixing Sansa players, but here is a likely candidate:
Download the Sansa Recovery Tool from Sandisk's website (make sure the Sansa is not plugged into the computer yet). Once the Recovery Tool is downloaded, connect the Sansa to the computer while holding in the REC button and continue to hold it even after th player is plugged in. It should go into Recovery Mode in 10-15 seconds or so.
-Tha Mp3 Doctor
Jan 17, 2009 | SanDisk Sansa E280 MP3 Player
My altec lansing speakers for my sansa is messing up my sansa
-Tha Mp3 Doctor
Dec 27, 2008 | SanDisk Sansa E280 MP3 Player
MTP Mode Doesnt Work
Try uninstalling MTP Mode in the Windows Device Manager, and replugging the player - set the menu setting in the Sansa itself to "auto" for USB Mode before replugging. Let me know how it works.
Jun 13, 2008 | SanDisk Sansa e260 MP3 Player
Computer shuts down and tries to reboot in an endless cycle
This sounds like a heat related issue.
Are you sure that the CPU fan is running and that the vent ducts are all clear?
You maye be able to get it cleaned out with a can of compressed air.
Is the computer new? If so, then it is probably not dust, but if it is more than a couple of years old, then that is probably the problem.
Dec 31, 2007 | Acer TravelMate 290 Notebook
It just froze
let the battery run out until it shuts off, then plug it back into your computer. Hope it Works!!
Dec 23, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
